Everything posted by subiemech85
Somebody left the gate open.......
where at? I wanna go!
what paint matches valve covers?
thinking it was more of a robin's egg blue, not hunter green is the air cleaner the same color of valve covers?
what brand and color do I need to match the color of 84 ea81 valve covers?
Off to Bolivia!
flush the toilet, and see which way the water goes away!
ea81: replace ? when engine is out
I still don't understand what you mean!
I'm driving a Brat
share the love
for what?
am i screwed? obsolete parts!!!
and I make a "shopping list" so the kids don't have to bother looking anything up, just makes life that much simpler
Can I do it? Should I try?
any decent jy will have a way to lift the car and move it!
Loyale: ignition wants to keep my key
I like jb quick, check wires, may be cut
Water pump replacement.
5 bolts, 1 longer than the others goes near the top, and 2 hoses replaced mine because water poured out where the seal was supposed to be
try these people: http://www.arrowweb.com/bake/ it looks like they have EVERYTHING
I "steam cleaned" all grease on the engine and engine bay, and hot water flushed the cooling system I think it's time to replace the oil pump seals, as there was a line of oil on the oil filter changed the water pump, spark plugs, and valve cover gaskets, and adjusted valves when it was in I have the cleanest truck in my area driveshaft and transmission comes out friday, and rebuild the engine and transmission mounts this weekend
what should be replaced when the engine is out? besides the transmission
Had an interesting thought while looking through a Catalog
about $900, and is mulitple volume
fuel tank question
it will, if you use your imagination, or use an auto parts store website to see if they use the same #
Midwest Offroading: Pick a Date and Place! (Roy's was Closed)
ledges state park in IOWA is nice, but nothing to do there's also abandonded railbed, but not exciting or you could play in river bottom, but there is no end to sinking so, is there anything worthwile in South Dakota?, Minnesota?, Wisconsin? Last weekend in August sounds good
Help me empty an EA81 fuel tank
you can pump it out, as far as where to disconnect the line, that is up to you, after the pump,or before the carb
Attention Grease heads - Need grease advise.
ask delo, they should know http://www.chevrontexacodelo.com/en/products/grease/default.asp you may want to try john deere corn head grease
alt. for the brake tool?
the cube is the way to go, and as a bonus, you can use an impact wrench to speed up the process
which clutch disk do I need?
is a TURBO disk better than a carb disk?
going from 84 brat ea81 dr trans to 85 wagon dr trans, need to know which clutch disk to use with the ea81 flywheel and pressure plate Is there a benefit of using the ea82 turbo clutch disk?
lost brat trim
I only jacked you to $20 they have been going high lately
LSD conversion..How do?
read the OLD repair manual
85 ea82 wagon to 84 brat radio swap?
what's the 5 pin bnc connector for on the radio? bump
