112
Everything posted by Numbchux
Wagon? IIRC, the backup lights on that are in the hatch. The wiring harness that passes from the body into the rear hatch is pretty notorious from breaking with the fatigue from opening and closing the hatch causing all kind of electrical gremlins. It is absolutely possible to splice in a new section of wire, but the most complete fix is to replace that whole harness. We kept them in stock at the dealer where I worked, and MSRP was about $80. Pull the back edge of the headliner down, and unplug that harness from the body, and then see if your fuse blows.
I had the EJ switch on mine hooked up to some other warning light on the EA82 dash. Something with the AT, maybe? My car was originally an auto, and swapped to a manual at the same time. Yes, stock sensors are BSPT.
False There's a wire or 2 in the circuit running to the headlight switch so they only work with the low beams on. I've modified this on almost all my cars. sirtokesalot, if you'd care to enlighten us as to what you're working on, I'll answer your question. I normally will not even respond if I have to ask this.
Turbo legacy didn't have a cap on the radiator, the bleed came right off the expansion tank on the motor to the overflow tank. I would put a higher-pressure cap on the radiator, and then run both hoses to the overflow, just in case.
By far the #1 problem for radio replacements when I worked at the dealer was bluetooth pairing issues. If it's under warranty, bring it to the dealer. My mom's 2012 Impreza radio stopped connecting. We bought a used one (don't remember if we found a local yard, or bought on ebay) and swapped it in. Or get as much information off the radio as you can (faceplate ID, brand, etc.) and call the dealership parts deptartment. There are some factory remanufactured options that aren't terribly costly.
Call out to XT6 owners! Wiring question
Numbchux replied to jdmleggy97's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't have the diagrams in front of me. Is this something that maybe could be tested from the pump side? There's at least 2 feet of snow on the hood of my XT6, but if this weather keeps up, I might be able to get to it enough to get the hood open this weekend. Won't be able to get the trunk open and get to the ECU until I can move the car, which won't be until the snow thaws AND ground dries up.... -
ER27 durability + performance build
Numbchux replied to tjet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This comes up in the images search that carfreak posted. This is very common discussion with performance EJ block selection, as all 3 forms are available No easy answer to that without some serious thermodynamics engineering. And being that yours isn't going in a Subaru, airflow will be all different from most of the documentation. But the EA/ER engines have very weak cooling systems, heat will probably be your biggest challenge, depending how hard you try to push it. Err on the side of caution with radiator capacity, oil cooler (at least oil/coolant exchanger, oil/air can be hard to prevent overcooling) would likely be a good idea. A radiator that struggles to keep a 90hp EA82 cool can keep a 130hp EJ cool without any fans. Don't run a lower temp thermostat, though. Aluminum engines don't like being run cold, either. But if you've got adequate cooling capacity, you shouldn't go over "fully open" temp on the stat. -
You speak the truth. One of the reasons the EA/ER engines have such a terrible cooling system. I've seen a couple big closed-deck EJ22t cars that required so much more cooling capacity than it seemed similar semi-closed blocks required. -
Agreed on the pins. When you replace the caliper, is it semi-loaded (comes with a bracket)? If you're reusing the bracket/pins, that's probably the problem. I keep a very close eye on my caliper slides on all my vehicles, and periodically clean and regrease them. Having far less issues since I started using Permatex Ceramic high temp brake lube.
Yep, check for trouble codes. It's probably trying to tell you what's wrong. Pull the vacuum hose off the fuel pressure regulator and see if there's fuel in there. That can cause some weird running issues. Question the age and condition of the spark plugs and wires. If it's a 2.5 (96 Outback could be either one, autos had the 2.5, manuals had the 2.2) the plugs aren't terribly easy to get to, so have new Copper NGKs ready if you're going to check them. The 2.2 is pretty easy to pull one and inspect it.
So, your tail lights are on, but not the front parking lights? If that's the case, that's quite the issue. Might be something simple, but that's not likely the stop light. I suspect you've got broken/shorted wires, and/or corroded sockets and blown fuses. Do your front parking lights come on at all? Get a good wiring diagram (jdmfsm.info) and multimeter, and start testing.
legacy brake master cylinder swap on Loyale
Numbchux replied to fishstix's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Subarus use diagonal systems, one circuit will be LF/RR and the other RF/LR. It does not matter which is which. The 2-port master is for the ABS cars, because the ABS system is the "T" that splits the 2 circuits into 4. The hill holder does the same. So yes, you can just use a splitter. Similarly, you can use a 4-port master (non-ABS, non-hill holder) by blocking off the extra ports. Off the top of my head, the Loyale is probably a 7/8 bore, and the Legacy is probably 1". This will reduce the mechanical advantage between the master and the caliper/cylinders. Good option if you've also replaced with larger capacity calipers, though (I have a 1 1/16" SVX master in my XT6, but I also have early WRX front calipers, and 200SX rears) -
subaruairbagrecall.us doesn't appear to have a website (could still be a valid email, but suspicious). No mention of any mobile repair/contact on https://www.subaru.com/vehicle-recalls/airbags.html Here's a job posting on LinkedIn, though. https://www.linkedin.com/jobs/view/recall-specialist-at-marketsource-inc-1692844397 F'n weird
