Everything posted by calebz
Are they different tires than the ones that were on there when you put them up for sale in the marketplace?
Last one we did, the car was left with only body, glass, doors and dashpad.. everything else went on the shelves.
really bad miss fire!!!!
calebz replied to offroadsubaruguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Similar situation recently in my turbowagon.. turned out to be the MAF -
No BS.. its true.. Motor needs to be lifted to remove the crosover pipe on a turbo. Its not that big of a deal to lift the motor a little.. 2 14mm nuts(not 10mm as stated in other post) EDIT.. just noticed the other threads.. your answers are there.
Sooo.. what did you do to get the rear pieces to fit?
New to the Board from Montana...:D
calebz replied to mentis's topic in Meet n' Greet. Your USMB Welcome Center
87 GL-10 Turbo here (mostly, its also part 86, 88, 89, part peugeot, mazda, honda and mitsubishi) Welcome. Theres much knowledge to be gained here. -
Noise on turns
calebz replied to ascus4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Possibly a binding problem.. check to make sure all 4 tires match size/brand/tire pressure/wear -
Inexpencive parts for a 1988 Subaru Gl
calebz replied to danman9y's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Same here.. I have an 88 thats going bye bye soon.. let me know what you need and I'll check the stash. -
Here's an EA82T http://usmb.net/albums/albuo11/Car_001.sized.jpg
You're more of a man than I am.. I hacked a hole and stuck on a premade scoop:)
Oob. Maybe try something like this http://usmb.net/albums/albuo11/ebay_010.jpg
Those blocks are supposed to be only 2 inches. Its OK.. It does change the driveline angle a little, but not much. Also, I don't recall the struts being any harder to get back in place, but its been a year since we did it....
Ice will form.. quickly Cold air good.. Ice bad.
I'm back, an apology, and stuff...
calebz replied to oobnuker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome back.. you're in good company -
If you ca'n't weld aluminum, or find someone that can, you're stuck. At least with that style of valve. If you could find a flush mount, like the WRX BPV, you could get away without welding anything.. but it would take a lot of sealant. Added note. If you are running stock boost, the BPV is unnecessary.. if you are much above stock boost, you should have an IC, which will change the way the BPV is plumbed anyway.
wheel & lug pattern question...again
calebz replied to the goat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Theres a couple of people that have redrilled their hubs to 4x100.. wider aftermarket selection that way. -
One option is a MegaSquirt/MegaJolt type setup.. Do away wth the nedfor the soob ECU altogether.
Hell yeah vicky! New cars are for people that can. New cars are also for people that want a good warranty. Most people that say new cars are for suckers have never owned a new car and have no idea how nice it is to just have it taken care of for free if something goes wrong. Theres also a bit to be said for knowing that no one else has beat the crap out of the car but you;) Just be sure you buy the car from a dealership with a good service history.. if the service at the closest Subaru dealership sucks, it might be worth it to drive to the next town or whatever to buy from a better dealership.. We have people from Austin that drive up to Dallas to have service performed on their soobs becuase the dealership down there sucks.
This board is the single most complete in depth source of info for swapping trannies. A quick search should yeild some pretty enlightening results.. Lots of us have done it, myself included. Heres one http://www.ultimatesubaru.org/forum/showthread.php?t=15648&highlight=manual+swap Some info about neutral safety switches http://www.ultimatesubaru.org/forum/showthread.php?t=15153&highlight=manual+swap
Its kinda strange.. When my 87 EA82T ECU went out, I had to replcae it with one from another 87.. I had one from an 88, but it had different numbers.. I tried it anyway and it didn't work(it did work in the car it came out of however)... On the other hand, when I was recently working on diagnosing some preoblems with an 88, I tried my ECU from my 87 in it(again, different numbers) and it worked. I have heard you can use an N/A ECU, but only from an MPFI car.
