174
Everything posted by lmdew
You need to find the source of the noise. Changing the length of the strut put your CV joints in a new spot, but if they were in good condition that should be OK. Did you make sure the top strut mount was tight? I've swapped struts where you need a thick washer on top of the strut mount to take up the added length of the top strut mount. Otherwise the nut runs out of threads and you still have movement of the top strut mount plate.
Easy way is to pull the complete bumper and then pull the cover. A junk yard trial run is usually a good use of time: - Remove the mud flaps - Remove the 10 mm nuts holding the front side of the bumper to the body (2 of them I think) - Unplug the plate light connectors under the spare tire cover - Remove the 2 19mm bolts on each side, accessed through the cargo area on each side of the flip up spare tire cover and under the plastic covers on the body. - Slide the bumper back and off
flashers
lmdew replied to subaru forever's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Flasher/blinkers go through the emergency flasher switch on the center of the dash. Did someone change the radio? If so they may have not plugged the connector back in. -
T-belt, idler pulleys, cam and crank seal and reseal the oil pump all due at 105K It's about $250 in parts + labor. The Gates Kits on amazon are good. You can go to a Subaru Dealer and have them pull the maintenance records for any work that has been done at a dealer and if you register the VIN with them in your name they will send you maintenance reminders.
Sounds to me that your shift linkage has become disconnected from the trans. - Put the car on ramps or jack stands - get under the car and you will see the shift linkage going into the transmission on the drivers side rear of the transmission (right up above the rear trans cross member) - Have someone shift the transmission into all 6 positions - Did the trans input shaft move with each shift? If not you have found your problem - fix the linkage.
Get the codes. Even if the CEL is not on the codes will be stored. Most Auto parts will read them for Free!
- 8 replies
- check engine light flashing
- subaru outback 2002
- (and 4 more)
I'd be willing to bet it's the breather plate that is causing the oil leak you are seeing and not the pan itself. RTV only on the pan. There is a breather seal at the right rear corner of the oil pan as well. I'd clean it up real well and watch it. If you are going to do the clutch and breather anyway, just wait until then to do the pan. Change out the PCV with a Subaru one. They clog up sometimes and cause high oil consumption.
