el_freddo
  1. GT meaning turbo over there?? GT = twin turbo over here but I know you guys typically don’t get the twins due to the LHS steering column fouling on the seecondary’s dump pipe or something. So, if a turbo, I’d say the smoke is the typical cam cover seal leak onto the turbo exhaust manifold. If NA it could be a rear main, or one of the other suggestions above. Cheers Bennie
  2. It will bolt in. Diff output methods will be different though. The ‘99 will most likely have stubs from the diff and the ‘04 will use driveshafts that have stubs that fit into the diff. I’m unsure if these driveshafts are 100% interchangeable. In my mind they’ll work but I’ll let someone more experienced comment on that front. You could do a diff centre swap between the two diffs to keep the correct driveshaft attachment method with the diff you want to use. Cheers Bennie
  3. Or even drop to 3.7. Adaptor plates availble from Oz: SUBARU EJ SERIES ENGINE TO EA SERIES GEAR BOX ADAPTORS on Gumtree http://www.gumtree.com.au/s-ad/1179605973?utm_campaign=socialbuttons&utm_content=app_ios&utm_medium=social&utm_source=sms You will also need the EA flywheel and beef up the EA clutch. From memory the clutch is cable operated so that bit is easy Cheers Bennie
  4. ECM meaning engine control module, such as an ECU?? Your BRAT won’t have one. The other thing to check is the fuel cut solenoid is working. Can you hear the fuel pump running just after you stop cranking the engine with the starter? If not, this is part of the issue. But it also needs a reference signal from the coil. Cheers Bennie
  5. Al, I believe it’s due to the reintroduction of the 4 door wagon that’s sligthly smaller in size than the ute and troopie. They all share the same chassis, and thus the rear track on the ute and troopie is the same as that of the wagon (which has the same track width front and rear). But for some reason they made the ute and troopie a wider body with a wider front end track width. The turbo diesel V8 was just a coincidence at the time of the new model. I’ll be interested to see what you find Al, I remember this wagon model being the reason for the track width difference. Cheers Bennie
  6. Thread dig alert!’ @wtdash - what came of this build? I hope you’re still on here and have something good to share (pls share even if not good!). Cheers Bennie
  7. For those else where in the Landcruiser Market, the track width is only an Australian thing due to our design rules with something about the distance the wheel bearing can be from the suspension mount. I didn’t know the rear end fought for the front wheel’s track in soft sand. Interestingly you can spend a couple of grand and have a certified kit fitted that brings the rear wheel out to match the front wheel’s track width. Cheers Bennie
  8. I’m with sparkboy - RIP is a bit up the deep end! It’s making a comeback so more of a hiatus... Sounds like you’ve got a good mate! And what’s being sand blasted? Not body panels I hope! They’ll come back rippled no doubt, unless blasting techniques have changed. The rippling is due to heat from friction of the beads contacting the metal. I’d look into that before professing with the sand blasting. Cheers Bennie
  9. Leaving one track different to the other would seem like a half arsed effort, and I’ve not seen any factory Subarus look like the Citroën from back in the day. Isn’t there a handling issue with the front track less than the rear? Cheers Bennie
  10. This is the standard way to do it if going 5 stud and I totally agree. But jdmleggy has widened the rear track to “EJ spec”, so the front needs the same treatment to bring front and rear track width to be the same. I too did not know about the EA81 tie rod end swap when doing the “standard” 5 stud front end swap. Cheers Bennie
  11. With a lot of fun... I mean Bennie
  12. What do you mean “cool like yours”?? They’re all cool! Rallyru, I love how your MY wagon makes a lifted Impreza look small!! Cheers Bennie
  13. Milty, we call that manoeuvre “angel gear” over here. If you skip into neutral at speed and use the brakes you’re in the hands of the angels. Some might say that it’s the same for an auto but really it’s not, get back on the good stuff and the auto does the rest for you. Cheers Bennie
  14. The front end *shouldn’t* be too hard compared to the rear. EJ strut of choice, EJ hub, EJ lower control arm. Hardest part is fabricating the rear mount for the control arm. And you’d need to check the front mount is in the same position on the EA crossmember. My hunch is that it’s the same but I’ve never looked into it before. I’m looking forward to seeing if you come up with something different. Cheers Bennie
  15. Nice thread dig... isn’t there another current one that’s working on/covering this already?? Cheers Bennie
  16. Also check the continality of the wires from the coil to the module to ensure there’s not a break in the wire. Cheers Bennie
  17. No, two different sizes. Dunno how you’d stuff that up! Cheers Bennie
  18. Steady blinking indicates the market the ecu is from, and there’s are no stored codes. Mid codes are stored, these would be flashed instead of the market designation. Cheers Bennie
  19. Igniter module is dead. Replace with known good one or be one. Check your fuses too, just to be sure you’re not chasing your tail for no reason Cheers Bennie
  20. New trans tunnel = more engineering required which = more $$$s, potentially $$$$s... Cheers Bennie
  21. Turn the heater off and see what the difference is! You’ll melt your dashboard doing this with the heater on! Cheers Bennie
  22. Good thread dig from 2016! Maybe they’re stuck on the side of the road somewhere with a jammed gearbox waiting for help? Cheers Bennie
  23. It’s bigger in diametre from the pics I’ve seen, and probably longer than an EJ 5 speed. It could be the same length as the 4wd 4spd box come to think of it. Google some images and check it out Cheers Bennie
  24. *Yawn* Boring!! Seriously though, you need to go with a vehicle that will meet your needs and that you’re confident with in purchasing. Don’t buy a car in the evening as the sun sets, paintwork unless really really bad will look ace... until the sun comes up the next morning. My dad did this and while the car was good the paint had many imperfections including swirl marks from a sander used before its last respray All the best in your purchase Bennie
  25. Yes you can if you keep the connectors. I can read the codes on my sister’s Gen3 Liberty using the plugs. Nothing has changed in that department for the early OBDII, later gear may have changed but I’m not familiar with that. I’ve also been told on good authority (auto sparky mate) that OBDII Gen2 stuff is much easier to cut down than the OBDI Gen1 looms. Cheers Bennie
