Everything posted by subie94
external cages
i know it's not a subie but has anyone thought of doing the same with a subaru?i'd give it a try but don't have a welder
PICS of my GL10 OFFROAD!
i enjoyed the pics but didn't see any movies :-\ still some cool trail pics.also loved this pic:
Why do people rely so heavily on compression braking?
in my 94 legacy i get 23 mpg,that's mainly city driving with maybe about an hour total of highway driving during the week.i use engine braking to slow the car abit then reg brakes go on. on the highway last week i did prob a big NO-NO!! was at about 65mph an coming up to the off-ramp i needed to take.realised i was going a bit to fast for it so what do i do?downshifted it from fifth to third without braking first.tach shot up to about 5000rpm (was at about 2500rpms) i did slow down though,quicker then my reg brakes would have done.(everything seems ok with those)there doesn't seem to be any effects from the downshift boo-boo compression braking can't be that bad,18 wheelers do it
MN 4WD Association Anual Event, Pics!
great pics
Corky's Garage Saga
looking good, it kinda sucks renting an apartment,can't do any building like your doing.stuck with a de-crap-ated garage that has no power,manual lift door an no insulation(nice an breezy during winter) you ever think of putting in a skylight? or two.
New member, thought Id say hi
welcome to the board. i used to own a 86 gl-10,oh did i love the turbo sad thing was that it was rusted way beyond help main places of rust was underneath near where suspension mounted,trailing arms too(?)
How many Subaru's on your block?
subie94 replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere's mine (94 leg),way down at the end of my road there's a impreza wagon (96-99?),just about a block away there's another legacy wagon.looks like a 92.not to mention another legacy wagon around the corner and a sti (white with carbon fiber hood an trunk lid)that's sitting at a garage on that same street(around the corner)
?'s re:outback struts on 91 leg wagon
had a feeling ob springs would make for a stiffer ride.is there any extra lean when going around corners? it doesn't make you feel like your gonna fall over does it?
is there a height diff between stock legacy springs and outback springs?not sure if i want to do any drilling.also thinking of picking up the scorpion lift springs.
Atf????
subie94 replied to mtbshark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthough i have a 5spd,i have heard good things about royal purple.seeing that atf is used for power steering,maybe i'll try it out to see what effects i get
4wheeled the Loyale... for real this time
:lol:
Mud is fun, but it's gross...
i have to agree with soobmater,looks really nasty.almost looks like....? um melted brownies or something.as far as cleaning the mud out,i've never had to cause i never let it in.
Crawl 4 the Cure; Subarus Well Represented! - New Pic Location
now that makes changing the oil real easy
To FWD or not to FWD...
subie94 replied to Thesis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXawd is better then fwd any ways(that's how i feel).if you want fwd then try an find a subie with a d/r tranny that way during summer(fwd) and during winter (4wd) i agree with rcg.be happy with what you have. :-\
Once again...wagons are awesome.
subie94 replied to WJM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXholy snizzle and i thought loading a twin hospital bed(non electric) with mattress,hospital bed table and a couple misc things was a load full for my old 92 legacy.
Stuck! :) (updated with retrieval pix modem sammich)
man that sucks about your audio equipment growing legs an walking off.i have had that happen acouple times. looked like it was fun in the mud(till you got stuck)
Smoking front brakes - '96 Outback
subie94 replied to rlynam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi was thinking the same thing.on the 92 i had it was doing the same thing but after changing the front calipers i found out it was the hill holder. rlynam- do you have auto or standard?if auto then more then likely caliper,if standard then i'd check the hill holder to make sure the cable's not stuck(keeping it on) unless you have hydralic clutch then i'm not sure if those have h/h device
Which Optima Battery Fits In A Subie?
subie94 replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell i've seen the yellow tops go for around $160.-$180. if you have a local audio shop in your area,they might even have em in stock
Finally doing some offroading!!
ok,now that i looked closer i see it
which choice? (about tyres)
i just took a look at them,looks gnarly.must have great traction. how's the road noise with them? guess i'll be forgetting about those other tires
http://www.tyres1.com/search/search.cgi?web_code=BFAT here's a better link.only size in 14's are 27x8.5x14 for $89 bucks
subie94 replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell as it turns out,it's dead.it charged up but as soon as i load tested it,volts dropped down to nothing (4 volts) but when load was removed,volts in battery went back up.so to be on the safe side i just went to walmart an picked up a new everstart battery.granted it doesn't have as much cca(525) but it is brand new soo.... :-\
subie94 replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think mine's dead went out to go to the store earlier and nothing.wouldn't even crank over.put a j/y battery in an it started right up.alt is charging fine(13.89v) i have the yellow top on charger right now,hopefully it recharges.
Subie powered Rock Crawler...
yup that's it.
Cheap GPS for Speedo?
if you go to http://www.tyres1.com and check out the interactive calculators and click on speedometer check.you can find out how much your new tires will throw off you speedo an do what i did,just remember to add that extra mph when you look at the speedo
