Everything posted by Qman
Lets just say Im interesting...
LOL, funny... I am sure Dave is glad so many of you do nothing to your wagons. Makes it easier to win best wagon, best swap, best GL...
2001 Forester Engine Woes - yep, me again...
Qman replied to Susie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStumbling, rough idle, sparatic condition are symptoms of a dirty or failing MAF or MAP. It could even be as easy as an intermittent vacuum leak. Does the power loss ever happen at other times other than up hill? Could be as suggested earlier as a failing catalytic converter.
Hatch Patrol/NW Washington Offroad Group/Older School Meet
Option #1 is the only way. Anything else would be sketchy at best during the summer cutting season. Besides, if you had any issues along the way help would be passing by you instead of trying to find you.
Reprogram of ECM
Qman replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe term "reprogrammimg" may only mean that they are going to clear all previous codes. Diagnostic fee? I would suggest that you find another dealer or Subaru specific repair shop.
Torque sequence for cam bearing caps
Qman replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 2000 Forester Engine Problem
Qman replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the beginning stages of a bad MAF. I have had two go bad in the last year. They all gave similar symptoms before they went bad. The last one had pinging, rough idle and missing. Assumed the knock sensor to be the culprit. Not the case though. The MAF finally threw a code right before it completely crapped out. You might try cleaning it but it sounds like replacement is needed. Throwing parts at it is very frustrating. Definitely not the way to go. Do you have a friend or board member that lives near you? Better to try a known good one before buying a new one. Though, I believe yours may only be around $50-75.00. Good luck, this type of thing can be very frustrating. Don't give up on it though.- Torque sequence for cam bearing caps
Qman replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMiddle out, inside out, with a torque of 13 ft lbs. It is aluminum and you can pull the threads with too much torque. I also add a touch of anti-sieze to the threads of each bolt, out of habit.- Car Carrier
While I agree with Shawn I also disagree. Being a racer myself the "luxury" of a trailer to haul the broken car home is always better than the alternative. I might also suggest that you look into getting a motor home and trailer. It will give you a lot more room on your trips. It makes travelling so much nicer. There is a larger fuel bill but no room fees. It sort of offsets itself. I nice 18-20 foot trailer can be had for $1000-2000 used/new if you shop around. What sort of racing does you husband do? Here is a decent looking one, http://phoenix.craigslist.org/evl/rvs/1177782033.html- Got the Touring Wagon!!! Pics pg.4
Rick, don't you mean they are sort of rare? You have only seen a dozen in the last few years? I mean, you see an average of 5 wagons a day or more and you only have seen a dozen in 2-3 years. It's all in the perspective... half full or half empty... lol!- how bad is the ej25?
Qman replied to wfothrottle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat has to be the most rediculous thing I have ever seen you write Gary. EJ25's do not overheat and blow head gaskets. They leak through the head gasket, the owner neglects them and they run low on water and then over heat. I am really tired of all the EJ25's suck, they are garbage replace them with a lesser engine replies. The only issues they have had are the seeping headgasket issue(resolved with updated HG's) and piston slap when they are cold. They are very reliable. They produce good power and decent fuel economy. They accept mods easily. The only reason they have a bad rap is because the same people who tell users to search for the answers themselves do not. If it was such a bad design I doubt the manufacturer would still run the same displacement and design today, some 15 years later. But, don't let me stop you from throwing out those horrible 2.5's. I love getting them cheap and swapping them into other Subaru's or selling them to people who put them into sand buggys and other offroad rigs.- HLA Bleeding Question
Qman replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGenerally, if they make noise there is another issue. Usually, it involves the oil pump. Delta Cam does have new lifters available at about half what dealer charges. You should pull the pump and check clearances between the gears. If that checks out make sure you have a good set of gaskets and o-rings and then consider replacing the lifters. They will not bleed off and not pump back up if they are good.- Exhaust for my '97 Legacy GT??
Qman replied to anwieczo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1, one of the first performance mods on a N/A Subie should be the exhaust system.- ej25 to ej22 swap question
Qman replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you detail the swap a bit more? Which parts did you use? BTW, the car senses the "Honda" bond and is now retaliating!- Delta Cam BBQ
'67 SS 375hp/396 It is absolutely gorgeous. My Mom had a '67 SS convert 375hp/396. She got rear ended by some girl in a '78 Toyota SW and totalled it. Such a sad day and waste.- Delta Cam BBQ
Yeah, pay no nevermind to the full 442 running gear plus the built motor... Do not hate on the wagons Flow... One of the only people to rallycross an EA82 wagon... religiously, BTW! And one more. This is one of the nicest black paint jobs I have seen in years!- Delta Cam BBQ
Sure, I'll pick you up at the airport. Maybe get them to pay it as a business expense.- Delta Cam BBQ
Sorry for the short notice. Thought I had posted it already. Sunday, May 24th, 10AM to 4PM. Burgers and dogs. Cars to see. Briing your favorite car and hang out. There will also be a cam grinding seminar. The first 2 people to respond(posted on other forums too) with 2.5 SOHC cams wil get the grind of their choice for $50.00/cam. One session at 10AM and one at 1PM. Delta Camshaft 1938 Tacoma Ave S Tacoma, WA 98402- So, i found the source of the rattle.. doesnt look good.
Qman replied to shortskoolbus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt did... to anyone who is not a certified mechanic.- So, i found the source of the rattle.. doesnt look good.
Qman replied to shortskoolbus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat, did you do it? That kind of statement adds nothing to the topic. Someone probably did as you describe. But the rest is out of context. Although, I would be more apt to believe someone rested the car on a jack stand there. All hoists I have seen have rubber pads designed not to bend over the metal.- What is this Broken Pipe near the injectors on my EJ18
Qman replied to sub_dont_touch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRepair it and see if it cures your no start condition.- Hatch Patrol/NW Washington Offroad Group/Older School Meet
Here is a pic from another site as of 05-03-09- '82 Brat: Solid Axle Build *** DONE! :) ***
Trust me, with the motor that is in there it already is "KILLER"... I know cuz I helped build it!!- '82 Brat: Solid Axle Build *** DONE! :) ***
Wow Mick, that turned out really well. Have you figured out articulation numbers yet?- Subaru Lift Kit, Wheels and Skid Plate Group Buy
No worries... everyone is new once!- SpeedySubie Decals Coming!
Rob, if you want something from a business you must contact them. - 2000 Forester Engine Problem
