Everything posted by subiemech85
wher and how to replace the input shaft.
subiemech85 replied to Gl-boost's topic in Old Gen.: 80's GL/DL/XT/Loyales...
input shaft is connected to torque converter which is bolted to flexplate shift selector rod is what u are asking about y did not want to work for ^ -
either red book for gen 2 or brown book for gen 3
Problem with 1989 EA82T MPFI Turbo
subiemech85 replied to stickedy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this issue has been covered and would have been found by SEARCH http://www.ultimatesubaru.org/forum/showthread.php?t=48380&highlight=knock+sensor -
Solved - Idle with AC on too high
subiemech85 replied to suburpy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there may be a vac. operated device that pulls a lever on the carb to increase engine speed -
1982 GL Wagon timing belt or chain?
subiemech85 replied to unibrook's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cam position -
Being offered 2 free Subies
subiemech85 replied to Subieguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if you're complaning about GAS mileage , think of FUEL economy of a small EFFICIENT DIESEL 16 or 20 mpg in rx vs. 45 mpg in vw pickup if you need more encouragement to get the subarus, just think that you could be the horse of -
'89 Justy trouble reading ECU codes
subiemech85 replied to IdahoJak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
with both test mode and read memory connectors connected, idle speed should be set to 800 +/- 50 with test mode connectors connected, ignition timing should be set to 5 degrees +/- 2 degrees below 1000 rpm "NEXT TIME ASK TO SEE THE D-CKECK REFERENCE BOOKLET" I have one and have been using it for all info provided got ? ask! -
the vw pickup is still made in south africa AFAIK and hauls, bigger box than a ranger http://vwcaddyforum.com/index.php? http://www.vwcaddyforum.com/pictures/caddyeng11.jpg
you can also get to them with needle nose vise grips
the connecors are between the hood release cable and the ecm towards the fender side of the clutch pedal the read memory connector has a LgW wire in pin 21 of the 22 pin harness the test mode connector has a GW wire in pin 22 of the 22 pin harness -
so why don't it work??? Update page 4
subiemech85 replied to Buddy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ate your wires or it could be subaru's common ground system -
Checked for codes, need to translte
subiemech85 replied to dave valiant's topic in Old Gen.: 80's GL/DL/XT/Loyales...
MT, Cal and Canada SPFI -
who makes the 5speed swap crosmemeberS
subiemech85 replied to tailgatewagon's topic in Subaru Retrofitting
I'm confused! since when does the crossmembers need to be changed if going from ea81 d/r to ea82 d/r -
Victory is mine!!! Can you guess the problem?
subiemech85 replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
reminds me of the time the fuel shutoff solenoid wire came loose trying to accelerate, cuts out, push in clutch, put go pedal down engine catches, rev up let up on clutch, good to go and it was my diesel! -
SPFI or MPFI????? IF SPFI, wires # 19 power (output) 20 signal (reference) 21 signal (position) code 11 = crank angle sensor (No reference pulse) IF MPFI, wires # 7 (power) 8 (reference)
seems like there are several posts that mention the coolant lines should be re-routed but that is it where should they be re-routed? here's my guess: turbo out to heater core in trubo in to heater core out BTW: pex t fittings work great as adapters, etx. I recently installed a fuel heater in the vw tapping into the heater core circuit
ea82 and ea81 drive shafts - are they the same
subiemech85 replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and I thought you were talking about the ea82 2 piece driveshaft front driveshaft varies rear dirveshaft constant is there going to be a trans swap? -
High pitched whistle varies with rpm?
subiemech85 replied to mbrickell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
vac. leak BTDT: I had a BIG vac. leak, idle adjust screw came out your leak may be smaller or it could be an exhaust leak -
EGR; replace, block, plug or leave alone?
subiemech85 replied to dreedraffs's topic in Old Gen.: 80's GL/DL/XT/Loyales...
use the gasket as a template for when you make the block off plate I used a piece of mower blade engine should be able to run without anything covering the hole gives it a different sound, low power, major vac. leak -
Weird Thermostat Replacement Issue
subiemech85 replied to Mantonite's topic in Old Gen.: 80's GL/DL/XT/Loyales...
which kind of glycol? ethylene or propylene don't drink drinkable I have had good luck with NAPA superstat thermostats and gaskets -
auto tranny alternative
subiemech85 replied to skybren's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if none of those would work, you could go hydro or ecvt my favorite is a 5spd!
