176
Everything posted by lmdew
Possible but hard. With the long studs, it's possible to pull the drive shaft remove all of the bolts and nuts holding the trans to the engine and frame and then slide it back. Your are now working in a 2 - 3 inch gap. If it drops down off the studs, it will hit the cross member of drop all the way to the ground. Better just to pull the engine or trans I think.
Before you buy anything, figure out what has failed! - Check the T-Belt and pulleys. You have to pull the front covers but you can do that by removing the radiator fans, leaving the radiator installed with no loss of coolant. - Check the Oil Filter for Metal Rule out the simple things first and if you need an engine, get a used 95 2.2 with EGR. It's a plug and play swap for the most part.
2003 Forester
lmdew replied to KFoxArt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You should be good to go. Drive it in tight circles and see if you have any torque bind in the transmission. Yes they last a long time and the Dealer did the essential maintenance already. -
Front Hub: Before you remove the brake rotor, put a large screwdriver into the rotor through the brake caliper to lock it up. Break the axle nut loose and make sure you can put the axle in. There are so many in the yards, it's not worth messing with one that the axle if frozen in with rust. After all it is Colorado. Remove the steering rack nut and smack it, it will come out Remove the bottom nut on the ball joint and put a large hammer on the back side of the lower A-arm and hit the font until the ball joint pops up Then remove the upper strut bolts. Rear is just about the same, but remove the lower knuckle to support arms, long bolt first. Again if it's frozen move on.
Are you pulling the front half, back half or complete drive shaft? Yes, it's the best access to drop the exhaust. Sometime the exhaust connections are rusted up pretty tight so dropping the complete exhaust may be the best option. O2 Sensor/s disconnected, 6 manifold nuts, support nut aft of the trans and then the rubber supports and drop the complete thing. You have to get the exhaust down far enough to remove the tunnel heat shield so you can remove the mid bearing drive shaft bolts and unbolt the drive shaft.
