Everything posted by Scott in Bellingham
Trying to keep busy! (Weight reduction)
heres the car https://www.facebook.com/photo.php?fbid=1694996420725919&set=a.1694996414059253.1073741841.100006467321842&type=1 https://scontent-sea.xx.fbcdn.net/hphotos-xfa1/v/t1.0-9/s480x480/10606355_1694996427392585_69599585287450966_n.jpg?oh=e01dbeba6d5ba17422b84e55cecb2698&oe=55CF699A
Big Summer NW wheelin trip?
Browns camp is a nice place in NW OR
I like to bob the rear on the wagon on a committed offroader, easy to do removes a lot of weight and gives a better departure angle, my present lightened soobie has no stock glass and rear bobbed and no stock doors a bar with sheetmetal you jump over , really makes a difference OH and add a EJ22 that makes a big difference, Ive done the dash removale route and didn't like it, it just didn't feel the same driving the car with loose wires and sheetmetal in front of me
- Anyone ever moved the front axle forward after a dual tcase lift?
I had the same problem from grass, we spent the weekend driving threw tall grass and it ended up doin the same thing kept the pressure plate from fully closing and slipt
1999 subaru legacy wagon lift
3"YOU will need a complete lift kit found here www.sjrlift.com . the struts will only get 1-1-1/2"
Fitting 235/70r16 tires on a lifted 99 legacy
235 /75-15s fit
- SJR 10 Year Anniversary , Bringing back my Original Alloy Aluminum LIft kits
4 lug redrill for my loyale
I redrill hubs 6 bolt and the common 4 bolts see here www.sjrlift.com
lifted loyal help
rear diff support (mustache bar) is held to the body with 4 bolts, just add a 1" spacer between the body and bar mount like a length of 1x 1-1/2 tubing with 2 holes in it, on the front is similar same tubing between engine crossmember and body, will need longer bolts also will need a longer steering knuckle
lifted loyal help
looks like a 2" lift, all suspension , you can drop the rear of the rear diff 1" at the mustache bar, also drop the engine crossmember 1" that will help with the axle angle
Its been 10 since years I started up SJR originally SJRLIFT, my first car I lifted was a red and silver 88 EA82 GL Wagon make a Alloy Aluminum Lift kit for it. well to help celebrate my companies 10 yr anniversary Im bringing back my Original alloy kits , some of you may remember them or even still have one on your car, Ill be posting more details soon and show them at my site www.sjrlift.com, along with this year Ill be introducing some new Alloy products as I develop them , in the works are, Weber to Subaru carb intake adapters, cool artsy rear diff drops, 1 Piece a-arm/tranny lift block to prevent captive nut tear out, also will offer personalized artwork and lettering on the alloy parts you order from me so you can customize your parts with your own logo art or lettering Scott
what did i find?
Gen1 rear suspension
lifted loyal help
Let's see some pictures of the lift blocks and axle angles, on a 6 in lift should have 4-5 in blocks on the engine and rear diff
2.5RS Impreza Buggy Build
Luv it, Good work !
Selectable Front Hubs
lets see what you came up with
Throw out bearing for ej swap
use all stock EA82 parts , you just need a redrilled flywheel and a adapter , I sell them here www.sjrlift.com Scott
redrilling ea82 flywheel for ej swap questions
I provide this service at www.sjrlift.com a normal drill will not work, I recommend a endmill
intake and throtle body spacers
let us know your finding, I like the idea of more low end
- NWWO Walker Valley ORV Holiday Run Report
super swampers
the tread on those Bias tires are so deep, just matters what your going to do with it, deep big cleats are awesome if most your miles are on the road Id go Radial
NWWO Walker Valley Holiday Run Dec. 27th
Im out got a Family Chritmas thing
Ill see what I can do
