el_freddo
  1. Mine’s on 528k km at the moment, it’s done some pretty serious off-roading and doesn’t have many original parts on her anymore except the doors, glass and back seat... She’s a beast though Cheers Bennie
  2. I’ve done this prior to our last trip: Worked a treat and made packing/retrieving gear soooo much easier compared to the old setup. It’s also lighter There’s a kitchen cabinet that slides in under the left shelf - it will end up on a set of slides so you can use it from the back of the vehicle or remove it and use it on a bench/table etc. Our setup is pretty much sorted now. I’m very happy with it. Cheers Bennie
  3. No, I think it’s been modified for aviation use. The EA81 bell housing looks very similar to the EA82 bell housing Cheers Bennie
  4. Try your vin at partsouq.com You might manage to find the part numbers you’re after through this website. Cheers Bennie
  5. Welcome to the forum! Nice L I love mine!! Keep the rust out of it and she’ll be apples for a long time to come Cheers Bennie
  6. You guys are such downers! Looking more closely at the lhs head near the intake mounting area I’m reckoning this is an EA81S engine. Cheers Bennie
  7. I think you need to identify what the noise from the engine is - if it’s a shot tensioner then replace it! The valve knock is really valve knock? It doesn’t sound like the engine is as dead as others seem to make out. If you’re going to do suspension work replace the struts with forester units as these will provide some lift. Someone will know what springs to run. Lift blocks can be added later. There are a few mobs that do lift over your way to choose from. Otherwise Subi Lift Oz over here can ship internationally All the best with it! Cheers Bennie
  8. Maybe, but theoretically it can be done. I’m still wondering why you’d want to reduce displacement... Cheers Bennie
  9. Why would you want to drop to a smaller engine? You could put the ej22 block between the ej25 heads. No need for wiring stuff then. Cheers Bennie
  10. With an EJ swap the L's AWD box is worth the effort, especially since they came with the dual range that can easily be swapped to the better L's low of 1.59:1. the AWD with the EJ makes a huge difference in traction in the wet! Even in general for that matter. if dual range isn't needed, shove an EJ AWD box in. The conversion is same same but different to the EA 5spd box. The rear discs are a neat upgrade over the drums. That said if your rear drums are serviced and working well, you may not notice much of a difference in performance. Discs seem to require less maintenance. Cheers Bennie
  11. Welcome Rich. Bugger about the rod knock. Insure you'll find some answers here as to options to get this sorted Cheers Bennie
  12. Nice L mate! Carb or efi? That'll help with diagnostics etc. I love my L - but I'm partial to the wagons And geez, going from looking at an '04 sti to the ol' L is a HUGE change in direction to say the least! Cheers Bennie
  13. The steering column is sitting properly as it should? Same year crossmember used from an outback? I'm 99% sure all EJ racks are the same dimensions etc. being an outback, the steering extension/joint between rack and column should have a block looking section in it. The liberty/legacy unit doesn't have this block section. The only other thing I can think of is that the joint has been pushed on to the rack shaft too far, leaving little to grip on the column's shaft. Cheers Bennie
  14. Oil pump leak is most likely the crank shaft seal - which means pulling the cam belt. It's a good time to replace the cam shaft seals too. dealer is probably quoting that obsurd price in the hope of a sale on anew vehicle. Cheers Bennie
  15. All good mate. Im looking forward to more pics of this engine if available... Cheers Bennie
  16. Sounds like you need to look further abroad for spare parts. I don't have trouble getting ball joints, tie rods, suspension bushes etc. I can't comment on the oil pumps as I run an EJ22 in my L. A very worth while conversion for the L in my opinion. GD will say go the legacy on that front too. Best of luck with your hunt for a good unit I love my L and I hope you do too after buying another one Cheers Bennie
  17. If you were in Oz the EJ AWD boxes are good parts sources for everything except the pinion shaft, rear housing and the locking centre diff. If it's a 4 door RX I'd be checking to see if the box is actually the AWD or PT4wd. They're easily advertised incorrectly! If it's a two door RX it'll most likely be the AWD locking box. Personally I'd be keeping this one as we didn't get them over here ;( The spline count is 25 and the stub is larger than the standard 23 spline unit of the brat and base model loyales... You can make a suitable brat shaft - or swap the diff stubs with the 23 spline units from another PT4wd box. The real issue here is that you need to open up two gearboxes to achieve this. Cheers Bennie
  18. Has the lower Uni joint mount slipped down the shaft? Was the steering extension replaced with the engine crossmember? If so, try using your old unit. If the engine crossmember came from a legacy the steering extension is shorter than that of the Outback's. This could be the difference. Cheers Bennie
  19. Never seen them unless you're talking about the aftermarket RAM heads for light aircraft applications. Every other factory EA81 I've seen has single intake ports, including the turbo variants. Got a pic of this limited run dual intake port EA81 you speak of? Cheers Bennie
  20. It's good for flying with Jono! i hunk it's got a flat torque curve - an important feature of an aircraft engine as far as I know. Cheers Bennie
  21. The rear discs will swap straight on. the AWD box (with the locking centre diff) will require some mods for it to fit in - do a search on here for a how to guide. It's basically the same as the PT4wd dual range box swap. That RX - not an RXII coupe is it? If so the coupe might be worth hanging on to if it's any good The EJ22 wil be a good swap, but still hang on to the EA81T to swap back in later Or send it my way Cheers Bennie
  22. The '88 is a good ride
  23. And in English?? I don't understand why all the back spacers - what are they exactly?? why not run the EJ front struts, brakes and hubs? If you do the rears properly you'll be upgrading the brakes to that of the EJ donor. Best practice is to match the front brakes from the EJ donor vehicle. Cheers Bennie
  24. Skishop, the ea81s didn't have the twin port like the EA82 MPFI. The twin port bit usually referred to the exhaust ports if I'm not mistaken. The EA82S is said to be a real screamer and a few levels above the normal EA81. by the look of that engine you'll need the bell housing and oil filler neck as a minimum to fit it to a vehicle. Best of luck with what you do with it! Cheers Bennie
  25. Was the core exchange waviered? Best of luck with the install and first drive! Cheers Bennie
