153
My weapon of choice was an angle grinder. Very satisfying. Cheers Bennie
If the injector is clicking, have you looked at fuel pressure or the possibility that the fuel pump is dead? Cheers Bennie
As GD said ^ But... Only way around this and keeping the low range is to find an RXII coupe AWD gearbox. This box has the locking centre diff - you’ll want to find one that’s not flogged out from running different front and rear diff ratios or from dickheads doing rear wheel burnouts using the front hand brake. From here you can cut and shut the pinion shaft to have the 4.44 ratio diff. The crown wheel needs to be shaved to clear the low range gears too. The good L series low range of 1.59:1 will drop in once the crown wheel is shaved to clear. Then you’ve got basically the ultimate package - best low range, 4.44 diff ratio, locked centre for 4wdn and AWD on the road - especially good if you’re running the EJ22. Downer on this box is that it’s a custom build with few spare parts available these days. Over here I have the advantage of EJ AWD dual range gearboxes for the drive gears at the very least. It’s the centre diff that will have this as toast if it dies (I lock it whenever I’m on dirt to avoid wear). Not a simple task, and in the eyes of GD, not cost effective, go get a truck :p (sorry GD, couldn’t help myself!). Cheers Bennie
Is this the FPCU? (Fuel Pump Control Unit)
el_freddo replied to NuclearDeLorean's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks mate. I’ve not seen anything like that before - only the spfi system and that didn’t land in Australia either. Cheers Bennie -
@GeneralDisorder - what’s a “feedback carb”? Just a carb with an auto choke or something more involved? Asking as my ‘91 brumby has electric choke and a black fuel pump control module. I’ve not seen a blue one before. Cheers Bennie -
Sounds like an awesome score! I’m sure you keep it and use it much in the same fashion as your wife’s grandparents did. While GD will say not particularly valuable it will have that sentimental value through family ownership and will be a very cool old school ride Cheers Bennie
I did them as cheap insurance/maintenance. Both engines I did them on were 350,000 and 420,000km (not miles!). Cheers Bennie
- 23 replies
Retro fit power steering 82 GL
el_freddo replied to Faraim91's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I doubt it was the pump doing it. I know of several EJ power steering pumps operating MY/EA81 power steering racks without issues. Dis you run this rack without leaks previously? Cheers Bennie -
If you’re going to lap the valves it’s worth replacing the valve stem seals while you’re there. Cheers Bennie
- 23 replies
That alignment looks bang on Paul. Ive not heard of cam or crank sensors going bad. They’re just coiled copper wire wrapped around a magnet, they’re sealed pretty tight and there really isn’t much to go wrong with them (they also make good cruise control speed sensors for after market units!). Are the cam and crank sensors plugged in correctly/fully? I like NVU’s suggestion of the super junction plug pins. Although I’ve not heard of this being an issue it could be worth the 10-15 minutes to rule them out. Any codes from the ECU to share? Cheers Bennie
EJ257 will most likely have dished pistons to aid dropping the compression for boost. I could be wrong though, the difference could be in the combustion chamber volume build into the turbo heads. GD will know I reckon. Also: best to get a manual vehicle if that’s what you want. Swapping a manual into an auto can have all sorts of wiring issues leading to codes etc from what I understand. Cheers Bennie
- 23 replies
XT6 Transmision onto 3.0R engine
el_freddo replied to nazvwxt6's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don’t do it. The transmission won’t be up for that amount of torque on tap. Cheers Bennie -
??? Thats old school thinking with a distributor. TDC doesn’t matter with the cam belt fitment. In fact, the pistons are halfway down the cylinders when the crank timing mark is set properly. This ensures the timing belt is installed correctly in terms of crank position If you use any other mark to align the crank you’ve got it wrong. And if you’re using the arrow on the cam wheel that’s wrong too. You need to use the small line on the rim of the cam wheel on either side. One side will be free of valve spring tension, the other side will be held by/have spring tension acting on it. All the beat with it, I’m sure your issue is that the Cam belt timing/alignment isn’t correct. Cheers Bennie
87 EA82 Fuel not going through jets
el_freddo replied to 87GL606's topic in Old Gen.: 80's GL/DL/XT/Loyales...
To remove carb unbolt the four 10mm nuts at the base of the carb. If you’re going to strip the carb down, it’s a good time to crack that screw from its hold while the carb is still fitted to the engine. Cheers Bennie -
Oil is drained so for engine work such as HGs. Some engine stands make it difficult to balance an oil pan on the only bar that’s part of the structure that holds the wheels out the front of the frame. So it’s easier to drain oil in the car. If storing the engine I’d leave it in, same for swapping the engine into another car - do the oil change after you get the engine going in the new vehicle Cheers Bennie
You need to identify what that set of black plugs are then. Find a wiring schematic at go over it. I’ve only ever known one set of green, one set of black plugs. Can’t remember which ones to connect to read codes - I do know they all need to be disconnected when driving the car. In Oz we didn’t get those seatbelt thingys because we wear our seatbelts due to laws requiring us to, and it’s second nature when you grow up with wearing seatbelts. There is no doubt more wiring related to those sorts of systems that we didn’t get. Your check engine light will still do its thing, but test away anyway! Cheers Bennie
Remove the air filter housing to expose the top of the carb. You should easily identify the bowl etc from this view point. Remove the top of the carb via the screws to get into the bowl. From here blow out what you can with compressed air. Your issue is probably varnish blocking the jets from old evaporated fuel. A good last of compressed air should have it sorted. Or EJ it Welcome to the forum! Cheers Bennie -
Head gasket external leakage is another thing to check. We got a 2003 forester with unknown history. Swapped HGs for the MLS units as a precaution and so we know it won’t be an issue we have to deal with in the short term. Valve stem seals were done at the same time. Well worth the effort of putting the time and effort in when the car is new to you - then the “servicing” doesn’t have to happen randomly when needed - just at the appropriate intervals for the usual oil and filter changes with a general inspection to ensure there are no other issues to attend to (eg split cv boot). Cheers Bennie
Ok, but thread digging an eleven year old thread about the EA81 probably won’t help. Post an add in the wanted sub forum Cheers Bennie
It is when it’s flashing the model designation code and has no other codes to show. Glad you got it sorted. I was going to suggest that one set of connectors are still plugged in but you found them already. Only have them plugged in without running the engine for code viewing purposes. Cheers Bennie
Moustache bar insulator washer updates
el_freddo replied to Step-a-toe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I used an old conveyer belt. It was a bit tight but it works well. Everything is solid, no real new noises either. Gen3 Liberty and Outback’s could be another source on the rear end. I’ll check it out next time I’m close to Basil (Sister’s Gen3 RX). Cheers Bennie- 1 reply
- 1
