Everything posted by calebz
LSD? am I halucinating or what???
Yup.. limited slip.. and the had a little tag on the back of the diff cover that states what the gearing is(3.7 or 3.9).. if it is an lsd, it says... get this...... . . .. . .. . . . . .. . . .. . . . .. .. . LSD! :D
84 Subaru 4WD Turbowagon
Good eye skip. I missed that(brain didn't process the info)
Anyone tried the Khumo Venture MT's?
Coopers website doesn't list the S/T or STT in a 14 inch.. lame. I think they look cool.. would work well on my wagon here's the stt
Question on 1986 gl D/R sedan.57K miles
hmm.. not the first time I have been wrong.. I think its the second.
HELP! im broke down
the death of your flashers and windows is a new thing?.. check your fusible links.. on a wagon they are in a little black box by the coolant overflow tank.. sorry.. not sure where they are on an xt
before replacing it, try cleaning the contacts on it
I got in trouble
its beeeyoootiful:D Much prettier than what the monk, okami and I found at the yards last saturday:D
Thats kinda what I thought..never heard of any other pre-87 spfi's .. 2wd or otherwise. And I don't recall that the 86 fsm makes any mention of them either
possible wheels?
As far as I know most all 6 lug patterns are the same spread.. the thing to watch out for is offset..
hmm.. what makes you rhink the ECM/ECU is zapped.. when mine went up in smoke the car wouldn't even start!..no fuel pump, spark or injector pulses.. Unfortunately my knowledge doesn't extend to EA81 turbos, but on an EA82, there' s an electronically controlled valve that regulates idle when cold. there's also a coolant temp sensor that helps the ECU control fuel mixture. Have you tested the ecu? If you decide its going to the wrecker anyway, let me know
Anyone still waiting for BillyC parts shipments???
Sure glad I got my FSM from him before he bailed. That sucks for you guys:(
will only be FI if its a turbo car.. otherwise, its got the hicrappy carb but .. one owner, clean and 57k make any old soob very attractive. How much are they asking? EDIT:.. Miles fox has an 86 with spfi.. but that isn't the norm.. apparently it was an experiment by subaru
opinion on pugs?
one thing to remember is that pugs work so well on our soobies because the offset is very nearly 0. Therefore that half-inch will only equate to 1/4 inch on either side of center
exhaust ?? 2.5" pipe??
forgot to add that there is indeed a muffler there.. not sure what kind.. it is also 2.5 in and out I believe.. I never thought to ask about the os sensor.. good quesion
H6-3.0 in Manual?
calebz replied to Nickshu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad to see another saabthusiast on the board.. my past 10 or so cars before I got my first soob were 900t's and a couple of 9000t's In answer to your question, if you want something on a new soob and it doesn't come that way here, chances are the rest of the world gets it(IE D/R trannies in bajas and outbacks)
I'm looking at doing the same thing soon Steve is running 2.5 inch from the turbo back.. looks much cleaner without that stupid stock downpipe. He kept his legal with a 3 way cat about halfway back.. does the job of the 2 cat setup that the soob has stock.. even the cat is 2.5 in and out.. sounds cool. wan't very expensive either if I recall
opinion on pugs?
depends on the size of tire you plan on using..if you are planning on using something that stretches the boundries of you 6 inch wheels.. then you will have some problems.. what size tires were you considering?
My custom subwoofer enclosure ('85 GL Wagon) (9/28 UPDATE!!)
This really depends on the sound your after.. I have been running sealed boxes for a long time.. vented/ported/bandpass boxes get better boom, but reach distortion levels at lower wattage. sealed enclosures get better thump. as far as the speaker "fighting against itself".. that isn't entireley true either. that fighting is what allows for higher wattage in sealed boxes. the airpressure behind the speaker stops the speaker from overtravelling its voice coil.. which is what causes fried subs. vented or sealed is a preference in sound, not necessarily o function of the speaker.. check the crutchfield compatibility chart somethime.. some speakers are designed for vented.. some for sealed.. some work in both.. then on top of that, there are, as miles stated, free air subs.
In need of engine rebild, LOTS of Q's
Weber.. better exhaust. I think the swap to 1600 pistons only applies to EA81
the Keepers...
Gee.. sure wish I would have known about that when I still had my damned PEUGEOT!! Oh well..:-\ Thanks.. BTW.. I know where a couple of 14 inch alloys are if anyone needs them I would put up some pics of which ones they are, but I am not sure where the wheels page is anymore
Air gate for Brats?
Gee.. I don't even have a brat and I kinda want one of these cool tailgates....
Electric Supercharger?
If you really want one, I have a 12v fan that is just the right size for this application.. its right in front of me.. I value it highly, but if your need is truly great I will let it go for only $150.. but only as a favor to a fellow board member:D
the Keepers...
Thats funny.. those are the same wheels I have on my wagon.. been looking for another.. so what do I find at the yard?.. a 14 incher with the round holes.. oh well.. who says my spare needs to match:rolleyes: And for $14 with a good tire that was even the right size, I couldn't say no.
Yup, ... garbage.. been brought up lots of times. Search the archives
5-Spd D/R Swap: Pedal Assy?
theres a bracket on the outboard side of the assembly. it attaches the assembly to a big chunck of the wiring harness.. sounds like you may have come across it already, given your reference to the" one other that was further up under the dash" If that one other is part of that bracket, .. well.. that bracket has 2 nuts.. look for another nut right next to the first one
