25
Everything posted by nipper
Weird vibration over 55mph
nipper replied to Caramanos2000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sheesh my humor is just failing all over the place. I thought you offered to take a picture of the vibration -
Its funny, everyone says the same thing, that E takes 10 gallons. Blu takes 10 gallons on E. This is just too consistant to be a random failure or fouling of the fuel senders. E is the new ten Set your trip odometer and go by the low fuel light, but there is really no hamr in filling at E. Now if E took random amounts of fuel in all our cars, then i would be annoyed. nipper
laptop
nipper replied to mike97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
i liked my idea better -
laptop
or make it some sort of evil bionic extension of yourself? -
Your going to show us a fuzzy picture? nipper -
Er um RUN! timing belt and all the gizoms i have never paid more then 650.00 for. There is no connection. Many soobys run around with a weaping cam seal and they do fine. When the main seal or oil pump leak then they can get soaked. You would know it if you had one of those leaking. Just replace the knock sensor and keep driving. If the oil leak gets worse, get estimates from other shops for doing the TB, waterpump, tensioner, idler, cam seals, main seal and re-sealing the oil pump. this shop is more expensive then a dealer ! nipper
er um ..... er one hump or two?
Yes do a search. I think you just need to swap intake manifolds, but it is a common swap to do. nipper
loyale convertable ???????
nipper replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its people like you that take all the fun out of Youtube hehehehe Just make sure there is a video camera for the first pothole -
It does look like it. nipper -
Checjk your universal joints and carrier bearing. If its a universal joint you will notice that it will drop from 55 to 50 to 45 over time. nipper -
Abs?
nipper replied to JohnKos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
What kind of tires? nipper -
I had to check the manual on that as i wasnt sure myself. I did the clean with a pencil eraser thing for the sender. It helped, but didnt cure it. I do the techron thing once a quarter as maintanence. I just know that if its 230 miles on a tank its time to get gas. I can go farther but thats my comfort zone. Otherwise I just fill up on E (about 10 gallons). nipper
