87
Everything posted by DaveT
I had a 5 speed where the clutch fork cracked and bent in a way that made it look ok from the outside, but it couldn't move the throw out bearing far enough to disengage the clutch.
loyale h4 wiring harness upgrade problems
DaveT replied to Subinoobi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There are relays that have polarity sensitive coils. -
92 Loyale Battled a Camry :(
DaveT replied to pheebs314's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've not seen the fan / lack of fan cause overheat. More than just a few bubbles of air in the cooling system will cause overheat. And in my experience, this means head gasket replacement. Sometimes very soon, sometimes in months. You might be able to limp it along for a bit by modding the radiator cap so the system cannot pressurize. A small piece of solid copper wire wrapped around the little valve in the cap does that. As long as you are not in desert temperatures, it should be ok. I've run them that way for quite a while without trouble. What it does is make whatever leak you have loose less coolant per minute, so enough may stay in to drive the car without overheating it. I managed to drive one of mine with a cracked head for months this way, while I rebuilt another engine for it. Eventually, the crack got bad enough so a bottle of water would drip through the crack while sitting in the parking lot in about 6 hours. I just had to add water all the time. -
I understand, not having an EJ. You wouldn't need 4. Only 1 working one for what I suggested. Plus the harness & computer for the EJ, which, yes, would be stuff you have to find / buy. It depends on the end point of the project. If you want to make a 1 off custom, with stuff you have, I get that. If you want a big power increase, EJ. Both are big projects time wise. For experimental FI projects, look at Megasquirt. Open source FI engine control system.
From what I have read from MANY past threads about modding these engines for performance, the bottle neck is the intake port and size and lift of the valves. The best way to get a significant power increase is to adapt an EJ engine into the car. Similar amount of work, and something like 40% power boost, with all of the reliability of the EJ engine.
This may depend on the transmission you have. For a 3AT, if the seal/s between the Trans and differential fail, the atf will end up in the diff.
Getting ready to remove the transmission. The cart carries the 3AT as low to the ground as possible. With the car up on the solid concrete blocks, it can be rolled out from underneath.
Yes, check that power is supplied to the coil, as above. Other hints: Easy test for no fuel - 1 to 2 seconds of carb cleaner down the throat. Hold gas pedal down about half way. Crank. If it has spark, it will fire for a few seconds, or a burst. If it's very flooded, it may take a try or 2. Check for spark - take the wire from the center of the disty, [other end is connected to the coil] and arrange a spark gap with whatever piece of wire, etc. so you can see it while cranking. About 1/16" gap. You should see a healthy spark.
Loyale waggon fuel pump? bad gas?
DaveT replied to kablamabam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nothing specific, but a few things I've dealt with that may be related. Nothing to loose replacing the filter. Check for water in the fuel line. I had an idle solenoid fail once. The engine would not idle. I had to hold the gas pedal down slightly to keep the car running until I got home. My 87 has an intermittent glitch that occasionally alters the idle speed, raising it occasionally. Have not been able to find the cause yet, as it is too infrequent. Once in a while, every one of my GLs / Loyales has glitched on start up - fired and died. Then cranking and cranking but no fire. Holding the gas full down while cranking clears the problem. Instead of pumping, try holding the gas part way down, and see what happens. Also try fully down. I use only 87 octane gas now. Back when they put MTBE in the gas, I had to use 93 to reduce pinging. As soon as they switched to ethanol, that went away. I also ran very stale gas for a while, and was surprised that it had little effect, until I got to the extremely stale gas. That I had to mix 50 / 50 with fresh. During this experiment is when I discovered the effect of water in the fuel. Loose power, run crummy. -
I'd put the intake on and try it. It's not that much work. Redoing the head gaskets is a lot more than that, IF they are ok, you loose a lot more time / money than if it turns out they are bad. If you use the OEM intake gaskets, they may even survive and be re usable if you determine the head gaskets are bad fairly quickly.
- 14 replies
- EA81
- Head Gasket
(and 1 more)
Tagged with:
So I drilled out my hubs for 6 lug conversion...
DaveT replied to ragingbull's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mscdirect.com or mcmaster.com. Order a centering drill bit. And a split point cobalt bit for the final size. -
I can't say 100% for sure, but they look identical.
When I get one of these problems, I usually try a good second or 2 of carb cleaner in the carb, or throttle body, then crank. If it runs for a second or 2, it rules out a lot!
I'll have to check the FSM to get the exact range, but 0 to slightly toe in is what songs good.
Assuming that the alignment is in spec, I've had a shimmy that fades in and out. Slightly bent rims could do it. Slightly off balance on both front tires could do it. When I used to run the white wagon wheels, I had to go to a Subaru dealer for balancing. They were the only place that could get it right. If the shimmy amplitude goes down as speed drops, it has to be weight related. If it only drops in frequency, it is tire shape or a bubble of delaminated tread.
Oh, another little mod I do to make starter service easier. Remove the clamp that holds the cables to the steel tube that helps support the spare tire. Then strip off the tape and stuff that holds the + and - cables together. Been running them that way since around 1988 with no ill effects.
EA82 O2 sensor renewal ...no easy access :(
DaveT replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I haven't had an exhaust system with heat shields in a loooong time. Although, the 93 I just got from a guy in CA still has OEM. But I expect that O2 sensor will not come out easily. I'll probably put the all stainless exhaust I made on it when that sensor or the cat fails. It'll be easier. -
17mm combination wrench for bottom nut. 14mm for the top one. Sometimes need a second one to hold the bolt.
For the AC - remove the alternator. Then remove the bolts that hold the cast iron bracket to the engine. The hoses are just long enough to allow you to flip the compressor back upside down. One 14mm behind compressor, 1 12mm under alternator, 2 14mm below the compressor. The left one just loosen, the right, remove.
Thank you! I have yet to disassemble the motor part of a Subaru starter. It may be the brushes hanging up on the comutator. Or something like that. I have disassembled the solenoid section many times to replace one of the copper contacts. That is an off car project.
I never had that part apart with one on the car..
