Carmen
Everything posted by Carmen
  1. http://www.ultimatesubaru.org/forum/topic/152891-recurrent-question-how-to-share-photos-on-your-posts/
  2. one gasket goes between intake and adapter, the other gasket goes between adapter and carb.
  3. never see a FIVE speed auto trans in a subaru from the 1980s that must be manual trans
  4. u are wrong, there is a .jpg image with the subaru coil springs specs, spring rate, diameters, etc
  5. my local friend helped a lot of us with this information : http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/
  6. it is feasible, last time jes showed a 80 lbs box with rear discs , spindles, etc. from new hampshire USA, for the car of his wife
  7. I like how you rebuild engine , that is love !
  8. use from the brat http://www.ultimatesubaru.org/forum/topic/124175-the-awesome-newer-generation-picture-thread/page-13?do=findComment&comment=1244761
  9. pcv setup wrong ?? worn valve seals ??
  10. my friend posted this long time ago. http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/
  11. Ha , ha thats so true.
  12. I dont understand what herpes has to do with subaru ??
  13. look under the handle, in the console
  14. no luck findin a replacement motor and the subaru honduras dealer sucks. no help from them to find parts.
  15. yes , please help me, the image does not load.
  16. I miss my little subaru rex , but mine is front motor and front drive..
  17. i need to know measures , have you pictures ?? http://www.ultimatesubaru.org/forum/showthread.php?t=133013
  18. car tetris that is new
  19. my dad does metallic bushings from thin pipes insted the old plastic ones to fix sloppy shifter in datsuns , the idea could used in subarus
  20. hi there are many ladies here in USMB i just see your link and i have a question : why wives and girl friends and not female subaru owners ??
  21. 87 ea82 with leaking hill holder, my dad did the jeszek lazy solution removing the cable and it works but he want to put the clutch return spring and there is a metal piece in the way, it was for the cable. question is to remove or cut that metal piece, is that renforcing the gearbox? has 2 screws and can be removed but my dad wanna cut the top of it, he is not sure another question: is a bypass made to remove the hill holder?? no leaks but sees ugly . thanx
