Converting from auto to manual tranny.
Legacy777 replied to turbo92subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGuess it would help if I typed the correct url Actually I'm more or less a backyard mechanic....I'm an engineer by day All the turbo legacies had the same ECU, so no you wouldn't have to swap ECU's. You will however have to deal with the same/similar wiring issues as I did. ie the neutral switch, at/mt identifier pin, reverse lights, shift lock, and cruise control. You'll probably also have to deal with abs as well. If you pickup a turbo legacy transmission, you won't have to deal with the rear diff or anything. You will still need a manual tranny drive line, transmission, trans crossmember, and other goodies. You'll basically need everything I did minus the rear suspension, rear diff, suspension, ECU, & gas tank.
CEL OBD I Questions
Legacy777 replied to A_DuB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes the computer will repeat ALL the codes stored in its memory until the key is switched off. So from your post, I'd say you have the following codes code 22 code 13 The computer should repeat all the codes, and not just one. I don't know what to tell you. Try pulling the EGI/TCU fuse, to erase the stored codes. Drive the car and see if any come back D-check If you have done the above procedure, you will likely wonder what the green T-shaped connectors are for. These are for a more active code reading procedure called D-check mode in the Subaru manuals. To perform D-check, start with both connectors disconnected, start the engine, allow it to warm up, then turn it off. Next, connect the test mode connectors (green T-shape). Turn ignition to ON position without turning on engine. At this point if the check engine light does not come on, it is faulty and must be fixed before continuing. Depress accelerator pedal to floor, return to half throttle and hold for two seconds, then release. Start the engine. Now the light can blink in two different ways. If everything checks out so far, it will blink to indicate a number 01, 02, 03, 04, 05, 06, 07, or 08. If a problem is already detected, it will blink according to the chart below. Either way, your next step will be to drive the car with the test mode connectors connected. You must drive over 7 mph for at least one minute, and shift up to 4th gear if you have a manual tranny. Now, either you will discover any trouble codes, or if you have none it will blink at a steady rate.
oil overfill?
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook at these pics. You're going to really have to over fill it to get the crank whipping the oil http://www.main.experiencetherave.com:8080/subaru/images/ej22t/2/
Legacy777 replied to turbo92subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you read my swap info? www.surrealmirage.com/subaru/swap
oil overfill?
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not good.....however I don't know if it will damage the engine....
A What-Cha-Ma-Call-It
Legacy777 replied to Prauch007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.subarugenuineparts.com www.subaruparts.com www.1stsubaru.com
Trans fluid coming out the bell housing
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe impreza tranny would bolt up, but the gear ratios are probably different. Where is the tranny fluid coming through? Like where on the bell housing....bottom, side, top?
Clunk ca clunk
Legacy777 replied to Thesis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere should be a fuse holder under the hood near the passenger strut tower that you can temporarily insert a fuse to disable the awd. If the binding goes away, then your clutch packs probably could be replaced. Have you checked the trans fluid? Does it smell burnt or look brown? I'd change the tranny fluid and see if that helps.
AWD & Manual Transmission
Legacy777 replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 5spd AWD system will deliver torque equally to the front and rear. If you provide enough torque to break the wheels loose, both the front and rear will peel out. With the AT AWD system, you'll likely get a faint front wheel spin, but the AWD system will start applying more torque to the rear wheels. It will continue to do so until front wheel slip is gone, or until torque split is 50/50. At that point, both front and rear wheels should spin, like the MT.
94 Legacy LS Wagon Transmission late to engage
Legacy777 replied to sregor13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes this happen only after the car has sit for a long period of time, like overnight? If you drive somewhere, turn the car off, come right back, do you also get the delay? Have you checked the transmission fluid level?
legacy exhaust questions ; Rusted studs
Legacy777 replied to anaphe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNone of the bolts on the mid pipe with the second cat are integrated. They're just bolts. Cut 'em off, and just buy some stainless steel bolts and nuts at the hardward store.
Loyale Nightmeres??
moving to old gen side where this will probably have more response.
96 Outback Driving and Whining
Legacy777 replied to badjer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's probably the throw out bearing.
CEL OBD I Questions
Legacy777 replied to A_DuB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think you're reading the codes properly. It will repeat ALL the codes, not just the last or first one. D-check is a more "active" diagnostic mode. You must follow the instructions on my site and....yes you have to drive it around. The ECU will pull readings from the sensors to make sure they're operating properly. U-check just checks for previous codes in the ECU.
Legacy777 replied to anaphe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you talking about the front cat? it's in the header. So you'd have to replace the header. There is an intermidiate pipe from there to the mid pipe with the second cat. Which piece are you talking about?
AC Compressor
Legacy777 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhere ya go http://www.ultimatesubaru.org/forum/showthread.php?t=2442&page=1&pp=10&highlight=134a Like I said in the most recent post....I'd use PAG 100 oil instead of the esther 100 oil. Other then that, it should be good.
LegacyCentral Board Down???
Legacy777 replied to All_talk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhardware problem....it's back up.
4eat trouble help?
Legacy777 replied to camosuba's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like your tranny is dead. It's probably going to have to be rebuilt. You could drop the pan and see if there's any metal chunks in the pan.
Changing ECU's...
Legacy777 replied to tracer46's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat ECU did you try to use? I bet all the pins for the ECU weren't the same, and that's why it's not working. You need an ECU I/O diagram for your old ECU, and one from the new car to compare that the pins are the same or not. If they're not, you'll need to rewire them. Last ditch effort. Put a resistor in the EGR circuit to trick the ECU. You'll have to check some manuals to see what the resistance of the EGR valve is, so you can use the correct resistor.
A/C Help!!!
Legacy777 replied to swordsmanrex's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou really should have it professionally serviced. Unless you want to buy all the gauges and equipment to evacuate the system.
Impreza 2.5RS problems
Legacy777 replied to fishbone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhere's the scan from the factory manual on the test procedure. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/coilpacktest.jpg
help -93 legacy radio removal
Legacy777 replied to rwdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to pull out the ashtray, and there's two screws facing upwards. Remove those, and the trim piece will come out.
92 subaru AWD legacy binding
Legacy777 replied to gyuunuuya's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think you need any special tools to get at things in the rear housing.
Rear fender rust '90 Legacy wagon
Legacy777 replied to Zack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClean the molding out, put some grease or something in there, put it back on, and just clean it out every so often.
front differential
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDue to case differences and everything, you really need to check the backlash when you swap everything. BTW, Gary....great pics!
