15
Everything posted by bratman18
Question about turbo diff lock transmission
bratman18 replied to bratman18's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok good to know. I have the opportunity to buy a car with this, and was hoping to combine my dual range, and gain the fulltime 4wd with diff lock. But I guess it's not possible. Thank you -
If I have an 88 5spd turbo full time 4wd diff lock tranny, is it possible to swap the tail shaft section over onto a regular 5 spd dual range and then have a dual range with diff lock and full time 4wd? I know I have read stuff about this before, but I couldn't find the answer when I searched. And please forgive my ignorance! I haven't worked with the turbo transmissions at all! Thank you!
I've got a 1/2" drive Milwaukee 18v cordless impact gun. Rated at 475 lb ft, and it's awesome. It's not bulky, and can remove lug nuts, axle nuts, strut bolts (as long as they aren't rusted on so bad you have to use a 3' extension on a breaker bar)
Front disc brake job...
bratman18 replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The rotor will not fit of over the hub. You have to remove the axle nut, then the hub/rotor assembly. Remove the 4 hub/rotor bolts, and then do the reverse to assemble. -
Good to see it coming together!!!
Awesome. I want this in my OBS!
Age old oil question
bratman18 replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have run 10w40 in all my EA cars year round. Always have, and for the exact reason you said, it helps reduce leaks. The EA82's leak oil, pretty much no matter what you do lol. It gets cold here in the winter, and I've never had issues running the thicker stuff, even well below freezing. But that's just my experience. -
Will 14" 4x140 steel wheels fit on an EA81?
bratman18 replied to Hydropneumatic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I ran 14" doughnuts on a couple of my wheeler cars with no issue. I did bend one, but it was an extremely hard hit, and bent the radius rod too. They balanced good, and held up fine. -
Little bump in the rump, EA82 shock mod
bratman18 replied to Gloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I actually did the first step in this a few years ago. I flipped the lower spring perch, and then welded an old prop rod around to hold the spring to add just a little extra. But we didn't have any old perches laying around to do like you did. -
Yeah that's for the newer ones. Seems the 05 Legacy GT's were the biggest victim of this issue for some reason.
Where do you find 185/80R13 tires?
bratman18 replied to silverghost88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That ebay link says $114 quantity 4. So it seems that's the price for 4 tires. -
The Subaru Search and Rescue Thread
bratman18 replied to Rust's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Rust, any chance at all of selling that front bumper on the wagon you got from Maine? -
WCSS 15 photo thread!
bratman18 replied to Hondasucks's topic in Meet n' Greet. Your USMB Welcome Center
Is he on here? Never seen it before. -
Whose red lifted EJ swapped EA82 wagon in the beginning? That thing is immaculate! -
front passenger wheel seized up 1985 gl hi-lo
bratman18 replied to nepppen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your pads are probably worn down enough. -
Awesome! Looks great so far!
Attach the lift block to the strut, then bolt the top in, then work the bottom of the strut into the knuckle. Might need a hand to work it in, but it'll go.
Stereo Wiring, '93 Loyale Canadian Model
bratman18 replied to Mustakrakesh's topic in Subaru Retrofitting
Interesting. I don't have rear speakers now, but I have in other Loyales hooked up the same way and never had an issue. But I did however run dedicated front speaker wires to the doors, instead of using the factory front speaker wires. Could this be why I didn't have issues? -
Yes, you have to screw the caliper piston in, not press it in like most. They have a tool for the job, but you can also just use the nose end of pliers as well.
