Everything posted by offroadsubaruguy
intake manifold differences?
is there any difference between a intake manifold for the dohc and the sohc heads for a 2.5???
Questions about ecu...engine type
well, i know for a fact that you can run a 2.5 on a 1.8 ecu, my buddy did it for awhile on his rally car, at least until the turbo came..... so i dont see why you cant run a 2.5 on a 2.2 ecu? you might need to change a few wires or maybe add some, but i doubt it.......
Forester with 4" lift and 29" Super Swampers
i would definately drive that forester, but only that froester...... maybe i shall have to get me one so i can do something kinda like that with mine, then i'd be ok with it, but not a stock one......
Started a group buy for lift kits
i remember you told me once already, but how much for the outback/legacy lift?
turbo a 2.2L
the only turbo kit i've seen is made by avo, and i think that it was around $4,500 to buy it, comes with everything you need to bolt on and go, but i think that it would probably be cheaper to do a wrx swap instead.... its up to you.... check http://www.rallitek.com for the turbo kit, thats the only place i have found it anyway.....
Looking for rising suspension or aftermarket kits
offroadsubaruguy replied to paparaz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXuse outback struts with legacy tops and you'll get a little taller. it will also allow you to run a much taller tire of your choice...
New Member 1994 Legacy Turbo Wagon
they are rare, but just treat it like you would any other subaru as far as maintainance goes, and it will last you forever.... oh and by the way, im jealous:slobber:
best/biggest tires for my 98 obs daily?
im running 27 inch mud terrains. it did down my gas mileage some, but since everything is off now i can tell exactly how much.... oh, and i got em for around $80 a pop off of tirerack... kumho venture m/t...... you will only get stuck by getting high centered with this tire. that is the only way..
halfshaft swap???
has anyone else thought of using svx halfshafts on their newer offroad rigs? after a certian point suspension lift, you'll need longer halfshafts right? well what about svx halfshafts? they are longer, and they should fit into just sbout any newer subie right????? just figured id check my ideas on the board.....
tire question
i am currently running kumho venture m/t 27-8.5/14...... cheap, they work better than anything else i've seen, and they dont make too much road noise....
Justification for lifting your Subaru
heres another one for me... my fiance wants me to ditch the wagon and go for an suv.... so my new reasoning for lifting the wagon, it'll be just as big as an explorer, have more ground clearance, and you wont have to climb into it. plus it'll be cheaper than any v8 on gas....
How tough is my Subie?
on a non lifted rig, i have never had any problems with the newer models, i have broken strut tops on the older ones though.... other than that, nothin wrong.....
Sti 8 Jap Version Please Help
offroadsubaruguy replied to amjid55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits prolly got something to do with the fact that the cats are gone...... youre o2 sensors are probably freakin out and throwing the check engine light, which then causes limp mode ( full rich ) then making the car not want to do anything. not positive, just my .02 cents
15" tires on a 93
offroadsubaruguy replied to jimscat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, just downsize the tire accordingly....
top speed???
offroadsubaruguy replied to n16ht5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif i remember correctly, subaru puts in a speed govenor at 110mph.. all of the newer subarus that i have driven ( from the begining of the legacy and on) have stopped at 110..... im not sure about the imprezas though......
EJ22 vs. EJ25
it all depends on what your looking for.... exhaust, if you have dual port heads, you can use 2.5 exhaust headers, or y pipe, from there back it should fit no matter what. internals, i have heard that the heads will fit, but the cams by themselves wont fit into a 2.2 head ( kinda iffy about that one ) flywheels will swap, so it all just depends on what it is you want to do and how much money you have to spend.......
idle dropping????
thanks again........we'll see if that works.
idle dropping????
thanks for your imput guys, i'll try both of em.... where is the idle control valve located?
idle dropping????
every once in awhile my idle drops and my car tries to die. it jumps back up before the car dies, but it kinda bugs me...... any ideas? its a 90 legacy wagon, with a manual, and a weapon r intake setup..... it has been going on for a while, even before the intake was installed, but more often now that the intake is on.... im stuck here, im outta ideas.....
simply put....... i understand the jeep thing, thats why i drive a subaru!!! :lol: plus, its just fun
Max Boost on 02 WRX?
if i remeber correctly, you cant really use a mbc on subarus because its all done by the ecu.... i have heard of instances where someone tried to use one and it did nothing because the ecu will basically override the mbc and only stick to that which is programmed... however, i do know that you can reflash the ecu to allow more boost. safe limits? i would say that 20 would be safe, but im pretty sure the motor can take at least 30, the tranny is a different story though.....
Ditch '84 for '93 for Offroading?
if you can find a 5spd d/r then you can swap the trannies, but the 4spd wont work, less splines on the input shaft i believe... as far as final drive? imprezas have the 3.9 in them, which makes out good since all d/r trannies are 3.9....
Ej20t
i think the only real difference is the horsepower and torque, but i could be wrong...
Rally Cross a GLF
first suggestion, ditch the muffler, go cherry bomb. it might not make you go much faster, but it sounds awesome when its in the higher rpms...... second, either modify the air pan you have, or get another one and cut the sides off. from there it all depends on what class you want to run... i would think that any other modifycations would class you in at least g2 ( group 2, incase you didnt know ).... but either way you'll have a blast, i wish that i could get my new wagon down to some rally crosses, but sundays are just not a good day for me anymore so i have a hard time getting to em...... have fun and enjoy the car!
A Lift For My 98' OBW...
im driving a legacy, that will have outback suspension on it..... so kind of a mutt if you will......
