30
Everything posted by Turbone
I think they are attached to the rear suspension, and about 4in square. They are supposed to protect the rear axle inner DOJ. And sorry, no. I'm not crawling under my car to measure it. Rob
If you did the XT6 suspension swap you would have a greater choice of wheels and tires. Rob
I think I read here sometime back of someone useing an ABS rain gutter downspout, the square type. Take some measurements first. Rob
Hey Jaim, glad to see you back in the saddle again. Well, as soon as you get it running:D Good luck, you've done it before. Rob
The person was Rguyver. I thought his setup was Turbo on a NA block? Rob
Check the bolts that attach the carb to the manifold. Also check the filler tube to the tank, they sometimes develop cracks. Rob
how do you define an addiction?
Turbone replied to elcaminokurt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
15, if you count the parts cars. Have 5 in the driveway right now. I might have forgotten a few:rolleyes: Rob -
Check the voltage output at the Alt, and then check it at the battery. If its 12v +, and less at the battery, then the VR is toast. If its less than 12v from the Alt, then its toast. Rob
Is it a 2 piece driveline? Rob
Welcome to the board. Indeed you do have a rare 83. Most 83/84 4wd's with AT were Turbo models. It sounds like you have a vacume leak somewhere. Listen for a whistle, but if you cant hear one, get a can of brake cleaner and spray (lightly) around the vacume lines. If theres a change in rpm's, you have a leak. The autos also have had issues with the vacume modulator. A line runs from the intake manifold to the passenger side of the trannie. Make sure this line isnt leaking also. Rob
When was the last time you changed the oil? And what grade are you using? It might help if you used a 10-W40 for colder temps, maybe even 10-W30. If you re-seal the oil pump, go with OEM parts. Rob
Ouch - looks like the head needs to come off!!
Turbone replied to RedRX's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Turbo pistons are flat for low compression. Rob -
Where did you buy the plugs at? It really makes a diff, the superstores end up with old stock and not the best of the batch. Thats why they can sell them so cheap. Buy your plugs from an auto store. You are the first one I have ever heard of having probs with NGK. Rob
Sparks? From what area of the trany were they coming from? Sounds like something came loose and bound up. But sparks do not sound good, you may be looking for replacements Rob
Are you using the designer (for lack of a better word) silicone? Thats not designed for water or fuel. I can imagine it could crack in freezing weather, its pretty cheap stuff. Rob
What, it took you 3 months to find it? Rob
Give us an update after you get them off. Rob -
thought I had it fixed(cooling related)
Turbone replied to 88xt6joe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I suggest putting in a new waterpump, not terribly expensive, and it sounds almost like the problem I had. Rob -
I have started replacing any old water lines with silicone. They will last longer than the car (hopefully). The only place I could find it was at...........you guessed it, Napa. Rob
Help me figure out this Odd Cooling Issue
Turbone replied to syphon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, I got the waterpump installed in mine and it cured the heating spike that I was experiancing. I hope your radiator fixes yours. Rob -
911 Help for Jarod in L.A. area......
Turbone replied to mudrat79's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sound like he's in the Bakersfield area. Its pretty empty around there, hope someone from the LAX area can help. Rob -
Well, here in the NW, its been snowing off and on for over a week. And today was the worst. It snowed a couple more inches(more in some places) and then started in with freezing rain. All the roads are ice rinks, and luckily most people decided to stay home today, including me. Rob
I'm having the same issue with my 86 turbo wagon. It will actually go to the red and hold it for a minute (with me holding my sphinkter tight), and then it will drop to normal op temp. I replaced the thermostat with no effect. Granted, its not OEM. I also had the anti-freeze smell and some leakage, and after some time and alot of looking, I found the source of the leak. It was/is the waterpump. The car has 126K, and I really didnt suspect it. But once I removed it and looked at it, it was really rusted. The car is waiting for warmer temps to install the WP, I removed it when the first storm hit, brrrrrr. Considering the mileage of your car, and the smell of anti-freeze, this could be your problem too. This unfortunatly is not a quick fix:( I have to remove the A/C, Alt, crank pulley and the timing belt covers, and both fans. Rob -
Ever seen this wheel before?
Turbone replied to soobme's topic in Old Gen.: 80's GL/DL/XT/Loyales...
They look similiar, but they arent the same. Rob
