Wheel lug nuts coming loose
1 Lucky Texan replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif the car has replacement...; lug studs, lug nuts or wheels - there's the possibility the nuts are 'bottoming out' before proper clamping force is achieved. I'd consider having her stop by a Discount Tire and have them inspect everything.
2010 Outback Making Popping sound Please Help
1 Lucky Texan replied to Cason's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen warmed-up, will the car buck/jerk in tight circles on dry pavement? OK turning sharp when stone cold, popping or binding/jerking in sharp turns when warmed-up is 99% gonna be the transmission's center differential. mismatched tires, very odd carrier bearing, wheel bearing or u-joint failure should be ruled-out but, sounds like the trans.
2006 STI has seemingly random dash lights turning on.
1 Lucky Texan replied to buffington's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa month or so might also be time for a poorly tightened wire to vibrate loose...double check alt and battery connections.
2012 Legacy Steering Wheel/tires vibration
1 Lucky Texan replied to osmonxp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvideo not seen look inside the reservoir for bubbles - you may have air being sucked-in. very common problem
1 Lucky Texan replied to buffington's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXabs is very sensitive to voltage - I agree with starting with the alternator.
Intermittent loss of power
could be knock sensor - cheap/easy to swap sometimes a failing cat conv will clog the exhaust
99 impreza power loss
1 Lucky Texan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany chance of wiring damage from rodents or pinched by some work that was done?
Mystery Misfire on EZ30 Cyls 1 3 5 Noticed on Idle
any indication the timing system had been opened-up before?
Hesitaion when flooring the pedal. No uphill for me
1 Lucky Texan replied to gravitate's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpull the covers and check cam timing.
1 Lucky Texan replied to gravitate's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbad knock sensor could be pulling ignition advance ?
Can I replace JUST the timing belt
ferret - I'd be interested in your experience with the GMB parts - kinda worried about them on my WRX.
Mouse in the house er Forester roof
1 Lucky Texan replied to winelegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat about bees in your intercooler? "Uh no sir, I assure you it isn't the heat shields buzzing."
- 2004 OBW Code 1443
98' Legacy Outback hot start issue
1 Lucky Texan replied to GorgeSuby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcoupla things to try, when you feel it will fail, or immediately after a failure - hold the gas pedal to the floor while starting. Don't pump it or lift until after it starts. that is the 'clear flood' condition for the ECU. if you think it's fuel startved, try spraying some starter fluid in the intake. also, some older soobs have had crank position sensors fail when hot.
2014 Forester Tire Options
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you ask at the Forester forum and over at subaruoutback.org , maybe someone has tried them, but, as you say, they seem new-ish. looks like there's a $70 rebate on any set of Continentals right now.
Starting issues
any oil on the plug wire boots? any differences in the weather conditions when it starts vs when it doesn't ? have you tried starting it with etherstart/starting fluid? could it be flooded now? are the plugs wet with fuel? (if so, hold the gas pedal to the floor and crank , that's the ECU's 'clear flood' procedure) is the IACV hose disconnected from under the intake tubing?
- Starting issues
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX18 reviews at TireRack - all but one seem positive after quick glance. I THINK 2 subarus were wearing them.
DRLs Turn off once alternator is plugged in (3pin)
1 Lucky Texan replied to Mofo223's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmany parts stores can test alternators/charging circuits. consider a used Subaru alternator from a junkyard - many rebuilts have a poor reputation. Or, locate a local rebuilder and have yours rebuilt.
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's cool, I could have waited longer before posting but his original post went several hours with no response at all, not common here. likely not agressive enough for regular off/soft road use, but the Pirelli Cinturato P7s on our OBW are great - helped get us home from CoSpgs in winter storm 'Ursa' , we were the pilot car leading almost a dozen others off a closed road between Capulin and Clayton NM. hope others reply
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnvrmd
1999 Legacy Outback 2.5 Automatic
1 Lucky Texan replied to Rwalen2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe you cracked the pump in the trans when you re-installed the engine? it happens frequently.
1998 Forester, engine knocking.
1 Lucky Texan replied to My64bit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlock-unlock with the fob a coupla times. or, cycle the ignition on/off 3 times quickly
A/C o-rings dimensions anybody?
1 Lucky Texan replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere may be part numbers or dimensions in this thread;http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/43428-diy-c-air-conditioning-leak-refrigerant-repair-5-less-15-minutes-less.html
1 Lucky Texan replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, I just eyeballed it, 1.8 or 2mm thick i think. Some size that required the minimal amount of stretching without being 'saggy' . so far so good. try to get some oil on your little finger to wipe on the new ring and gently wiggle/twist as you insert the hose adapter.
