Everything posted by Sweet82
Finally parted with my Subaru
Sweet82 replied to anonym00se's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So what Subaru's are you going to buy in the mean time? You can't just be "Subaruless". -
Kinda reminds me, I need to get a family photo too. It's just a problem getting all the Subies together:rolleyes: Lookin Good, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
Looks good! If it were me, I'd do a spray on Bedliner rather than paint. A single can goes a long way, It's tougher than paint and easy to fix. My .02 Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
Just plain scary. Why?
EA81 Tranny question 5spd into 4spd D/R casing
Sweet82 replied to s'ko's topic in Subaru Retrofitting
Sko, Swap the tranny with a D/R 5 speed, if you must have that extra gear. Keep your one piece 4sp driveline as the 5 speed one has multiple parts. I think the 4sp has a lower gear ratio than the 5sp? What are you trying to accomplish? Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester -
EA82 and EA82T: Whats the difference??
Sweet82 replied to 87RX's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If all your information is correct, the EA82T should drop right in as that would have been the original engine in the car? -
Same here, on the real long UGLY climbs, I power out.
I think the automatics would explode under some real Subaru type wheeling. I'd think gearing them down (if it could be done) would just aggrivate the problem of exploding the tranny.
The answer is NO, Sell them to me!
If it were me, I'd keep the roof on and add some steel tubing to strenghten it. I think your never going to regret the ability to have a sun block and storage space. I put a roof in Summer even though it added weight, I thought the benefits out weighed the weight.
Turned out better than I thought it would! A good solid skid plate and your there! Excellent work! Glenn
What about just making a beefed up skid plate and keep everything else the way it is? An angle of approach is only so good without the gearing to back it up? My .02, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
I saw a Lexus in Moab last weekend that someone had done much like your photo shop pic. It was way too flashy for my taste but it was an interesting idea. Your picture is missing roll bars? I'm sure they are in the plans, I just didn't see them in the picture? The Lexus had a roll cage...
So what are your evil plans? Inquiring minds want to know...
Going, Going.... Trip report to follow.
I wouldn't take "Summer" anywhere it was not suppose to be. I don't want the fish cops to seize it. However if it's not restricted (to ATV-Cycles) I'm good to go! Nothing worse than trying to ride a Cycle in a two track trail.
Relocating Oil sending unit?
Sweet82 replied to Sweet82's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Any idea what the thread pitch and size of the adapter/old sensor are? Short of buying a gauge or spare oil sensor what do I ask for at the parts store or fitting store? -
My Hatch, "Summer" is a 1982 Carter Weber and my box is black. My FPCU controls the choke as I have found out the hard way... I can "make" a blue one work but I have to jump a wire to the choke. The blue and the black boxes are wired differently.
Wait a minute.......... I thought my Subie WAS an ATV :lol:
This was touched upon in another thread, I'd like to move my sending unit out of harms way. If my skid plate moves enough, it could take out my oil sensor. I'd prefer a pre-emptive strike and move it while it's in good shape. Does it have to be mounted upright in its new location? Anyone have any specifics on what fittings & parts are needed to move it out of the area? (EA81) Better safe than sorry, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
LSD does not compete with the welded rear end. Not even close. Removing an axle or more likely installing an axle before wheeling is not a big deal. Driving with a welded diff is not as bad as I thought it would be. I have noticed a little more wear on my back lugs since I decided to leave my axle in all the time. If you weld the diff right...you'll never break it. You may break other things but the spider gears can't break if they are one big ball of weld. I have yet to spin a front wheel with the rear welded--even uphill around a corner on loose gravel while flooring it. Too much traction! Dual Ebrakes will allow you to transfer power to the wheel that needs it. If your back is locked, it won't slip even with a rear wheel in the air. If you have dual Ebrakes, you'll be able to apply power to the front wheel that needs it. Disclaimer: (because of my traction I have never had to use the Ebrake system yet) Glenn, 82 SubaruHummer--locked, Ebraked, tired--atv 84 GL Mad Max--still a virgin 01 Forester--yet another virgin
If your car was running normally before it quit, the FPCU you have is the proper one. If it is not putting out the power like it should then replace it with a FPCU with the same numbers on the box. Subaru used a couple different carbs and the boxes are specific to the carbs on the car. I'd check your system and find out where the 12v is stopping and the 3v is starting.
