Everything posted by Numbchux
Easy Question For the EA82 Gurus
rear seat and y-pipe definitely. the pipe before the muffler might be routed differently though, as the rear suspension is quite a bit simpler.
EJ swap under way
- 4eat in my 91 legacy
agreed. many cars with a manual had a 3.90, so those rear diffs are quite common. if you don't swap them, your transfer clutches will burn out in very short order, and then you'll only have FWD.- EJ swap under way
yep, it'll need an 02 sensor. that's a pretty crucial part (will run without....but your mileage/performance will suffer). so, of course, plug is left in the harness. it's ready to ship out.....pm me your addy.- EJ swap under way
other "half" is stripped now too. pile of excess now:- EJ swap under way
the first few were good fun. they're getting a bit tedious these days (I've got no less than 8 subaru bulkhead harnesses in my house right now )- Rear coil-over question.
front camber is not adjustable. so, in theory......the only way for camber to be different on one side than the other.....is if something is bent.- EJ swap under way
lots of harness progress today. got the larger "half" off it completely stripped down. stuff I'd cut out as of this afternoon: tonight: harness this afternoon: tonight:- Rear coil-over question.
just use real compressors.....they're like $20 to buy, and at most auto parts shops, free to rent.- Rear Wheel bearing question
if you can get the axle off the diff (I wouldn't drop the diff just yet. as I really don't think that will help all that much. it is only 3 bolts, but I just don't think it'll be that much help). if you can get it free of the diff, you can pound the spindle out of the bearings with the axle still attached- SVX lsd in a brat?
yep, Outbacks, foresters, '01 RSs, I think I'd heard it was available on some tribeca's too...but don't quote me on that one.- EJ swap under way
wiring is coming along nicely. and I've got 4 days off this week, so pretty good chance it'll be done soon.- official build thread.........this is monstaru2
absolutely awesome idea. love the train of thought. lubrication is AN issue, but I don't think it's THE issue. I just don't think there's a way to get it to spin the right way in that case.- SVX lsd in a brat?
lots of debate of whether it will work or not. but it seems the only one of those posts by someone who's tried includes pictures of it done: http://subaruxt.com/forum/viewtopic.php?f=1&t=2089&st=0&sk=t&sd=a&start=90 SVX uses an r160 VLSD. I agree, I do prefer the clutch-type, but if that isn't available, a VLSD > open every day of the week. and a welded diff isn't for everyone either. you'll need to swap the SVX inner DOJ cups onto the EA shafts. I've heard the XT6 shafts are larger in diameter than other EAs, so in an EA81, you might need custom races. but even that is peanuts compared to trying to get your hands on an EA82 LSD. I plan on putting an SVX rear LSD in one of my EAs this spring. I'll include pics of it as well.- Wikipedia's List of Subaru Engines
click the link to the EJ-specific page. EJ22t and EJ22k are both listed. I've submitted numerous changes/corrections to that page.- EJ swap under way
I don't use the stock relay/wiring/fans. just the one wire from the ECU to control a standard relay. it's exactly the same to wire in as your controller, except it doesn't need to be mounted anywhere. and it can't fail (I used a couple of those underhood controllers, and the road grime caused them to fail).- official build thread.........this is monstaru2
alright...you got my gears turning so I went downstairs. hmmm....look at that, an empty r160 case, and a ring gear sitting right next to it from my last LSD conversion. first thing, the bolt pattern for the rear cover definitely is symmetrical. so you really could just throw it on upside-down. but, the pinion gear is off center, in both dimensions. obviously it's near the bottom of the case (presumably why you want to flip it), but it's also off to the right side. so, putting the ring gear on the other side would mean the helical cut on the gears would be the wrong way around. but also the center of the pinion shaft would line up about where the back of the ring gear would be... I don't think it would work, even with a custom-made gearset. cool idea, but looking at it, I just don't see a way it would work (boy.....I wonder where I put my camera.....)- EJ swap under way
have you looked at, oh, any of the EJ swap threads? yea. the EJ engine is a bit longer than the EA, so there is no longer quite enough room between it and the radiator.- official build thread.........this is monstaru2
wouldn't flipping the diff upside-down make it turn the other way? unless you've got a tcase that reverses the rear output direction (I've never heard of one...). also, you'd have to either flip the rear cover upside-down (might be just that easy, I don't remember how symmetrical the cover is), or relocate the breather. planning on leaving it IRS as well?- EJ swap under way
you should cut another 1/2" or so off one of the ends of the upper radiator hose. as it's kinked just a hair. radiator fan controller was entirely unnecessary, as the harness will have an ECU controlled relay in it. a manual override would be very easy.- Tein FLEX legacy rear dampers; 00-04 or 05+?
that's what WJM used on his RX as well. *in theory* the 00-04 ones should work as well. but the 05+ are the only ones that have been used.- just bought an XT6.....added pics!
the front air struts hold air just fine. so they will stay for now. I'm not swapping to an EJ engine, just struts/knuckles/bearings/brakes/axles. it will get coils in the front then.- just bought an XT6.....added pics!
ProECM lightweight crank pulley I picked up from kingbobdole... threw the 15" steelies and Blizzak Revo1s from the wagon on it and took it ice racing a few weeks ago. more pics in the rally/racing section. which was the last coffin nail in the rear air suspension. it was drastically sagged for the trip home, and only made it about 2 more days before it was bottomed out completely. spent a day trying to jumper the solenoids and such to put air in them, without luck: that black connector under the fuel lines is the check connector where the signal wires for the individual solenoids are. jumpered to open one of the rears: the connector under the fuse box, jumpered to open the air charge solenoid: I was entirely unsuccessful.....so I got a few boxes over the last week or so: 4WD EA82 GR2s (which come with new upper bushings), 2.5" x 12" 250 lb/in Eibach springs from Ground-Control. should make for a nice firm ride, and match up well with some outback struts when I go EJ in the front. also got a couple boxes from Rock Auto. including 6 NGK v-power plugs, Bosch plug wires, and a Beck/Arnley 02 sensor.- Rear Wheel bearing question
you do NOT need to drop the rear diff to get the axle off. just unbolt the shock from the control arm, and pry it down. that will give you enough play to pull it off the stub. the project is fairly involved. especially if you're in a part of the world where rust is an issue. the bearing retainer can be removed without the tool, but can also ruin your day if it doesn't want to. the pin socket and an impact wrench makes it a 7 second project. I'll never do it again without. if yours has the one-piece outer race (your new bearing probably does...), it'll come out pretty easy. if it's the 3-piece, the last piece to come out is pretty narrow, make absolute sure it comes out straight, or it can get jammed. an air hammer can also come in handy. other than that, pull the axle, and brakes. unscrew the retainer from the backside of the control arm. give a few taps on the end of the spindle to separate the 2 halves of the inner race. a bench vice can be a big help when getting the other half off the spindle. get the outer race out (the inner race, bearings and a large socket work well). then re-assemble.- '82 Brat: Solid Axle Build *** DONE! :) ***
oh yea, seen a couple '80s Toyotas up at the ORV park here in MN crawling with stock motors and 200+:1 crawl ratios. it's something else to see a rig going to through some gnarly rock crawl with his left foot hanging out the door (gearing is so low....don't even need to touch the clutch pedal). - 4eat in my 91 legacy
