lmdew
    173
Everything posted by lmdew
  1. It can sometimes take a few days for the lifters to pump up if the engine has been sitting a long time, years in some cases. I've seen it on numerous used engines I have installed. I've never had one that didn't clear up.
  2. Local used is the best. www.car-part.com is a good place to check full service yard prices, but shipping is expensive.
  3. Lot's of You Pull and Pay Yards up your way. www.car-part.com Or swap to a manual 5 speed trans.
  4. Did he check the input shaft for play? I just dropped a trans out of an 01 Forester the inner hub of the clutch disk was completely severed from the outer disk. The shop that surfaces my flywheels said it looked like someone downshifted at high speed. The input shaft to the trans also had lots of fore and aft play. Used Trans going in along with a new Clutch Kit.
  5. I just punched in the trans code and that is what it came up with. Anyway they match now as they trans and rear diff are from the same car. $60 for the diff and some time. Larry
  6. I grabbed a trans from a 02 Outback for a 01 Forester. The forester has the old style suspension found on 90-99 Subarus Legacy's. The original trans was a 4.11 but the Outback was a 3.90. So I had to swap the rear diffs as well. I didn't know for sure they would fit, but all bolted up well and it's going down the road. The new style suspension was harder to get the rear diff out, as the side play to pop the axles out was not near what the older style is. Hope this helps someone down the road. Larry
  7. Do you have VVT? I changed a fellow cam and crank gears for him to get his engine swap going and the drivers side cam gear had 2 yellow dots and lots of tick marks on the face. I matched it to an old cam gear with a single tick mark and the tooth between the yellow dots match up so that is were I set the timing. Ran well.
  8. Start with the easy stuff and make sure the brake pedal is actually activating the switch. Sometimes the little button wears out and the switch is not activated..
  9. Yes make sure the TC is fully seated in the trans. One way I've found to ensure it's all the way in is to push back slightly and rotate it. If the starter is still bolted in place it will just rub the starter gear. When you bolt it up to the flex plate it will pull forward about an 1/8".
  10. One way to mark it for sure, cut the head off, push the nut and what's left of the bolt out of the way and drill up from the bottom. Larry
  11. I had the bolt out so I drilled up from the bottom to locate the hole. Mine was on the drivers side. If you can't get the bolt out, just measure over an inch or two and drill up from the bottom to locate the hole. You can use an 1 1/2 or 2" hole saw and drill from the top down. Then just put in a plug. If you ever have two remove it again, no problem.
  12. Way back when I had one cross threaded. I had to saw the bolt off and then I drilled down through the floor pan with a hole saw to give me access to put a nut on. Those cross thread very easy.
  13. You need to remove the guard so we can see the crank gear alignment mark on the back!
  14. Pumps are self bleeding as you move the wheels. If you pick up a good used one with no leaks, you should be good to go.
  15. I picked up a 00 Forester 210K on it. It runs good but the clutch was completely out. PO said the trans was out, didn't move at all. Not even a little drag. I pulled the engine and trans today, the clutch friction material was completely free of the center hub. It was an aftermarket clutch (South Africa stamped on it). It does have the aftermarket input shaft sleeve and throw out bearing. I can move the input shaft about a 1/4" in and out. The side play is slightly more than normal but not to bad. The forward and aft movement is bothersome. The Trans Code is: TY755VC1BA = 4.11 I do have a spare trans TY754VCBCA = 3.90 So a few questions: 1) What sets the play in the input shaft? I have no idea what happened or if there was any strange noise before it quit. It seems to shift well and all of the drive shafts move as normal. 2) If I swap to the 3.90 and put in a matching rear end, how can I correct the Speedo? 3) Is it worth splitting the cases to fix the input shaft play? The gear oil was a little dirty, but not to bad, no chuncks and just heavy fuzz on the plug. Thanks, Larry
  16. Pretty easy to drop the tail shaft housing. Yep you will need to get in there to see what damage is done. Search torque bind and you will find some good picture.
  17. Well you say trunk and then hatch. Sedan's have trunk lids, Wagon's have a Hatch. Sedan, you should be able to go through the rear seat and get into the trunk to pull the release. Wagon, you need to pull the lower panel off the inside, about 8 little plastic buttons across the bottom and then pull it off. Once in you can manually release the latch. Before you do all of that, push down while someone does the electronic locks for you a few times.
  18. It's only $2.00 at The Subaru Dealer. The EJ22 does not have the HG problem the 96-99 DOHC engines do. the newer 2.5 SOHC engine call for the conditioner.
