8
Huck, I'm looking to do the same thing for my 97 OBS. I've got everything but the vacuum lines & one of the actuator brackets. I should have them shortly. Everything you listed is pretty much all the cruise stuff....to my knowledge. I've attached the pdf that I got from someone else who got the full "add on" kit. It also has a wiring diagram, which may help. Let me know what you find out. I'll be likely doing this in a couple weeks. Josh 97 Impreza Cruise add-on.pdf
FLASHER Problem - DRIVING ME CRAZY!!!
Legacy777 replied to TheBush's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I know some of you have already replied, but I'm going to move this to the old gen forum since the body style is the older gen cars. -
Mods
Legacy777 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yeah, scoobymods has a lot of good info. I'm going to add this to the sticky. -
If the check engine light has come on at any point, it should store a code. Check the ECU for stored codes. The procedure can be found on my site along with the codes www.surrealmirage.com/subaru/engine.html Also, to get at the HVAC unit, you have to remove the black plastic surround trim. To get that out, you need to pull the vents, cruise/heater buttons, and the air susp. blank out to get at the screws behind them. You'll also need to loosen/remove the two bolts holding the steering column to the dash. That will lower the steering column enough so you can wiggle the black plastic piece out. Once that is out, you can get at the HVAC unit. The plugs are a little bit of a pain to get at, but once you get it out, you should be able to look at the solder joints for cracks. There's some pictures I posted in that thread on the bbs.
