A/C question
Legacy777 replied to shaner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you pinpoint where the noise is coming from? Sometimes you can have pressure leak by from the high side to low side, but that is typically more of a hissing sound.
Which pins to short? (Impreza cruise control question)
Legacy777 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could probably bypass the clutch, but I definitely wouldn't bypass the brake. There's a diagram at the bottom of this pdf which may help. http://main.experiencetherave.com/subaru_manual_scans/FSM_Scans/1997_Impreza_Cruise_add-on.pdf
Timing belt on 2.2L
Legacy777 replied to roger1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is no 180 deg out with these motors. Just line up the marks and install the belt. BTW, at those marks, the timing is not at TDC. Also, make sure you use the correct mark on the crank gear. It is the mark at the BACK of the timing gear and not the mark on the front. You can see what I'm talking about in this picture. http://main.experiencetherave.com/subaru/images/timingbelt/DCP_2728.JPG
92 legacy driver door lock problem
Legacy777 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe first gen legacies are kind of an oddity. They have power locks, but they're not really your typically power locks, at the driver's door. For the older subarus, including the first generation legacy. If you turned the key, it would unlock the driver's door, if you turned it a little further, it would unlock all the doors. Because of this there was no electric actuator on the drivers's door lock system. It does sound like you may have more than one problem. First thing you need to do is remove the door panel. That will let you see the locking mechanism & rods. I'd start with the key lock assembly. There are rods going up to the key lock cylinder and door handle. There are plastic clips you can slide off the rods to allow them to detach from the lock cylinder and handle. Then you can remove the door handle by removing the two 10mm nuts. Once it's out of the car you can test the lock cylinder and see if it's turning freely. Once you do that, you can check out the locking mechanism rods and plastic connector joints to make sure nothing is binding, and they are lubed. Hope that helps.
Clutch gone, dual mass flywheel questions
Legacy777 replied to welly's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've never heard of any subarus with dual mass flywheels, however that doesn't mean they don't. I however don't see why you couldn't replace the dual mass flywheel with just a normal flywheel & sprung clutch......
jumping time
Legacy777 replied to mike97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the tensioner, and make sure all the idler pullies are good. Over time the grease will dry up, and they can seize. This is especially bad when it's the idler gear. This is what happens http://main.experiencetherave.com/subaru/images/shreddedtbelt
cleaning prep for head gasket replacement
Legacy777 replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you tried a very high grit sandpaper? I wouldn't go nuts with it, but it shouldn't bother the mating surface.
Exhaust for my 1997 Legacy GT??
Legacy777 replied to anwieczo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAn up pipe is something for a turbo charged car. You do not need one. As you have found, there's not much out. If you want the most gains from the exhaust have an equal length header setup made. MRT used to make a setup like this, and it produced the most gains in the non-turbo engine compared to a typical subaru header configuration. The only thing to keep in mind is that if you go with an equal length header, you will lose the deep subaru rumble exhaust note. It will be a more raspy sound, but still sounds good.
Wagging steering wheel
Legacy777 replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I'd probably start with getting the wheels balanced.
2002 Impreza wanting to stall?
Legacy777 replied to hairpy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would probably start with the basic tune up items, filters, spark plugs, etc if you have not done them recently. If you or someone you know has an OBD2 scanner, you can watch the ECU parameters to help aid in troubleshooting.
CAT - Legacy Outback 2.5 AT '01
Legacy777 replied to HonzaCZ's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do have a high flow cat from magnaflow that I am using with my aftermarket exhaust. It seems to work alright. However I don't have any experience with replacement cats for OEM exhaust. In reality, it should work fine. I don't know if they will last as long. They should still pass all the emissions tests/checks. My suggestion would be to see if you can get some feedback from users in Europe on the non-OEM catalytic converters being sold.
Forester 07 automatic shifter
Legacy777 replied to bakuteh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably not
Still can't get 4th
Legacy777 replied to bsaride's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably something broke inside the transmission with the shifter fork. Not much you can do about it unless you open the transmission up.
Foglight question?
Legacy777 replied to bostonfan49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Legacy777 replied to HonzaCZ's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould be fine using a CAT from another country.
Conversion kit for '99 Forester radio
Legacy777 replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to use a pocket or cubby from the first gen legacy or some other subaru.
96 Legacy Brakes & CV axel
Legacy777 replied to guidance1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXScott, I will caution you about using non-oem steering boots. A previous owner replaced a boot on my Impreza with a non-OEM boot, and it was just a tad too short so when you were at full lock with the steering, the boot was being stressed/stretched. Eventually, the boot tore, and I got to replace it.
benchpressing 250 pound transmission at 2 in the morning...
Legacy777 replied to shortskoolbus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPulling the AT trans SUCKS! I definitely did not enjoy that job.
Projector Headlights on 94-98 Legacy GT
Legacy777 replied to AlpineRaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to get the yellowing off with some plastic cleaner, or clear coat rubbing compound and cleaner wax.
Forester FXT Struts on '90 Legacy - with Pics.
Legacy777 replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like a nice offroad machine.
Will 2002 Forester cargo cover fit a 1999 Forester ?
Legacy777 replied to jimrichard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump anyone know?
2009/2008 Outback key fob
Legacy777 replied to flash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt probably can. Just go to a local dealer, ask to look at the 2009 keys and see if the key structure/layout is the same. If so you should be good. Then all you need to do is get the new key blank, give the parts counter the code off your original keys and have a new key made. Or they should be able to look up your key code via your VIN.
STI STS...20% off?
Legacy777 replied to cvlooper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are working pretty good. I'm still happy with the feel. I've got essentially the same bushing setup between the Legacy & Impreza, minus the custom joint on the Impreza, and I can tell a difference between the two transmissions.
how many volts to the speedometer head?
Legacy777 replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould be volts.
'98 OB noise
Legacy777 replied to tomzieber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it only occur when the car is moving? Could be a wheel bearing, cv axle, something in the trans...
