Everything posted by bratman18
TomRHere's '88 GL 4WD Wagon
Aftermarket cv axles? How's the driveshaft?
- My off road brat.
ADVForester
Nice. I saw your Forester on subaruforester.org. Love the skid plate!
- RSB mod on 03 OBS
- Outback hitch mounted winch power
RSB mod on 03 OBS
Should be able to undo the endlinks, rotate the bar ends upwards into position, and then reattach the endlinks.
My 1998 Legacy Outback
Looks great! Love that front bumper.
I need help! Alternator died on me. (story inside
bratman18 replied to ibroad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe charged you $600 to replace a battery and alternator?!
Front Sway bar
On the old ones it doesn't make a whole lot of difference. It helps quite a bit offroad, but not a lot on road. I always remove them from my old Loyale's an GL's. The newer ones like the 2000 sedan that he is talking about above, yes, it makes a huge difference. But not on an old lifted Subaru.
88 GL Best underpowered car ever
They're actually called SOS Fab now.
just picked up my first dual range suby!
I have DD's many 2" lifted EA82 cars with no issues at all. And mine were never even camber correct like this one. But totally your call!
I have a brand new unused 2" BOSS lift that I'd sell if you're interested. I'll let it go for what it cost me, $125 shipped and PayPal'd.
how to leave from a dig...with an STI
bratman18 replied to StiAnthony's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSTi drivetrain is damn tough. There are plenty of people out there running 600+ to them and running them down the track, with no real issues. The axles are the weak point, but I don't think at your power level you will have any issues.
bratman18 replied to StiAnthony's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot positive, but doesn't the traction control limit the amount of throttle? I would think you should turn it off. It won't spin a ton anyway with it on full diff lock.
bratman18 replied to StiAnthony's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat might be something you have to test out. Is your car completely stock? You will find that if you're not launching at a high enough RPM then it will still bog down a bit. But if you do it right it will take off screaming and have you shifting pretty quickly. But yeah, if you turn the dial to full lock, and dump the clutch, it might spin slightly, but it will mostly just throw you back in the seat and GO! And the 6spd and R180 take it very well! For even better launching, it wouldn't be a bad idea to upgrade your bushings to take some of the driveline slop out of it.
87 GL Wagon (picture heavy)
I have had many 2" lifts on EA82 cars with no crossmember spacers. I never broke an axle on one and I abused them. The lifting of the front end on acceleration is caused by bad alignment after the lift. If you toe your tires out a little on each side, it will get rid of a lot of that problem and help with tire wear as well.
bratman18 replied to StiAnthony's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFull lock and launch!
99 Legacy GT getting 2004 Forester suspension.. Do i need the outback lift blocks?
I have put Outback struts which are pretty damn close to the same into a GT before. You do not need the body spacers. It can be a struggle to get them in, but they will go.
Fuel pressure regulator thingies?
I was always told those were kind of like silencers or something. We used to bypass them all the time without issue.
Documented: The 1970 FF-1 Project car...
Anyone on the forums buy it?
Stereo Wiring, '93 Loyale Canadian Model
Are you trying to install an aftermarket radio? If so, they sell adapter harnesses right on ebay.
SJR-LIFT
bratman18 replied to baja03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsjrlift.com sjrwa@yahoo.com
3.7 Lsd
Sorry but the new search function is lacking. While this topic may be somewhat easy to find, many others aren't, so no harm in asking. This is after all a forum. And this isn't NASIOC. People should use the search function, but no need to be rude to someone looking for answers.
help to find the wheel pages ea81 & ea82
http://www.indysworld.com/80s/general/wheels/wheels.html
BOSS 2" EA82 Lift Kits- $100!!!
He isn't making them anymore.
