173
Everything posted by lmdew
I have a nice rust free pan if you want it. $20 + shipping from CO. A good steam clean is where I'd start and then find the source of the leak, If the TC was pulled out of the trans and then reseated the main seal may be damaged. As others have said, the trans coolant lines may have been damaged when the engine was changed. The trans funnels with a plastic hose on them work great!
Yep, works great. I've done this numerous times. I end up using about 3 gallons of fluid.
The clutch is spring loaded. The pressure plate tension is released by the clutch. It's unlikely that the hyd system would cause the slipping. Make sure you check the rear diff and make sure the axles are fully inserted. I've had a couple of them where one axle had popped out about a 1/2" and all the power to the rear was not going to the wheels. Felt just like a slipping clutch. Two other Mechanics told the previous owner the car needed a clutch. Putting the axle back in fixed the problem.
Winches
lmdew replied to miatapasta's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The hitches bolt into the frame, with the same bolts that hold the bumper on. It would be pretty easy to weld up a mount for the winch. -
Yes, if you need a couple of spare cam and Crank Sensors, I can send them to you. Friday, I'll be flying through ORD. Larry
With the timing belt off you can rotate the cams so the valves are closed and then put the crank front belt pulley on and turn it with the bolt. The passenger side cam is free when the alignment mark is up, so those valves are closed The Drivers side cam is under spring pressure from the valves being open. You can rotate it about a 1/4 turn clockwise with a 17mm wrench on the cam sprocket bolt to close the valves. Once the crank is set, just rotate it back to the alignment mark.
