30
Everything posted by Turbone
Yeah, Edrach has/had a set that he sent out and had polished up. They look very nice when they are shined up.
Bad coolant leak (And my screwup?)
Turbone replied to Keiji22's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Better to do it, that way you learn how. Sooner or later you will be doing it. Upgrade, bad turbo, etc. Get some PB Blaster and soak the nuts/bolts. Remove the oil line on top, then the hard water line on the side. Remove all the nuts holding the turbo to DP. Remove the nuts holding turbo to up-pipe. Theres a bracket that holds the turbo to the head, need to disconnect that. Then the whole thing should come out. The return line for the oil should just slide right off, but the water inlet will stay attached. This is where you need to use abusive language :-p It will have a double clamp on it too, so twice the fun! -
I'll see what I can find in the manual, but I've always removed the turbo to get to that line :-\ -
It sounds more like the supply or return coolant line for the turbo. The return line is between the turbo and head, and yes its a royal PITA to get to. Best way to check is to fill the system with water and let it run, then use a flashlight to find exactly wheres its coming from. -
It could also be a bad connection at the ign connection plug under the dash. Its a pink connector to the right of the steering column and under the dash cover. I've seen these have melted plugs before when the contacts are loose.
I've got a 1990 XT6!!!!!! (and- i'm a moron)
Turbone replied to audio_file's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wanna trade? -
Do I really have to list all the mods? I havent even been out since the snow melted :-\
caravan from seattle to Wcss #10
Turbone replied to sparkster58's topic in Meet n' Greet. Your USMB Welcome Center
Your bringing 5? Did you have to offer them money? I have this problem every year. I was going to bring 3 last year, but one person couldnt make it in time. I have one lined up to drive this year, but if I had more volunteers, I could bring more. Well, I could if the price of gas wasnt so friggin high -
I'll be leaving sometime on Fri, not sure what time yet. But it also depends on my "drivers" also. Or even if I'm bringing more than one car -
Happy B Day Backwoodsboy (aka Gritsboy)
Turbone replied to Bucky92's topic in Meet n' Greet. Your USMB Welcome Center
And.....ahem.......pulling things out were they werent meant to go :-p -
i am new to the site and i have some questions
Turbone replied to doubi2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Because fulltime 4wd rocks But only if its made to do that. I get 24mpg on the hiway in my RX.....as long as my foot stays light. -
need a little help, 89 XT turbo
Turbone replied to one eye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All the times that I have had a hot=no start problem, the coil was the culprit. -
Happy B-Day bud, get the most out of it -
Emily's Birthday BBQ & Open House Invite
Turbone replied to ccrinc's topic in Meet n' Greet. Your USMB Welcome Center
That would have been a bad thing :-p I want to see lots of pics. The more incriminating, the better -
Found a 83 DL wagon, couple questions.
Turbone replied to ErikAnderson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is this the one you were looking at? If so, the price has come down. http://seattle.craigslist.org/sno/car/725530130.html -
Well yes, I have been known to get it airborne on occasion
Heres a most recent pic of mine,
Remove engine (Its a 3cyl, you can pull it by yourself). Tear engine down. Replace bad parts with new. Put engine back in car. /
Sorry I didnt make it. I kind of over did it stripping out one of my SVX on Sat and just felt like a Rally X would have been a bad idea :-\
Another pull a part update
Turbone replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
As per a phone conversation with Ed earlier today, he is correct when saying its a FWD. He will be grabbing the rear disc's on his trip Thurs. Thanks Ed!
