August 19, 201015 yr cool i thought this was just for old school... LED'ed my whole dash and was going to do the ECTS but the USPS I guess was too lazy to deliver today... I did buy a new radiator cap since i think the one I have on the car is near about as old as the car.. but new radiator.
August 19, 201015 yr I washed both of mine The justy is almost ready to be fired up and touch the ground. I will make an extensive post for that soon.
August 19, 201015 yr put seats from a '92 Ford Escort GT into Mountain Grizzly... they match really well too with the gl-10 door panels!
August 19, 201015 yr Cup Holder!! Hard to find these (i think company went out of business), but luckily cheaper now (still too spendy honeslty). But dammit i want someplace to set my coffee! On a side note - this is w/ a full "skinny" 24oz water bottle that made it a bit tipsy. A regular cup/can of soda, or even 24'ish oz cup from drive through fit much more securely. Necessary - no. but nice to have! rob
August 20, 201015 yr New deck: Upgraded to mirror sun visors: and add some yakima ski racks.....can't wait for snowboarding!!!! -Nomad
August 20, 201015 yr My newly aquired XT6 has just had an oil change to Royal Purple synthetic and Valvoline synthetic trans and diff fluid. Today its new rotors, pads,water pump by pass hose and outer cv boot kits.
August 20, 201015 yr Nice work on the XT6, above. Today I lapped the valves and put permatorques on my ea82
August 20, 201015 yr That engine looks nice all cleaned up. Best time to do it too. I put a Midland 1001z CB in my Legacy - Need to buy a nice Fiberglass entenna!
August 20, 201015 yr Nice work on the XT6, above. Today I lapped the valves and put permatorques on my ea82 Sweet! nothing nicer than assembling an immaculate engine:grin:
August 21, 201015 yr did a 2 inch suspension lift on the front with some redneck custom strut extenstions it turned out pretty good. camber isnt as bad as i figured on it being changed a lower ball joint too... which was completly fried. id swear there was at least an 1/8 inch of play. the one pic with extension next to shock was cut shorter obviously but everthing fit nice and tight.
August 21, 201015 yr It's been an interesting summer... Had an electrical failure; replaced starter and then ignition switch, then the battery. I was going it with a shotgun mentality but with 200k, I figured anything I replace is gonna be an upgrade. Then in the heat of July developed a fuel delivery problem. A jy fuel pump unit complete ($5!!! ) fixed it right up. In early August the alternator died but that story was more about the $160 cost than the 20 minutes it took to swap it out.
August 21, 201015 yr just replaced the tired forester assemblies with less tired forester struts and king springs. probably sits up .25-.5" more due to the HD springs. King Me, ha. rears old/new comparison
August 22, 201015 yr Finally changed the front axles. Sounds good without the clunking. Clayed and waxed the car, Tuned the MSII a bit more, still has a way to go but it can rip tire in first kinda, and trying to figure out the water to air intercooling setup for it. OH you wanted pics? Sorry, dont have time. Maybe later though.
August 22, 201015 yr new pads all the way around on the 89, and i looked at the 86 set my ej22 computer in the glove box and walked away, lol i think that thing will be sitting there till it gets a little cooler outside
August 22, 201015 yr finished tieing down my wires and added a backup camera for my carputer! works great, and looks stock! -Justin
August 22, 201015 yr I noticed that I've never seen my radiator fan working. I bought some relay's, one to turn on a light when the coolant temp sens. turns on the fan, and one to bypass that circuit for a manual override. Made a mistake on my diagram, the thermal switch gets its power from the factory harness, not this circuit. 5-way relay, 4-way relay, left over connector from my bumper job, blue lighted switch, green indicator light. Did some testing, found out that the factory harness ground for the fan is shot, so I ran a fresh ground and used a butt connector to tie off the factory ground. Still a little messy, but I have the 4-way relay hooked up for the indicator light, and spliced the power-in so the fan can be fed by the factory or override circuit. Here's a shot of the 5 way circuit sitting in the place where my stereo is supposed to be (stolen before I bought the car). The main power feed is drawn from the cigarette lighter, which is switched and fuse protected, the two output circuits from the relay are also fuse protected. Note: when the fan turns on via the coolant temp switch, it still draws from the factory harness, I just ditched that connectors harness ground. This is the switch and indicator light installed. I'll go back in a paycheck or two and shorten the wires, clean up the mess a bit, probably throw in some black looms to keep them out of the way of other circuits.
August 23, 201015 yr Ahaha, Amen to that sticker. Im trying to get stock out of mine right now. Its fighting me.
August 23, 201015 yr Cup holder battle 1.99 each at Fred Myere. Tow screw mount, easy fast and works.
August 23, 201015 yr Some Totally wasted guy hit my parked car with his 2007 F-150 and also hit a '91 Celica. Needless to say he is now in jail. And his Insurance WILL pay.
