30
Everything posted by MilesFox
So you hook your car up with all these goodies and give up over a bad wire? I guess that means the weber and 4spd are useless with a bad alternator wire. The wire leads to the fulsible link panel under the hood. Just run a new wire and be done. Why give up at the last possible thing to go wrong? Everything else is new or serviced, right? At least you didn't crash it.
I had my 88 DL and suggested there were plugs for rear speakers behind the b-pillar. Turns out i was wrong, as the DL is a stripped-down, schematically simpler version of a GL harness. The loyale, however, has a full GL harness, and some accessories were deleted for the Loyale trim level, but the harness would still acommodate any available options in various packages. A loyale will have circuits for: power mirror power window rear door speakers map light
EA82 and ER27 compression differences
MilesFox replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sweet!. We should make a sticky, or post this in the USRM -
EA82 Re-assembly Questions:
MilesFox replied to Deener's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You should not have to use RTV on the valve cover grommets if you have new ones. The bolts are shouldered, that they will snug down metal to metal before squishing out the rubber grommets. Tighten to snug and you are good. MAke sure to use a pick or razor to remove all the old sealent fromt he groove on the bottom of the cam tower. Use the ultra grey, or some anearobic (hondabond, etc), but do not use regular blue or black rtv. You can use a dab to hold the o-ring in place. The o-ring is important, as that can be potential for a major oil leak/pressure loss It is not necessary to apply ultra grey to the head side, just the carrier side. Fit the parts together and install the bolts hand tight. Let it set up, and then torque in a radial pattern, starting from the middle and working out. -
Look behind the driver side of the center console under the dash. There is a rubber fitting that contains nylon vac lines form the firewall, and it plugs into the door actuator next to the heat adjust cable. See if it has been knocked loose. You may have to drop the kick panel to get a good look at it.
Correct me if i am wrong, but i believe the ea82 mpfi non turbo engine has a 9.5 compression, also -
EA 71 Steam in crank case
MilesFox replied to flatfour73's topic in Historic Subaru Forum: 50's thru 70's
There is an o-ring between the block halves on the top of the engine. MAybe this could be your problem? It is one way to introduce coolant to the crankcase. This is just an idea. pressure check can help prove or disprove this. Put your ear to the fill tube while the system is pressurized, and listen for steam. You could run the car to operating temperature, and then turn it off to do this. -
Maybe the water pump is losing efficiency. I helped 'TheLoyale' (Tom) find a 500 dollar legact in the alley in my neighborhood, and tried to add coolant. The seller said the water pump leaked. We tried for over an hour to bleed the air out of it, and after we think it was full, it would get warm, thinking the thermostat would open and the rad would get warrm. The rad stayed cool for the most part, while the upper hose was hot. The next day, we drove it the 5 blocks back to my place. The water pump seized and took out the timing belt. We put on a used pump and belt, and tom drove it home that day. How many miles on this car?
So i was going to do this today: http://www.videojug.com/film/how-to-remove-rust But all of the running water is frozen! I ran out of welding wire trying to finish my trailing arms. I got under the car to knock off some of the undercoating and the surface rust. The rear floor seams are rusting out. Maybe I will go as far as pulling the rear seats and carpet up to get at all this. But only if i have all the materials to go back together with it. I am starting to contemplate whether or not it is worth that much effort, though. My decision to remove the interior will be based on how much room around the shop i have to keep all the stuff from getting nasty and ruined.
Stainless Brake Hoses: EA82?
MilesFox replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
RUST, and the idea of keeping the car forever. That and rust. Oh yeah, the rust-belt of the midwest. Roadsalts. and, of course, RUST! -
strange thing happened to me
MilesFox replied to soobies's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is enough mentions of the axle nut and washers in most axle/wheel bearing discussions. The washer does more than the cotter pin. -
Although someone can look up the info, pull a bolt, or go here and ask, it doesn't hurt to answer if you immediately know the question. And, really, it shouldn't hurt to ask. My comments about generation was not targeted at the original poster, but just a general observation of mine, since i know a lot of folks 5-10 yrs younger than my self, and the generation gaps are narrower. My comment has relevancy for the mere fact that a question was posted on an internet forum, which i answered:-p
The internet makes this sort of thing instantly available, among other things, for the current generation. This is why there is Google, and Wiki-Pedia. But for these people, Google and Wiki-pedia have always been around, and is the first resort.
It would be ideal to space everything equally. You will retain the same suspension geometry, as you raise the body from the car from the suspension assembly.
Make sure the washer is not on backwards. It is bowl shaped, with the convex side against the nut.This is important for holding the torque on the cone washer. Do some reading, and inspect your hardware! -
how clean is your engine bay? post your pics
MilesFox replied to MPGvan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is my '86 GL coupe Runabout. EA82, Hitachi carb. -
12mmx1.25 thread. This thread is the lesser common pitch you will find at hdwe stores, and finding them more than 2 inches long can be tricky. It's the same thread as the lug nuts and wheel studs. I built a lift with blocks using the body bolts to mount the lift to the body, and leftover suspension bolts from parts subarus and lugnusts to bolt the suspension to the lift blocks.
Exhausting topics:single, dual, or dual with"X"
MilesFox replied to raging squirrel's topic in Subaru Retrofitting
Based on the firing order, each cylinder bank fires almost simultaneously, as you will have 2 cylinder exhaust pulses at near the same time out of one port for that bank, alternately between the ports. So if you think about it, you essentially have 2 inline twins on a common crank. Each side of the header would be tuned to each bank, and both sides would collect at the end of the exhaust pulse, and after the collector, it's all muffler and tailpipe. Making the exhaust in an X configuration, at the same lenght as the cat in the factory y pipe(collector), you would have the same dynamic velocity/pulse/scavenge effect either way. From there you will hae a larger dump pipe, or 2 smaller dual outlets. And this, having 2 outlets gives you the same volume of flow, but the skinnier pipes keep the velocities up. In a true dual setup, you can run individual runners with no balance pipe, if not for the consideration of cats and o2 sensors. This is what i come to with my understanding of exhaust dynamics, and with subarus. A cam will affect the engines performance curves, but the exhaust piping itself is just fluid dynamics all on its own, regardless of the cam -
any tips on replacing speed-o cable
MilesFox replied to HGJ's topic in Old Gen.: 80's GL/DL/XT/Loyales...
maybe the cable pulled out of the back of the cluster, and the spinning shaft is rubbing against it. It is possible to pull the cable out and not know it when servicing heater hoses or anything else in that area, you would only have to pull the cable an inch to pop it out. You can inspect the cable by removing the instrument cluster bezel, and the section of dashboard behind it pulls up, and from there, you should be able to access the cable. This is easiest to do with your arms in the window while you view from outside the windshield, unless you can cram your head in there. -
Well, Tom, if Jon has the tool, we should look for where to find ss line
