Everything posted by subiemech85
Vac Line Running into Filter
subiemech85 replied to BobBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i'll have to check the 83 wagon if it just goes from the filterbox to nothing componetwise, you do not need to plug it if it goes to the outside of the filtered area, but if it connects inside of the filtered area, it SHOULD go some where, depending on what it is -
it's a matter of where both ends go -
does anyone know what this might be??
subiemech85 replied to mickytrus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
read this topic, as all answers have been provided already -
So who would build the NEXT trashwagon?
subiemech85 replied to MilesFox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have the trashwagon7, and it is for real found it miles, cunxttime -
Road Trip II: TrashWagon's RETURN
subiemech85 replied to MilesFox's topic in Meet n' Greet. Your USMB Welcome Center
MADE IT HOME with one problem, MOM was waiting in the doorway, telling me I should have been home 2 hours ago, told her i'm sorry...... I love that cruise control shower has been fixed it was a great time hang'n out at eyesore, free food, deebo I am the proud owner of trashwagon7, REBO -
just hang'n out at eyesore, good day -
how much for the rims? why not take the brat? seriously: madrid body shop, but may not be worth fixing:-\
there has been extensive coverage on this topic, I started a long thread "gm alternator conversion" search for gm, alternator, conversion, cadillac, washers turn alt upside down and use washers and a longer belt, all in the instructions
everything's a go on my end:banana: :wave: -
anaerobic works without air permatex at autoparts stores, $3 for the small tube http://www.permatex.com/results.asp search for anaerobic -
Old Advertisement on T-shirt
subiemech85 replied to Hogsubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
more to come, only one for now WARNING link may be offensive http://www.westcoastvintage.com/tshirts/asiantshirts.html -
85 gl wagon problems(long)
subiemech85 replied to iluvdrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it is a vac reservoir, front line to controller, back line to intake manifold -
2005 Calendars for sale, 23 left!
subiemech85 replied to Subafly's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my check cleared a week ago, lucky I had enough to cover it -
" why dont you remove the cannister?" found the cansiter in reference that you DO NOT remove that is the one in the pic remove the EMISSIONS canister -
now changing a bulb, then back on the road going to crash at eyesore, 4:30 am ish I will meet up with the gang around 5:30 pm ish, bringing beer, tools, $ camera, questions, and tw7ip :banana: :banana: :banana: -
they are going throug sioux falls sd, with a broken exhaust pipe, noise and ambulances going by. -
100+ when cold, 35-, and 15w40 20 at idle, 750rpm 40's all other times
Help, wifes car died...
subiemech85 replied to tregare's topic in Old Gen.: 80's GL/DL/XT/Loyales...
look here: http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29dd8b7a4f46.89471656/&FileType=Image&File=New%20Image.JPG -
just keep your old coil waranty that coil you buy, there are "lifetime" stock ones available a new "cheap" coil is about $10 last time I looked
Front wheels locked up!
subiemech85 replied to TomInOR2002's topic in Old Gen.: 80's GL/DL/XT/Loyales...
send that trans my way if the front dif locks and is dual range:D IIRC the hill holder works on the front left and the right rear -
"the cap and rotor seem to be the right ones, and with a timing light I verified that I'm getting spark through all of the plug wires." waht happened to that timing light? is a sensor disconnected or something mis-adjusted I'm just a carb guy -
question quality of parts CHAMPION is crap, use NGK fuel? sensors? timing?
