subie94
Everything posted by subie94
  1. what about high centering it? that's why you don't slow down,just gas it.
  2. please turn around.i could see if you were actually in a rally.
  3. wow so many for analog.Hmm.....yah i'd have to agree with others. i've had digi before an no sir i didn't like it
  4. last winter,my cable scared the sh*& out of me.driving to work then all of a sudden this very loud screech!! i was told because it was so cold out(single digit temps) the speedo cable being just a very long spring.any amount of moisture froze an caused the noise or something like that(was awhile since i was told this,so i might of forgotten something) did your speedo needle bounce/shake some.next time you drive an get the noise.keep it at a steady mph and watch needle.(if it isn't the cable causing the noise then it should stay even with whatever speed your at.if it is your cable then needle will bounce an shake some.
  5. maybe speedo cable? disconnect at trans and run some oil down it,see what happens btw,how's your knocking/ticking? i got my ticking taken care of(loose plugs) but now when i start her up after sitting over-night she knocks untill she warms up.almost sounds like piston slap.but sound seems to be coming from back side of engine :-\ Hmmm...
  6. you'd be surprised how well those disposable cameras come out.you could get some of those too.they even come with a flash for a'lil more $
  7. probably open diffs,they don't transfer power to the wheels that don't slip to well. as far as abs light coming on.system prob though there was a prob with the brakes cause two wheels were spinning and bk two weren't.i've had it happen when i got high centered last winter.
  8. the j/y in the next town over,they want about $25. per strut assembly. as far as tire size,i think you could squeeze in 28's if you do some trimming and hitting.
  9. yes,it is so fun to watch stupid people do stupid stuff. i know subies can take some abuse,but what their doing just isn't right.that's my opinion.
  10. is it dented on the corner.then i read somewhere here that if you have them remove the bumper or cover and use a heat gun to warm or heat up the area around the dent,they can (pop) the dent out. read it here-http://www.ultimatesubaru.org/forum/showthread.php?t=46989
  11. i found out that one of my sending units was acting up(when i first picked up the car) guage was working fine then (boom).dropped to e,then about acouple miles down the road,guage comes back up.found out that the contact strip on unit had a dead spot.
  12. man i wish you had a lay-away being out of work sucks.granted i do have the skid-plate from 91loyale.but yours looks so much tougher then stock one.(which it is,i sure)
  13. so we gonna see some of that video footage? awesome pics,looked like it was a blast. i guess i'm gonna have to move.
  14. mine's tinted (30% i think) this one is 5% back two side windows,30% other four.
  15. http://www.ultimatesubaru.org/forum/showthread.php?t=44587&highlight=torque+bind some reading here might help you out.
  16. simply awesome looking paint job and brat
  17. then if it is ticking then i'd see if you can find the bad lifter yourself.unless you wanna pay money to someone to pull off your valve covers.
  18. ok then like before,that's most likely all your gonna get from one of those. should sound interesting when the turbo kicks in though stinks i can't put mine in my leg,abs pump is in the way.unless i cut the intake tube shorter. Hmmm.... :-\
  19. maybe austin should of used something stronger then,like steel (but then weight comes into effect)
  20. sounds like torque bind.did you change the trans fluid? i haven't had the prob but i have read that sometimes changing the fluid to new helps.
  21. Error GROUP_CHECK that's what i'm getting if i click on the x in you post
  22. is it gonna be a universal cone filter? i did the universal cone deal,i used the stock intake tube and only thing i noticed was a change in throttle response.(an sound) $50 bucks+throttle response and sound=i was happy with it. here's a pic
