Everything posted by Numbchux
MNSubaru Ice Races
also....gif slideshow of one corner:
- MNSubaru Ice Races
EJ swap under way
should've pulled the sway bar while you were in there.
EJ swap under way
not really. the OBD II uses slightly more wires, and a couple extra sensors (MAP and some solenoid on the passenger strut tower...), and WILL NOT work correctly without a VSS. but the way the harness is laid out, it's much easier to install.
MNSubaru Ice Races
couple more good shots of the '6:
Post pictures of your EJ swap
for those concerned about install of a wiring harness. here's the page of info I send out with a stripped harness. http://www.numbchuxconversions.com/Files/Harness%20info.pdf
rats nest? ha. finished OBD II harness ready to be installed: as much dash disassembly that was required. using a hole saw to cut a hole in the firewall for the wiring: engine installed (AND wired. and it only got cleaner!!)
1985 Subaru Brat Suspension Upgrade
there's approximately nothing made for the brat performance-wise. GR2s are the only thing that are stiffer than stock. and those are not adjustable. and the front strut design is unique enough, I doubt you'll find anything that'll work up there very easily. not to say it can't be done. just that I don't think it has, and it won't be easy.
EJ swap under way
clear your pm box.
^ditto. both the swaps I've done, I've mounted the ECU to the steering column.
Documented: The 1970 FF-1 Project car...
for reference.... 14s: 15s: kinda hard to tell from those pics, with the ride height being so different. but from a looks standpoint, I think the 14s fit better.
MNSubaru Ice Races
Took the XT6 up for the day today.....only a couple pics so far....will post as they come (almost everyone is still up there....I'm just too cheap to pay for lodging). weather was pretty nice:- Post pictures of your EJ swap
my pm page isn't working now....fuel lines are easy. the carbed car has a high-pressure line, return line, and vent. and so does the EJ.- Fuel pump for 91 Loyale NA. Alternatives?
the '86 was carbed. the EJ22 I dropped in it was N/A. N/A EJ22s and SPFI EA82s have almost the exact same "needs" (psi and cfm). so if it works for your SPFI, it'll work with the EJ22.- Input for OBS rebuild.
^he's talking about a hybrid. the phase I EJ25 shortblock with his 2.2 heads/intake. that's plug and play.- Input for OBS rebuild.
IIRC, the cylinder hole in the head gaskets is larger than the bore by a bit. so 2.2 HGs will still clear the bore just fine. but don't quote me on it.....I've got some info on hybrid builds somewhere, I'll dig... I wouldn't bother with the EA82 trans. limits your clutch selection quite a bit, and FT4WD/AWD is much nicer in mediocre weather (where FWD just won't do, but 4WD is overkill). upside is, you'll see better good-weather mileage in FWD. the torque of a high-compression 2.5 would make the low range entirely unnecessary. also, since this is a daily driver. I'd think twice about a high-comp hybrid. they're a bit high-maintenence, and will require premium fuel. maybe get another 2.2 and throw some cams/TB spacer/exhaust at it. might get you the extra power you seek without sacrificing reliability and cost.- Fuel pump for 91 Loyale NA. Alternatives?
I got one for a '90 Ford Grand Squire wagon on ebay for about $30 and used it in the '86 wagon that I EJ-swapped last summer. worked great!- 4EAT Paddle shifters
wow. simply awesome work. another solution to the rpm signal "issue" was presented to me this week. Tom'sSVX mentioned over on RS25 a digital speedometer signal modifier that can be adjusted to correct a VSS pulse for different tire sizes. he suggested it could be used to correct a tach signal to use a 4-cyl tach after an EG33 swap.... I'm thinking I could easily rig up a 4-cyl EA82 tach (only takes 3 wires...power, ground, and signal), and use it to calibrate the converter. then a 4-cyl TCU could be used pretty easily (that is, if reprogramming the code doesn't work...). I'll definitely be in touch once the weather warms up. then I can get in there and wire in a set of EJ TCU plugs....make a wire to plug in my laptop....and start digging into code. I was looking into FSMs, and a FWD 4EAT legacy has the exact same gear ratios (including a 3.7 axle ratio) as the XT6 AWD 4EAT. it just happens my EJ22 donor was a FWD 4EAT, and I saved the TCU (somewhere). might try to download the gear ratio maps and VSS signal stuff from it and program into an AWD TCU.- Uncle Scotty! one cocktail please
I should mention, I probably put almost 30k miles on it before I started noticing negative effects, I put the cocktail in my dad's '94 LGT at about the same time, and it's still running awesome, but he puts a fraction of the miles on his car than I do. I'll look into that Motul. might be another good option.- Uncle Scotty! one cocktail please
follow up. ditched the cocktail not long before putting the car away for the winter. was noticing quite a bit of bearing noise from the tranny. enough that I was starting to worry.... so I drained the cocktail, and filled with 4qts of straight Castrol HypoyC 80w90. shifting is a little slower (but better than before the cocktail), but the bearing noise is gone. also have to let it run for a minute in neutral before it'll go in gear in the cold....but I'll deal with that over bearing noise any day of the week. so, I think the cocktail is like running ATF in your MT. great to clean it out for a little while. but not long-term.- Strange 1990 Loyale 4WD problem...
^I haven't had a push-button 4WD car. but my RX trans is extremely hard to move by hand if the car is running (vacuum lines removed). even if the car is in neutral, the input shaft is spinning, and circulating fluid.....that's my theory anyway- Strange 1990 Loyale 4WD problem...
first off: do you have any other reason to believe that it isn't working? did start the car, and see if the lever moves with the button or not? What I'm getting at, is if the problem might just be with the indicator light. otherwise, if I'm reading this correctly (correct me if this is wrong). you have vacuum to and from the solenoids (and it switches lines with the switch like it should). and the lever moves freely at the trans by hand, but not from the switch. assuming that the 4WD system works. it could be: vacuum leak between the solenoid and the diaphragm on the trans faulty diaphragm broken cable between the diaphragm and the lever I believe the push-button 4WD trannies use a clutch pack to transfer power to the rear end. BUT, if these were failing, the light would still come on, you just wouldn't have 4WD. also, yes, the PT4WD systems do have torque bind while in 4WD. that's why there's a 2WD setting. You should be able to manually switch it to 4WD, start the car, drive in a tight circle on dry pavement, and feel significant bind (don't make a habit of this, it's hard on the car). ALSO, WELCOME!!! and a huge pat on the back for searching through existing posts to find the solution yourself!!!!- '82 Brat: Solid Axle Build *** DONE! :) ***
because toyota stopped making solid front axles in the US in '86. which happened to be the same year they widened the rear axles. so choices are, use the narrower rear to match, or wheel spacers. thousands of toyota guys use spacers. the scrub radius change is not a big deal, it's not like this is an AutoX car. - MNSubaru Ice Races
