Everything posted by lmdew
95 Legacy LS. I want to rebuild my All Wheel system
lmdew replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a good set, that I was going to send to the recycle center. I just pulled them out of the attic the other day. Good basket and clutches. Your's for the shipping and $10 for my time boxing them. PM me with your email and I can send you some pictures.
'97 Legacy - Troubleshooting cooling fan
lmdew replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have some spare fans if you need one. I'm in CO 80919
93 legacy over heating. Ive tried everything
lmdew replied to Wet cat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReseal the breather plate on the back of the block. You should have the aluminum one already.
Back Glass
lmdew replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com Used. If you have a You Pull and Pay do it yourself.
lmdew replied to Wet cat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a used lower mileage 2.2, put all your new timing components on it and for less than $400 you'll be up and going.
94 ej in Vanagon dies w/o notice
Check out LoadPro and load the circuit when checking voltage. You may be reading 13vdc - Battery voltage with no load but if you have poor contacts or green stuff in the wiring it will not carry the load.
2005 to Present SUBARU ATF
lmdew replied to WCEB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAmsoil made a significant improvement in my 2000 Impreza Trans with high mileage. Great ATF.
- 99 Legacy won't run with MAF connected?
2000 Impreza Instrument Cluster Clock Repair?
I've had several Impreza with the clock up in the instrument cluster. When the clock goes out is there a repair. I've searched but did not find a repair on the USMB or Web. Lot's of info on the Forester and center in dash clocks. Thanks, Larry
Manual 1999 Forester No Lights No start,No Fun,Its a Bummer!
lmdew replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI"d check for voltage with a miltimeter at the Fusebox in the engine compartment, under the drivers side dash and at the starter. If you have battery voltage at all those locations, with the meter on the starter have someone turn the key to start, does the voltage drop?
lmdew replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have an aftermarket Security or remote start unit on it? Have you checked for voltage at the fuse boxes? What caused the battery and cable change to start with?
Can an injector leak this much?
lmdew replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight on the passenger side fuel rail on the back. You have a new one on the way. There is about a 2" fuel line that connects it to the fuel tubing. If your fuel line is in bad shape, replace it.
lmdew replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXParts shipped.
2000 Impreza OBS Fuel Smell
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo other leaks. GD had noted he had changed several for fuel smell. Thanks GD and USMB!
90 Subaru Legacy 2.2 not turbo automatic transmission problem
lmdew replied to AKLegacyGL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the pan is dented up, fix that first. Drain the fluid, drop the pan and straighten it back out. The external filter kits were on some Subaru's. You'll find the filter up on the Driver's side of the engine compartment. The screen in the trans is just that, it's just a screen. No need to change it. Grab 3 or 4 gallons of DEX III, Walmart is fine. Drain, Fill, and pull the upper trans coolant line. Run a temp line into a gallon jug. Start the engine, let the trans pump out about 3/4 a gallon. Turn it off, fill the trans, repeat until the fluid is coming out clean.
lmdew replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have plenty of good used Red Injectors. How's $40 shipped. If you want the rails as well, I can ship them that way. Have you back on the road in no time.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey installed with ease and seem to be working well. No more fuel smell. BECK/ARNLEY 1580893 Time will tell.
transfer clutch pack replacement
lmdew replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso check the Rear Diff. If one of the axle stub shafts popped out a bit, all of the power is going no where. I've had it happen more than once. The hardest part of the clutch pack is getting all of the old gasket material off the tail shaft flange. The C-Duty wire is very short as well. Don't pull off the connector.
Starts with AT Temp light on and torque binding
lmdew replied to ncmrtnsn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you putting in Fluid in on the Drivers side behind the Starter? The dipstick/fill tube is kind of hidden. If you fill the passenger side towards the front of the Trans, you filled the FWD Diff with trans fluid. Drain it and refill with gear lube. You are not the first to make this mistake.
Lifted Impreza sway bar link idea/question
lmdew replied to comatosellama's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as the link is there it doesn't make much difference what it is. I'm sure the newer styles would work. Same length side to side and strong.
Head Gasket Job
lmdew replied to L5wolvesf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX95 2.2 swap. Cheaper and will last a lifetime.
2004 Forester moon roof
lmdew replied to carmen5184's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHit a you pull and pay and grab the complete unit. Have to drop the headliner. www.car-part.com
Subaru windshield wipers running backwards after replacing the wiper transmission
lmdew replied to Impress owner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo you replaced the motor and left the wiper arms on the shaft. The easy way, I'd remove the wiper arms. 14mm nut. Then turn on the wiper motor and watch the arm shaft. It should be normal. Turn off the wipers and then shut down the car. The arms can be installed in the park positon.
Instrument panel swap?
lmdew replied to jhammy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe panels do swap for the most part. There are some year to year differences on the plugs on the rear of the gauge cluster. I've changed lots of panels in the 95-2002 range sometimes because a speedometer failed or the clock was not working... If you have a different panel that is not an indication someone did something wrong.
Headlight adjustment
lmdew replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull your car about 4 feet away from f flat wall and straight ahead. Turn on the lights and start cranking the two adjusters. You will see the beam move. As you move the left to right adjuster to move the light beam in or out it will also adjust the vertical some due to the design. Inner lower adjuster is for in and out. Top adjuster is for up and down. As you move one it does affect the other some.
