Everything posted by Numbchux
brat body on toyota frame with 350 engine?
Anything will fit.....zzz Consider the body will be higher up Re the frame because you'll have 2 frames. So you'll have more vertical clearance. Also, due to how far forward the transmission is with the subaru drivetrain. By using a divorced tcase and front axle, you'll be able to move the whole drivetrain back quite a bit. Yea, you'll have to get creative with the radiator and stuff, but I'm sure it could be done.
Loyale hub, how do I remove it from axle?
yea, get the axle to move, or sometimes a flathead screwdriver in the notch to force it to expand. Also, a torch pointed right at the washer will usually get it to pop out too. also, the rotor is bolted to the hub, so either unbolt the rotor (EDIT: I see you already did this), or remove the caliper.
Who sent me a harness?
Bump. Just got back from Sno*Drift. Got a couple other projects lined up. Since I don't know what's going on with this one, I don't dare start it, so I guess it's going down to the basement. Whoever you are, please contact me!!
Baja foglights
The factory foglights are great for the factory application. But for something that's going to be custom anyway, you can do a lot better for a fraction of the price!
loyale rear lift
I had 5" extensions on my '88, and with only 1" drop on the diff, I blew up 2 rear axles in about a half a day worth of wheeling. swapped to a 2" diff drop and 4" extensions, and never had a problem again. So there definitely is a limit. Only way to re-center the wheel is to lower the whole suspension crossmember. Which is not a good idea if you actually plan on wheeling it, as it'll make a major hangup point and weak link. Good news is, due to the trailing arm being where it is, the tire will never get any closer to the body in front of the tire. So if it's not touching now, it won't be a problem.
EJ20 Pistons in an EA81/EA82?
I don't think he had rod failure. He blew the piston ringlands apart a couple times due to a lean condition.
reddevil milling Phase 2 EJ251 rods to accept STi pistons: http://forums.nasioc.com/forums/showpost.php?p=17334554&postcount=784 He was running 20+ psi, twin-charged, through it about 50 miles later.
looking for help from the suby masterminds
Check out my post in your other thread....
Pug lug question
lol. Yea. Still gets out to Gilbert about once a year. Definitely not road-worthy anymore
This was an OBD I EJ22, right? Cats won't be effected at all. Just put one in each side, done. Put the 02 sensor in one side or the other, and it'll run pretty well. it'll only read the A/F from 2 cylinders, so you'll have to assume the other 2 are running close enough. "Run right"? depends on your definition. I have heard (and it makes sense in theory) that a boxer really needs the scavenging of having both sides connected to run at it's best. Since both cylinders on one bank fire, and then the other bank. By splitting them up into 2 separate systems, the temperature fluctuates too much, and the velocity of the exhaust gases drops. Here's an idea I was planning on running on my wagon. Keep the measurements from the header flanges to the crossover exactly the same as the borla header, and then open it immediately back up to 2 pipes and continue on to 2 decent mufflers.
Pug lug question
The Poopenvagon always did, and still does, have stock subaru lug nuts with 15" pug steelies. It's probably been 8 years or so since that car was built, and the last 5 it's been used only for bashing around the farm. If it hasn't failed on that car, I'd consider it safe
EJ20 Twin Turbo and RHD Conversion
Wow...I didn't catch this thread before. Cool build!! Not exactly. Most of the world (Australia included) rates their octane based on the Research number alone (RON). Here in the US, we use the R+M/2 (Average of Research and Motor octane, also known as the AKI), which is lower. AKI tends to be 4 or 5 points lower than RON. Meaning 93 AKI would be the same as 98 RON. And 91 would probably be just fine for non-race days. I would highly recommend getting a good knock monitoring system (knock-link being my preference). and experiment a little. You'll find different brands of fuel effect how much knock you're getting (in this area, Shell tends to have the most stable fuel).
Mounting fuel pumps in the rust belt
yep. that plate/bracket thing get tossed in the junk heap. slide a chunk of rubber on there to isolate it, and slap a few zipties on there however fits best, and call it a day It's not perfect or exact, but it works great. Just make sure you don't have any metal-on-metal. Cause the vibrations and such WILL wear through the side of the pump.
Lots o' Swaps
the front 02 is pretty important. the OBD II ECUs are pretty smart, and will make adjustments to the fuel trims based on that 02 sensor. The rear one is just to check the efficiency for the catalytic converter. it'll throw a code if it's not hooked up (or, if you don't have a cat), but it won't effect the way it runs. the 02 sensor bung is mounted in the cat-pipe, right after the manifold, on OBD II setups.
Everytime I've replaced one, it's gone back in with zip-ties. I bought a chunk of 3" (I think...) radiator hose a couple years ago. happens to perfectly slip over the outside of the fuel pump. helps prevent damage to the outer case if it's up against something. I don't think there's really a good way to do it. given it's location, and the small hardware it uses, it'll be pretty prone to failure. The bracket even came out pretty easy in my loyale, but the non-OEM replacement pump was too big for the brackets, and still ended up held in with zipties.
A week or so ago, a box showed up at my house. it says "93 EJ to EA" on it, so I'm assuming it's probably someone from USMB. I've been searching through emails and pms here and on many other sites, and I can't seem to find one that matches the name on the box. I get SOOOOOO many emails asking for information that sound like they're going to actually send me a harness. Most of them don't.... Anyway, whoever you are, you got my home address, so you've gotten in touch with me somehow, please contact me again with what's going on here. I've got 2 major rallies in the next month, as well as other projects, so this is a terrible time for another one to show up un-announced.
Stainless Brake Hoses: EA82?
depends on the design. every one I've installed we left the crossmember against the body. brake lines for rear drums are a bit different. you'll have to get a bit creative. IIRC the thread size for where the line attaches to the cylinder is smaller than on a caliper. so you might have to find something else there. or just have a braided line made to replace the short line between the body and trailing arm.
swapping gl-10 disks to loyale
No, the search function is not perfect. But seriously, there's a thread in the USRM that was posted (actually, transferred to the new site, it's much older than that) 3 YEARS before you registered here, titled "Rear Disc Conversion on EA81 & EA82s". So don't try to tell me that my bitterness isn't justified. I'm not kidding that this is one of the most commonly done and documented upgrades on an EA series subaru. Don't believe me? Here's the search results for "disc swap" in thread titles only: http://www.ultimatesubaru.org/forum/search.php?searchid=1174784 And the cherry on top. Don't worry, anyone who chooses to continue to use that phrase or word (in that or similar context) deserves zero respect. ESPECIALLY from someone who's arguing. There are very few sentences so apocalyptically offensive. I don't mind the occasional "that's retarded", "gay", or even "rice" comment. As in most contexts, those words have developed a separate meaning that really isn't offensive. But by specifically naming the special olympics, in a reference to people who should know better but choose not to act better, is INSANELY insulting to the handicapped people (and CHILDREN. Specifically the young down syndrome boy who has been photoshopped to look like he wet his pants in the picture you reference) who participate in the special olympics. My cousin has down syndrome, and she is one of the most wonderful, kind, and loving people I've ever met. Our society would be much better off with more people like her, and less people like you.
nobody makes them specifically for Ea82s Fronts are for sure interchangeable with EJ stuff. IIRC rears can be as well, just have to grab a banjo bolt from an EJ, and they'll be waaaayyyy too long. Or, grab a spare rubber one for the front and rear, and you should be able to find a local hydraulics place that can crimp the right connections onto a chunk of braided line.
- Shoot.
Best 4WD tranny for street/autocross EA81/Ej22?
not according to every listing I've seen. the '88XT FSM definitely shows the shorter gears. larger tires will bring the rpms down, that's how I combated the issue in my wagon. The 4.111 gearset that I had in my XT6 was muuuuuch better. had zero desire to have low range back. axles don't really break at stock height without a lot of extra power. If you don't do any maintenance and drive it for tens of thousands of miles with a destroyed boot and completely dry joint, it'll click and bind. But I've never seen one actually leave someone stranded.
advise on rear shocks and front strut.
^ the shock absorbers have zero influence on ride height in the rear of an EA81. So yea, suspension geometry has to be designed with axle longevity in mind, but once everything is set at the ride height you need, take some measurements of the shortest and longest (full stuff and full droop) shock you need, and then get 'em. Here's the Rough country shocks we used on my buddy's brat next to the stockers: a few minutes on the grinder, some lube, and a bench vise, and we got that upper mount swapped over from the old to the new. installed:
Shoot.
2" would probably be pretty good, just from an eyeball. Any idea how much of a difference in ride height you have compared to stock? The rear axles can safely take about 3" of extra height. On my first trip out with my old wagon, I had 5" extensions on the struts, and 1" blocks on the diff. I broke 2 axles in as many days (really....only half days before I wound up driving back to camp in FWD to replace an axle). Also, you may consider seeing if you can get your hands on a pair of rear axles from an '85-'86 Ea82. they have DOJ joints on both ends of the axles, instead of one DOJ and one CVJ, which means they can telescope from both ends and get a bit longer. While a DOJ can't take as much angle, it seems the biggest problem with a lifted EA82 breaking rear axles is the one DOJ get's hyperextended.
I Finally Got Lifted! Now With More Vitamins! Pics!
Wow! There's a screen name that I haven't seen around in awhile. Good to see you back in it, and what an excellent car for it.
There's this awesome thing on almost every internet discussion forum ever, called a search function. Here at the USMB, we also have a thing called the USRM (Ultimate Subaru Repair Manual), in which users have submitted many many many writeups on maintaining and upgrading your subaru over the years. an EA82->EA82 rear disc swap is one of the most commonly done, discussed, and documented mods done on old-gen subarus. with a tiny little bit of work, you'll find a TON of documentation and information on the swap.
