Everything posted by Carmen
http://www.ultimatesubaru.org/forum/topic/152891-recurrent-question-how-to-share-photos-on-your-posts/
Okay! Okay! All Weber Converts! I Give!
Carmen replied to Sapper 157's topic in Old Gen.: 80's GL/DL/XT/Loyales...
one gasket goes between intake and adapter, the other gasket goes between adapter and carb. -
u are wrong, there is a .jpg image with the subaru coil springs specs, spring rate, diameters, etc
Forester from Switzerland
Carmen replied to jf1sf5's topic in Meet n' Greet. Your USMB Welcome Center
WELCOME! -
my local friend helped a lot of us with this information : http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/
it is feasible, last time jes showed a 80 lbs box with rear discs , spindles, etc. from new hampshire USA, for the car of his wife
I like how you rebuild engine , that is love !
pcv setup wrong ?? worn valve seals ??
cheap coil springs to experiment with? ea82t FWD
Carmen replied to Tat2Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my friend posted this long time ago. http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/ -
Ha , ha thats so true.
Rarest Old-School Subaru Part or Option?
Carmen replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I dont understand what herpes has to do with subaru ?? -
Loyale Parking Brake Adjustment o_O
Carmen replied to mstr_pete's topic in Old Gen.: 80's GL/DL/XT/Loyales...
look under the handle, in the console -
no luck findin a replacement motor and the subaru honduras dealer sucks. no help from them to find parts.
yes , please help me, the image does not load.
Carmen replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I miss my little subaru rex , but mine is front motor and front drive.. -
Hill Holder disconnected but still leaking?
Carmen replied to thebr0wn0ne's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i need to know measures , have you pictures ?? http://www.ultimatesubaru.org/forum/showthread.php?t=133013 -
car tetris that is new
my dad does metallic bushings from thin pipes insted the old plastic ones to fix sloppy shifter in datsuns , the idea could used in subarus
hi there are many ladies here in USMB i just see your link and i have a question : why wives and girl friends and not female subaru owners ??
bump
87 ea82 with leaking hill holder, my dad did the jeszek lazy solution removing the cable and it works but he want to put the clutch return spring and there is a metal piece in the way, it was for the cable. question is to remove or cut that metal piece, is that renforcing the gearbox? has 2 screws and can be removed but my dad wanna cut the top of it, he is not sure another question: is a bypass made to remove the hill holder?? no leaks but sees ugly . thanx
Ea82 dash clock ipod upgrade! Now with pics!!!!
Carmen replied to AKghandi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i like tha idea :)
