Everything posted by Turbone
Need to borrow a spider intake...
I have one, but everything is still attached. Let me know when you need it, I may be in the Renton area Sat. Rob
old school wagon help
GD, are you saying I need constant attention? All I seem to get is constant BS:lol: Rob
EA81T engine dies
If you havent done it yet, I suggest checking the timing. It could be the cause of the knocking and other problems also. Skip, you are partially right about the connectors. The "check connector" is black, but the "test mode connector" is green. Rob
my ride "Interior Shots"
Yay, I finally get to see it! It looks good too. Cant mistake it for anything but a Turbo, eh? Rob
$#@%!$$@# window seal...
Go to your local hardware store and get some window weather stripping. They have different sizes, lots of selections if the store is a big one. Expirement with that, its cheap. Rob
How'd the HP's Xmas tree run go? (new photos last post)
Theres plenty left to go around. Oh, and the incident with the hood pins. Uh, lets just say that while having an electrical/no start issue up above, in my haste I for got to put the pins back in:banghead: Glad I had a X-Mas tree on top, might have broken the W/S. Stupid hood. Stupid Rob:rolleyes: If anyone has a spare hood lying around, let me know? Rob
Anybody have a '86 service manual?
Sorry bout that, missed this post. Theres alot of differences in weight between the models and options. This is for the 5spd D/R - 1,143lbs. Rob
EA81T engine dies
Ditto on the sensor. You need to find the green connector under the dash, left side, one wire. Once this is connected, you will be able to read the codes. Rob
87 GL cooling system bugs
The problem is almost similiar to mine(86 GL-10 TUrbo). I just put a new thermostat in cause of a wierd heating issue. The temp would go up to the red for a couple of minutes, then drop down to normal. I also changed out the temp sending unit. Its still doing it, along with a loss of coolant(you can smell it after driving). I have replaced most of the hoses on top with silicone, but havent changed the return for the turbo. Theres no change in the way it runs, and doesnt act at all like its overheating:cornfuzz: I guess I'm going to have to crawl underneath and have a look at the water return hose:-\ Rob
All info is from the 86 FSM. The 4wd stats are for the RX Turbo. Front 2wd - Expansion,176lb/Comp,110lb 4wd - Expansion,309lb/Comp,265lb Rear 2wd - Expansion,176/Comp,110lb 4wd - Expansion,309lb/Comp,221lb Rob
Front - GL-10 Sedan 2wd is 134lb per in. 4wd is 157lb per in. Rear - GL-10 Sedan 2wd is 159.6lb per in. 4wd is 159.6lb per in. Rob
EA-81, the way it should be
And why leave the a/c stuff on? You can pull the EGR off and put a plate on it . Looks nice tho, are you able to close the hood with that aircleaner on? Rob Side note, just remembered this is a Cali car:-\
Tell me about the spider
Hey Tex, have you thought of drilling and tapping the housing? There is an extension there with a flat spot just for the plumbing (I just looked at mine). Want to help me do the install of mine when I get the 88? Rob
!HELP! wagon died on me. pretty nasty. very concerned
I would. You either blew headgasket(s) or cracked the head(s). Rob
Aussie Hatch Questions
The headlight switch sounds like the same as the ones on our 1985 and newer Soobs. By pushing in and turning it, with the key off, you have parking lights. As far as I know, there have never been any factory rear fog lights installed on US Soobs. It sounds like the wire to the fog lights might be making ground somewhere and blowing the fuse when turned on. The fog light might be part of the parking light circuit, or else making contact when it shouldnt. The plugs in the engine bay are probably for testing a certain circuit. I dont know what circuits tho offhand. Hope this helps. I've seen pics of your hatch, did you get the rear lights finished? Rob
question <could not think of a good subject line>
As I stated in my first post:banghead: Go to NAPA. They sell it by the foot, in different diameters. And its not the blue crap, its orange/brown in color. I know its not perty, but it works. Rob
If you have never done this, your in for a PITA. Call Napa and get a price on silicone hose. If its going to be done do all the turbo water lines. You may have to (most likeyl) lift the intake to replace them, so that means you will also need the gaskets for that. Do hope you have a manual? Rob
? driving fast/looks
You do know that when you put oversize tires on, that it changes the speedo reading? Rob
HELP, New to Sub's...random engine shutdown
Another point I just thought about, and which happened to me also, seeing how they replaced the head gaskets, some electrical connections might have been moved/disconnected. Check all the major elec connectors in the engine bay. Rob
It could be the electronic module in the distributor. It happened with my 84 turbo wagon, and a few other cars that I know of. Someone in the marketplace might have a spare, or you can look in a local PAP. I think theres a couple in Oly. Rob
FAILED Emissions!
From Caleb on the 16th - The reason people are down on you is because you didnt follow directions. You asked for help and the ones that have gone thru the emissions BS told you what was needed. The ones that passed without touching the engines were very lucky. Personally, I think you should sell the car, the EA81T is to complicated . Rob
What is a fair asking price???
Put a new thermostat in it. That will help. All Soobs mark their territory, just some mark it more than others. It could need a reseal on the oil pump and cam seals. Rob
84 Subaru 4WD Turbowagon
I believe these wheels only came on 84 Turbo's and GL-10 models. Rob
"Lola" needs your help please
The fuse for the fan is not even close to it. Its an in-line white plastic covered fuse to the left of the steering column under the dash. Rob
electrical problem.. not enough to go around?
Definately check your grounds, especially the one from the battery to engine. Rob
