Overheating and blowing cold air
Legacy777 replied to 90subaruls's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USMB. The first gen legacies can be kind of cranky with certain cooling system items. Was the thermostat you put in the car a subaru thermostat? If it was anything but a subaru thermostat, you will have problems. Don't ask me why, but it's been pretty well documented on some of the forums that thermostats other than subaru thermostats can cause you issues. So that's the first thing I would suggest replacing if you don't already have a subaru thermostat. Second, there is a little bleeder screw on the top side of the radiator on the passenger side. You need to remove this screw to properly bleed the air from the cooling system. Remove the bleeder screw, fill the radiator, start the engine, add coolant as necessary until it starts overflowing from the bleeder screw. Put the bleeder screw back in, and top off coolant at the main cap, and put the cap back on. I'd try those things first before messing with head gaskets. You should have heat. I don't think head gaskets are going to cause you to not have heat immediately unless the leak is very bad, but in which case the car would probably not run very well. I'd also suggest checking out http://www.bbs.legacycentral.org if you haven't already found it.
Smelly HVAC
Legacy777 replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's some HVAC/evaporator cleaner I've used for mildew and other stuff. Works very well. I'll usually drop the blower motor and then spray the evap real good. Interdynamics makes it, it's called pure air. May want to try that as well as checking out the evap.
Dirty IAC 2.5RS
Legacy777 replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe IAC on these motors are a little plunger type thing. You can just remove it and clean the carbon and other gunk off it. Clean the area around the TB that you removed it from. If you move the plunger around, when you first start the car the rpms will probably rev up until the stepper motor resets itself to maintain the proper idle speed.
Duty C replacement at Gwinnet Subaru in Atlanta
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat seems pretty reasonable IMO....
95 Legacy clutch cable question
Legacy777 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou talking about the clutch fork? There's going to be a little play, but I don't think there should be a lot. If there's a lot, one of the clips that holds the clutch fork onto the throw out bearing may have come loose.
Sound from front left
Legacy777 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat are you referring to ask backing plate? The anti rattle shims? Some of the new pads have anti rattle shims/pads built onto the pads. Personally, I find those damn anti-rattle shims cause more noise then they're supposed to fix. So I usually don't run them, and will just use some CRC disc brake quieter on the back of the pads where the caliper & pads touch.
Legacy777 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd check the brake pads and also the axles to make sure nothing is rubbing.
Idle question / issue?
Legacy777 replied to yesyeah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's what the idle should be 700-750. If the AC is on, it should be around 800. The tach on the dash really isn't going to give you a good way to measure that small of a difference in the RPM.
coil pack question 2.2 legacy
Legacy777 replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year legacy? The 90-94 Legacies have two different makes, hitachi & diamond, but both are interchangable.
EJ18 T-Belt on a late model EJ22 ?
Legacy777 replied to Huck369's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the trigger pattern is different, then I'd probably say no to the t-belt stuff.
2 wire speed sensor vs 3 wire-Forester
Legacy777 replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you pull and swap the two sensors, or is the connection inside the transmission preventing you from doing that?
Water Pump leak ? 94 Legacy Turbo Wagon
Legacy777 replied to tjaiz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a weap hole on the pump, which would allow coolant to drip out through the seal area. Look for coolant around the pump area
2000 OW 2.5 litre MT- idle problem/power loss
Legacy777 replied to wvcaver's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Cargo box for 07 Outback Sport
Legacy777 replied to timmckee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Engine ID?
Legacy777 replied to Jump This's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USMB. Unfortunately, no there's not a site to my knowledge where you can type in the serial numbers. Are the engines you're looking at US engines or from overseas?
Head Gasket replacement
Legacy777 replied to autobob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Cleaning Tools
I am pretty anal retentive about clean tools.....and what I will typically do, depending on the level of gunk on them, is clean them with brake cleaner first, and then do a final wipe down with a glass/all surface cleaner. As I mentioned, I probably go way beyond what "normal" people do, but that's me. I hate picking up a slimey grease tool that wasn't cleaned from the time before. Only exception is when I've got a several day project going on, I may not clean the tools. Brake cleaner is probably going to work the best for you to remove the power steering fluid.
Electrolosis(sp?) Crap I don't know even know how to spell it!
Yeah I'd like to see some before and after pictures when you get a chance.
EJ Cooling Fan wiring
I would include the connector so both fans operate together.
External transmission filter info
Legacy777 replied to coldfusion21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have not cut one open, but when I was looking at replacing mine, I received that information from one the local Subaru dealerships and another subaru shop I was talking with. The purpose of the add on filter kit was to catch debris or what not from manufacturering. By all means, if you want to cut one open, I'd be curious as well to see what's inside.
The AC short, or sub fan connector causes both fans to operate together on AC equipped cars. This is the desired operation. I am pretty sure that the fans are operating at high speed all the time. Here's the crazy AC wiring diagram for the fans http://main.experiencetherave.com/subaru_manual_scans/FSM_Scans/ACwiringdiag.jpg And the regular fan diagram http://main.experiencetherave.com/subaru_manual_scans/FSM_Scans/1992_legacy_radiator_fan_wiring_diagram.pdf Regarding the temp sensor. There are two temp sensors (at least on the 90-94 Legacies) The one-wire sensor goes to the dash gauge, while the two wire sensor goes to the ECU. Both wires of the two-wire sensor need to go back to the ECU. One wire is the 5v reference voltage, and the other is the signal coming back to the ECU.
Legacy777 replied to coldfusion21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can buy the whole external filter kit for like $20, which includes the filter. Yes, I know it's cheaper than buying just the filter. Go figure. That's what I did when I replaced the filter, just bought a whole kit. BTW, that external filter, is mainly just a screen, and does not have any filter type paper in there. If you want to add a cooler, I'd suggest routing the lines from the transmission, to the external cooler, and then into the radiator cooler, and back to the transmission. This will keep the trans fluid temp moderated in cold climates, and should eliminate the need for a thermostat to be installed.
Legacy 1994
Legacy777 replied to Conroe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I believe your correct. So the ECU should be in the passenger footwell.
Legacy 1994
Legacy777 replied to Conroe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's a pic of the MAF sensor (minus the stock airbox) Here's a pic of the ECU
99 Impreza Outback Sport Engine Lag
Legacy777 replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood to hear that helped.
