Everything posted by TheSubaruJunkie
New camera... new pix :)
im not much for the sleeper look. the center support is painted black, but its gloss black so its still real visable. im going to use either wire mesh or bug screen behind the grill to hide all that. -brian
Lets try some silver 15" pugs for now. Then maybe some 15" rota Subzero's after the XT6 swap. -Brian
EJ-22 into 87 RX
You can adapt the Tranny to fit the EJ22. The main question is... will the RX Tranny handle the power the EJ22T is capable of putting out? -Brian
hahahaha... your the 6th person in a matter of minutes to comment on the rims. The rims come when the Legacy sells. I have a guy who is interested in the Legacy and will be putting a down payment on it in a week or so... when that happens I can order my new tires and go get my new rims. -Brian
Got a new camera yesterday since my old one broke. So in order to break it in, i took the RX somewhere to pose her for some shots... enjoy: -Brian
Pollock Pines California
We'll see I just want to play in some snow, i'll find someplace to go. Lookin like there's going to be a good downpour tonight and through the next day or two. WIll be perfect for Wednesday. -Brian
Whats this?
That'd be my guess. Either that or a ghost. You were probably shifting. -Brian
diy-drilled out chevy 6-lug
No subie will destroy a 6lug rim. 6 lug rims are designed for 3/4 ton pickups... our subies wont stress them that much.... even with 2 more holes drilled into them. -Brian
Suggestions on making my 86 Brat stronger for off road use......
IF all your traveling are FS roads, you have nothing to worry about. Focus more on carry'n spare parts, cause there are parts that will fail, but are near impossible to make stronger. Things that come to mind: Alternator Belts (alt & A/C if equiped) Front CV Shaft. Or a broken front shaft to install and limp home in RWD. Chain and/or strap to get towed out (you'll always want to "see whats that way") Also, things that are very handy to have in the brat are WD40, Carb cleaner, rags and of course... plenty of spare oil. Other than that, your brat should tackle almost anything you throw at it. We add lifts to add larger tires, not to make our suspension stronger. The stock suspension is strong enough. The Front CV's are the weakest point and there's not much you can do other than replace them. -Brian
State Laws concerning Engine Swaps
Russ... I may need your help. My friend who wants my EJ22T is set to believe he cannot use the Canadian EJ22T in my car since its not a CA engine. What do we need to do to get around this? From what I understand, the only difference between the CA EJ22T and a 49 State EJ22T is an extra ground to the ECU. I want to see this EJ22T in my friends car... also, would it being a '92 Engine going into a '91 car cause more red tape trouble? -Brian
Repost: EA82T, INJECTION vs. EA81, CARB.
Not just the powerband, but the high maitenance. Off-road engines are put to alot of abuse. Any EA81 will withstand the abuse, but with a turbo there are more moving parts, forced induction and alot more things to go wrong. -Brian
There should be plenty of snow left for the trip. I have a co-worker who lives there, he said he coudnt drive up Sly Park to the lake cause there was so much snow. Local news crew's have been broadcasting from P.Pines talking about how they're expecting to get dumped on. -Brian
I wouldnt suggest a turbo for off-road use. But if you have access to a EA81T you might want to use the EA81T heads with the MPFI system, and use a carbed block with increased compression. The MPFI will give you a much larger advantage for off-roading over a carb, but a turbo isnt always the right answer. -Brian
There's alot of snow out there... and Im hoping to find some in Pollock pines. I'll be making a trip up either Wednesday or Thursday and dont like traveling alone. Will need a support vehicle incase someone needs to be pulled out. Here's an idea of where i'm planning on going: -Brian
Big Lift For Forester?
If your going to go with a 8" lift, and turning 30" tires, you might want to have a divorced T-Case installed too. Not sure how tough the center diff on a forester AWD is, maybe look into having that welded shut to power the t-case better. The 1st guy who comes to mind would be Mudrat, for fabrication... unless you have the know-how. I also wouldnt recommend Alloy rims. You might want to check into some cheap steel rims which you can get in 15's too. -Brian
Boost Gauge install complete.
What i used was the LED that subaru put in the left side of the dashboard. It originally lit up the letters for my hazard button and the dial to control the dash lights. I used that light to light up my boost gauge. If my gauge had its own light with the wires, i would have just tapped into the wiring for that LED. I'd suggest doing that. If your gauge is near the center console by your stereo... you can find a switched 12v from the wiring for your cigarrette lighter, or the light that illuminates your ashtray. I use neither of those devices, so i used my cigarette lighter to control the Stereo i installed. -Brian
I hate this state with a passion. Even tho there are no differences between CA EJ22T's and Non-CA EJ22T's... the state still will not allow you to swap the engines. Since this rule apply's in California, the sale of my EJ22T has fallen through, and now im stuck with the car. -Brian
XSNRG Your Inbox is full AGAIN!
Make sure you clear all your sent items along with your inbox! -Brian
EA82T Hesitation until boost.
If it gets severe i'll start adjusting sensors, but right now im going to K.I.S.S I'll clean the MAF out, probably should while im installing the intercooler. Russ, the distributor cap and rotor look very new. Did you replace those when you put those wires on? If they are NGK wires then i'll trust them over pretty much anything (but have heard good things about Magnacore). -Brian
front strut removal
I have a screwdriver ive modified to use as a wedge with a handle pretty much. It works great for spreading the strut alittle to help removal. This was taken while installing a lift kit on my 84 Wagon, but I assume its about the same as a '88 RX. Might be easier to remove the strut from the knuckle than destroying your balljoint trying to remove it. Definatly unbolt the swaybar -Brian
Intercooler is here!
I'd preffer to have it plumbed back in. I want to try to keep the car as quiet as i can.... ...ah, who are we kidding I'll have to try it out. -Brian
Find a hose that comes from your intake manifold. Cut it, put a T in it. Then run hose from that T into your dashboard. Mount the gauge somewhere and attatch the hose to the gauge. Done The gauge i got had no mounting hardware or any threaded inserts to mount it anywhere. I used a hose clamp, stuck the gauge through the board which its attatched to... then put the clamp on the gauge behind the board to hold it in place. -Brian
So i got...
Good idea. Maybe i should do something like that. Let us know how it turns out. -Brian
A quick Q on 80-84 interior
High consoles are usually found in GL's with Power windows. They used the front end of the console to house the window switches. I put one in my wagon, and made a new plate to hold switches for my auxilary lights: -Brian
Subaru Vs. Bolder
TheSubaruJunkie replied to hush777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX25-30mph would have no problem causing that much damage. Expecially if he hit a boulder. -Brian
