151
Working out Bugs In the Breaks
el_freddo replied to NoStyle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Get an aftermarket gauge if you haven't already. The factory oil pressure gauges are only there for aesthetics, not accuracy! what oil viscosity are you using, this can have a huge effect on oil pressure once at operating temps. Cheers Bennie -
Brumby ea81 with ea82 spfi and turbo
el_freddo replied to bindiesel's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmmm... This think sounds tasty. You in Oz too since referring to the Brumby rather than Brat? The good news is that you've got spark etc. so hopefully it's either the firing order that's out or you just need to adjust the timing. And we definitely need pics of this setup/beast. Any internal work done to help with the longevity of the engine? Cheers Bennie -
First easy place to look is in the Haynes manual. Yes, there it is, I said it. I recall a picture diagram in there for the MPFI TPS. I couldn't tell you if there's a SPFI TPS diagram in there though. You should find the SPFI TPS pin out in the SPFI conversion document. My copy is in a box somewhere, but I'm sure there will be a digital copy on the forum or a link to it off site. Cheers Bennie
approprite r134a compressor for NA 1992 ej22
el_freddo replied to Eric Freudenthal's topic in Subaru Transplants
Just use the AC compressor that came with the EJ or get a later model Subaru AC compressor. With the compressor you have all you need is the r134a valve fittings and you're set. Cheers Bennie -
Need Rubber Hood Prop Thing
el_freddo replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I nabbed one of these units for Sunnie the brumby then cut off one retainer clip on the underside to slot it in the factory EA hole. Fits snug and doesn't move As for the rubber grommet, surely you could use a generic rubber bung of a suitable size with the middle cut out... Or nab a decent one from a part yard vehicle. Cheers Bennie -
I don't think the funnel is really the way to burp these vehicles without it being on ramps or taking it for a short spirited drive after a quick top off with the engine running. Thenback up on ramps, let cool off, top up again then run engine, top off if needed, cap on then go for a good drive that maintains highway speeds for a while if possible. Once that's done and it's cooled down again, check the coolant level and top up if needed. With the thermostat did you install it with the correct orientation? Does the upper and lower rad hose get hot? Do the Thermo fans cycle on and off? these are other factors that need to be known to help properly diagnose the issue. Cheers Bennie
- 10 replies
- blows cold
- no heat
(and 4 more)
Tagged with:
Instead of a new radiator I recommend creating an air dam under the front of the L series, starting below the radiator and ending somewhere near the engine crossmember. You can add flutes that face backwards to the air dam too, this helps in creating a low air pressure system behind the radiator which naturally draws air through the radiator, increasing the cooling ability of the radiator without needing to rely on the fans as much. I did this with my EJ22'd L series with a dual core copper radiator (Nissan pulsar unit) and ran it across the Nullarbor Plain in the middle of our summer, loaded to the gills with the AC cranked. It got to 44*C outside and the car ran steady on 93*C at 110kmph. The makeshift air dam allowed us to do this as my L seems to have issues drawing air through the radiator at speed. I don't know if it's the lift kit with a modified factory bash plate rather than a custom unit (on the list of things to do), but the MAN truck grille we found on the side of the road the the trick beautifully for our return trip home. I also wonder if those little pressed metal plates that reside under the radiator on each side actually contribute to this pressure effect. They're usually left off at some point in these vehicle's lives and could be a factor on a stock vehicle's cooling ability. Cheers Bennie
Digital dash I don't know as I've not worked with these before - is this in an L series or MY? I would think that the suitable gauge would work, but the temp could be reading so low it doesn't register even one bar. If you let it heat up to cycle the fans you might see some action on the temp gauge... Hopefully someone else will chime in on this to shed some fresh light on the digi dash "situation" Cheers Bennie
There's a yellow/silver (possibly with a grey/silver dot) wire from the ECU. You should be able to find it in the pin out diagram. This wire needs to be hooked into the tacho wire on the back of the instrument cluster. You could try tracing the required wire in the vehicle's loom that's closer to the ECU if you wanted. I tapped in at the round plug at the back of the instrument cluster. The tacho will read correctly since it's a 4cyl swap into a 4cyl vehicle. You're correct about the temp gauge on the EJ sender Cheers Bennie
Correct break in for new rings and bearings?
el_freddo replied to Downwash77's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here we go, my old man always told me it was to bed rings in and that regular small interval oil changes in the first 10k km were essential to remove fine metals from the engine internals to help reduce any permit ute wear on the mains and big ends... Anyone go yet another story about break in procedures? Cheers Bennie -
Just use the factory EA wire, it'll plug right onto the EJ sender no problems. I'm not sure what the EJ's wire colour is, mine's hanging in the wind. I'd recommend fitting an aftermarket temp gauge that will tell you the actual temp of the engine. The L gauge in the EJ sender will read weird and usually be low compared to the standard operating temp displayed by an EA82 sender unit - not that it tells you much by pointing off to no where... Cheers Bennie
Dual headlight conversion
el_freddo replied to ClassySoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You need the units from the L series to make it work. Afaik it's a bolt in affair then mod wiring for dual headlights. The ea81 models need the radiator support panel swapped from the single to dual headlight unit from what I've been told. Cheers Bennie -
Any transmission with matching diff ratio will fit and work so long as you stick with NA or Turbo gearbox according to your model. The clutch setups are completely different between the two. Or you can swap the rear diff to match the ratio of the new box. Or if you can find a rear housing it'll bolt up to the back of your gearbox. Most are 1:1 in the rear housing, but some are a funky 1:1.1 or something. I believe these are mainly turbo models, particlarly the earlier models. Got any pics to share on the box housing that's busted? Or is it internal? Cheers Bennie
1) needs new front struts. The old units are worn out and make that clunking sound over small ripples and bumps in the road. Replace the struts, get a wheel alignment and you'll be sorted. 2) inspect the AC belt for cracks etc and replace if necessary or just tension the belt up to reduce the initial slip that's causing the screeching. 3) replace the knock sensor and reset the ECU either by the battery dance (disconnect the battery for at least half an hour), then warm the engine up without touching the throttle for five or so minutes. Then go for a drive. You may find that the oxygen sensor will need replacing too. That should solve your issues. I reckon they're pretty small overall. Cheers Bennie
Difference between 3at and 5mt driveshaft?
el_freddo replied to greatdane66's topic in Subaru Retrofitting
With the 5spd you have to make sure the gearbox comes from a carb fed EA82 as these boxes will have the correct diff stub to match your EA81 drive shafts. If you get an EFI EA82 box it'll have the larger stub axles like the EJ diff stubs. Stick to the carb spec gearbox and you'll be right with the drive shafts Cheers Bennie -
Ej22 swap alternator wiring
el_freddo replied to Liftedimpreza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do a search on the forum, I'm sure it's been covered on here somewhere. Otherwise the next best thing is to study the wiring diagrams of both vehicles to work out a solution. You'll probably find the small wire is ignition switched and reference wire - so you could tap that into the ECU's power wire so the alternator is triggered with ign ON. but you have to confirm what that wire does first. Cheers Bennie -
Ej22 swap high idle
So what was the fix for those that may be searching about the same issue? Cheers Bennie
