12
Everything posted by mikaleda
	In 81? I'm sorry but I've never seen any 81 with an ECM in any brand except cadilac. I can look this up and I think I will, I could beleive 83, but not 81.
- 29 replies
	81 definatly shouldn't have an ECM.
- 29 replies
	find out what your misisng, buy a cheap spark tester and when it dies plug the spark tester in and see if it has spark. if there is no spark it would most likely be the electronic module in the distributor or a coil, if it has spark then it is a fuel related problem and would most likely be a bad fuel pump.
	IIRC the 84 2wd california carbd cars had an ecu, im not familier with the turbo cars but this isnt a turbo, as far as i know for the NA motors in 83 there was no ecu
- 29 replies
	Good info, but an 83 brat doesn't have an ECM. The wiring may be differant on the car your talking about. It could be there so not a bad idea to take a look.
- 29 replies
	Brake cleaner would work better probably since it doesn't leave any residue unlike carb cleaner.
- 7 replies
- ignition switch
 - lock cylinder
					(and 1 more)
Tagged with:
	No problem just p.m. A mod for this forum if you want it deleted.
	This belongs in the subaru parts stuff for sale section, a mod will see it and move it probably.
				Quick question rear axle
mikaleda replied to ontherun987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just give it as much force as you can with a breaker bar and you'll probably be fine. Just don't jump on the breaker bar tightening it -
	No if its an old gen then most likely is an open diff
				EA81 Engine Coolant Temperature Sensor: Where?
mikaleda replied to Feanor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Someone replaced it with a two prong is what happened you have the right area, the thermo switch for the fan is also single prong and is in the radiator.- 8 replies
- Temperature Sensor
 - EA81
					(and 6 more)
Tagged with:
No that's the thermo switch for the fan, the temp sender for the gauge is in the intake, its a single prong sender, its fairly easy to find- 8 replies
 - EA81
					(and 6 more)
Tagged with:
	Like turbone said its the purge control cylinoid. To find a vaccume leak I use carb choke cleaner, on a cold engine only, spray along vaccume hoses and connections, EGR ect. When you spray where the leak is the engine will bog down.
	Ya usually If you can get it out a lock smith will rekey it for cheap.
- 7 replies
- ignition switch
 - lock cylinder
					(and 1 more)
Tagged with:
	Check out the subaru parts/stuff for sale section and maybe put up a thread in the subaru parts/stuff wanted section.
