Everything posted by lmdew
1996 Legacy Possible Air/Gas Mixture Issue.
lmdew replied to Havetolearn4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck to see if the large 1" dia hose going from the Air Box to the Idle Air Control Valve is connected. It usually comes off when the air filter is changed or top of the air box is removed. Use a Subaru MAF! NGK copper core plugs are best. How did the plugs look that were removed?
96 Impreza power steering gone/weak after pump rebuild
lmdew replied to lowbreaker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have several used pumps. $20 + shipping. Flat rate Large box.
Question regarding engine swap for a 1999 Subaru Legacy Outback
lmdew replied to Njclark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've been very happy with the 95 2.2 swaps I've done. www.car-part.com still shows some low mile engines. 96-98 2.2 will work but require a single port y pipe. Watch for EGR configuration for plug and play the 95 2.2 with matching ERG is great.
Trip prep reminder
lmdew replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you are in Colorado Springs for a few day you might be able to get in to see Casey at http://resolve-therapeutics.com/. She does a great job on my back after long flights.
Iridium spark plugs in a 1990 ej22?
lmdew replied to darsdoug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRecommended NGK Copper core!
Center console won’t close 94 Legacy
lmdew replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you get the center counsel working?
lmdew replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould have had another cup of coffee. Bus crossed a double, double yellow line turning into a gas station. Said he never saw me. I'm here. Any Day you can get out of bed, have a hot coffee and shower is a Great Day. If you make it to the end of the day and have an IPA it's even better!
lmdew replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood PT and yoga have helped me! 2014 head on motorcycle to school bus accident, at 60 mph made me a slow moving vehicle. But hey, I have all body parts and still get around.
lmdew replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHope all goes well. You can pull the lid apart and remove the struts from the piviot point. As noted, there is nothing under the counsel that would stop them from moving. Is something in the hinge?
adjust windshield washer squirter
lmdew replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you get a small pin, push pin works well you can put it in the hole and move it. It's a little ball and socket.
Coated (not painted) Rotors?
lmdew replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are shops that still surface rotors, just a little harder to find.
2004 Impreza 2.5 Auto woes. On 3rd transmission puhlease help! (Now with pictures (and video)!)
lmdew replied to Rockstaar1226's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLoadpro if you are reading voltage your meter can lie to you unless the circuit has a load. Loadpro makes it easy to check the wiring, Opens, Shorts and High resistance. https://www.aeswave.com/LOADpro-Dynamic-Test-Lead-p8955.html
lmdew replied to Rockstaar1226's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have a good Subaru/Transmission shop near by? Might be worth having them take a look. At least you could get an idea of what's up. A friend had a 2013 Legacy that was giving him some issues. Shop said a Speed Sensor. I found a good PDF and he went to the yard and pulled the sensor. Swapped it out and all good so far.
Subaru Forester evaporative emissions canister solanoid
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've changed and pulled them from several 96-99 Legacy Outbacks. Rust free CO, easy as can be. I have not done one on a Forester.
Remove sway bar endlinks? Busted anyhow.
lmdew replied to uniberp1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are there for a reason. I'd keep them. You never know when someone pulls out in front of you.
Strut broke through into rear compartment 1997 Legacy
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad you got it!
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAuto? spoob lock can be manually released. Manual, have someone rock the car while you try shifting it.
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoth Auto and Manual you should be able to shift at the Trans. Could also disconnect the driveshaft. That would take care of the rear wheels. Put it on a dolly and haul it away.
1995 Legacy 2.2 engine only with OEM ECU in Limp Mode
lmdew replied to STEVEN BORNHORST's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have the connectors in the harness to put it in the diagonsitc mode?
Transmission does not engage gears
lmdew replied to kevsev7k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrop the trans. Inspect the Clutch side. Test the trans. Replace as needed. As someone said earlier, check the trans gear fluid when you drain it.
Couple Q’s about EGR and 2000-04 Legacy 2.5
lmdew replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA few cold IPA's and I would have headed out to help.
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a rust free body! One of many problems to surface, I"m sure.
lmdew replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI didn't know you were coming out to CO.
rear diff leak on my 02 Forester :(
lmdew replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr ready to drive https://denver.craigslist.org/cto/d/denver-subaru-forester/7384107596.html
lmdew replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere you go. This one and your parts. https://denver.craigslist.org/cto/d/denver-2001-subaru-forester-needs-case/7384135294.html
