Everything posted by nipper
09 Thread. Let's see your CURRENT lifted Soob.
nipper PS does the red brat come with a joystick?
end link ???
nipper replied to mike97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts is very obvious to see if it is broken. It may rattle when broken. You may not notice it untill you hit a really big crosswind or an emergency manuver. nipper
Important news
way cool nipper
Tachometer light
nipper replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subaruforester.org/ Look there as they may have the specifics on it. The only Forester manual I have is for a 2007, and I think that is too far removed from your year. nipper
No combustion - Carb replacement or other solution?
YOu need suck squish bang to get combustion. Right now all you have is what is required for bang. You need to do a compression test first. Without compression you can rebuild the carb all you want and it wont run. Also carb issues slowly appear over time, and dont suddenly occur with a bang. nipper
2003 Subaru Legacy Outback H6 3.0 VDC Wagon
nipper replied to anthonmas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlu has 245,000 miles on him and i conside him "middle aged" 125,000 miles your just past break in. Of course there is the flip side that we need everyone who can afford to to buy a new car, but if thats the only reason, your car has plenty of life left in it. nipper
check this out very interresting
nipper replied to mike97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyup, there is also a one for 2000 ish models due to the PS hose. nipper
rear wiper arm removal
nipper replied to 97obs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tried soaking mine, but I finally got the little 4.99 tool to remove it from the auotparts store and it popped right off. nipper
97 obs cel code p0720
nipper replied to crockettbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell i can do it the old fashioned way, im a nig fan of the postal system.
nipper replied to crockettbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi cant emali but i can do a file transfer via YIM or AIM.
85 subaru wagon clutch very difficult to depress
Clutch cable is going. Dont worry it will get really easy to press soon. Of course it will only go down at that point. nipper
dome light (life of its own)
nipper replied to sleepylegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo your telling him to use a peso? nipper
New Jersey Devil Chase
OMG a reasonable time? Do you feel allright?
nipper replied to crockettbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX168 mb for the file, will your mailbox handle that?
nipper replied to crockettbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi found a pdf sercive manual for 1997-8 does that help?
You drive me up a wall
Espically considering the first one i think was a russian lada the first one scared me to no end
nipper replied to sleepylegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey always blame the innocent dogs nipper
nipper replied to sleepylegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemove the switch and replace it? Just a thought. Sounds like a loose wire or bad switch. mipper
86' GL Crank Shaft Pulley Problems
Re you really sure you checked the timing? The hardest thing to bend is connecting rods, you really really really REALLY have to work at it, and it usually means there is a hole in the block to match it. piston rods are "connecting" rods. There is something else going on here, i bet the low compresssion is just on one side of the engine. Who told you about the connecting rods? nipper
What is this on the outside of the windshield?
nipper replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXer um, seems like someone bought into thier "marketing" though P.T. Barnum had a better way of saying it. nipper
nipper replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell is is much easier to apply window tint on the outside of the windshield (Trust me i know way too many computer geeks, that is thier logic). nipper
Something's going?
nipper replied to vincentmoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck tires, rear end grease, carrier bearing. Sometimes when you cant trace a noise you have toi wait for it to get louder to find it. nipper
Opinions 45k Engine or Headgasket Job?
nipper replied to roadsubiedog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnce again an important question, how many miles are on the engine. Also important a compression test to see the overall health of the engine. Years dont matter but mileage does on this decidion. Its always better to go with a known risk then an unknown risk. Also has this engine ever been overheated or cooked? nipper
nipper replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi agree with him
Something's going?
nipper replied to vincentmoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck the transmission mount and the carrier bearing. Any mysterious high speed (subtle) vibration that comes and goes? nipper
