8
Going to move this to the shop talk forum since it's more of a specific tool type question.
Gary, It really depends on what you are shooting for. If you're just looking for an alignment that will not cause you premature tire wear. For the most part, I'd agree that a little movement shouldn't hurt things. However, if you're looking for a "performance" type alignment, it does matter. If you've got one wheel that is out a 1/2 deg of camber from the other, it's going to change the handling dynamics of the car. It may or may not be a noticable difference. It depends too on how you drive the car. We may be splitting hairs here, but I've watched them do alignments on my cars, and have felt a difference from before to after.
Gary, What makes MWE's axles so good? I've seen some comments that they seem to be the "best", but haven't really looked into the details. I've used http://www.cvaxles.com in the past with good success, and they used to be the ones everyone seemed to plug....so just curious why the torch has passed to MWE. Thanks
There is an AT/MT identifier pin on the first gen legacies. Depending on the ECU, you either ground this pin or leave it empty to let the ECU know what type of transmission it's connected to. What year and model Legacy are you using for your donor swap?
Is it the same o-ring or always different o-rings? If it's different o-rings, I'd probably suggest replacing all the o-rings in the system. It's possible you had a bad set or something got in the system to contaminate them. If it's the same o-ring you may have an issue with the piping. I'd suggest they put some flourescent dye in the system so you can more easily find the leaks.
I sent you a PM. You can either email me the pictures of if you'd like you can donate some money to the board to get "donor" status and get those additional features to post a picture.
Thanks
Josh
Let us know how it works out for you. I was looking for a MIG welder last year, but decided to wait since I already had a fair amount of projects going on and didn't need something else to occupy mytime I'll probably look into one this summer again.
That "should" work. ELM is just what is used to convert OBD2 to the proper PC data formatting. I bought an ELM323 and from doing my research I found that some of the earlier OBD2 subarus didn't quite have all the data that the newer ones do. However I was able to get my 1997 Impreza to work, so I would think your 98 legacy should be alright.
