Everything posted by Scott in Bellingham
- I'd like to try to make a side by side buggy.
Lifting the front of 84 wagon question
2" you will also want to lower the engine crossmember as those EA81 axles don't hold up under all that lift, I can make the parts for you
key copies 2002 Forester
cool no cjip, no it wont turn, must just be a bad grind
I went to get a key copy for my 2002 forester, and the copies don't work, is they something more then a key blank? is it a special thing with a chip ?
Wheel Adapter 86 Brat
those look nice, I can redrill your original hubs with that pattern heres my link www.sjrlift.com under Misc
Walker Valley Fall Trail Run.
Ted hows your car equipt ?
Lifted 99 LGT tire size?
235/75-15 is about the largest you can go ,
1995 Legacy Wagon Offroad Mod Tips Needed
outback or forester struts will give you the clearance you need for bigger tires
Scored a lift kit the other day...
I do sell the EA71 kit for the 1st gens its just not posted at my store
Walker Valley 10/25/14
I may be up to that
Hey from the Netherlands and Yugoslavia!
one thing you may run into if using a Subaru layout like a EA82 or a legacy is the hood length is quite short on the Yugo compared to this layout, I ran into that problem when I wanted to do a Justy body with is similar to the Yugo , just not enuff room in front of the axle
My 1991 Turbo legacy, and a trip
10 + years ago I sat in the pilots seat in the Spruce Goose, they had just set it up and my Father had helped work on it and he got us in , cool history
Anyone recommend cv joints for a 4" lift?
if its the front check your moter mounts and tranny mounts, My SJR 4" lift comes with all 4" so its a Body lift, keeps CVs is stock Geometry
New Lifted Wagon at Walker Valley
thanks for n sharin, let me know next time you go out, Im itchin to go
I can build and or provide you with what you want and need, Ive made a few buggy/modified subarus , I can do it all or just provide some parts and advice or anywhere in between heres a link to some pictures https://www.facebook.com/media/set/?set=a.1694996414059253.1073741841.100006467321842&type=1&l=af9cb242d3
Plastic EA-EJ adapter plate?
the EJ-EA adapter I sell weighs less then 7 Lbs, its 1/2" Steel
plastics ok ,I don't have a recommendation on type , on the upper studs , do the welded together studs so the plastic is ONLY under compression
- new project
Toyota axles with leafs and a tcase?
will need a subframe of sorts,
Homemade Transmission Crossmember
I used a 1 x 2 , this was on a EJ car
Starting the journey to find a Brat.
where you located?
