30
Everything posted by Turbone
Generally, anything 84 and up will be a hydraulic lifter engine. Altho theres no guarantee of this either. It would be better f you could find a donor car, one that you know is a runner with just body damage or rust as the problem. The only checks that can be done with the engine out of the car is oil consistency, color and odor. A milky looking oil means theres water in it and most likely a head gasket has gone bad. This isnt terminal either, but you wont know how badly the engine was overheated till you pull the heads and see if theres a major crack between the valves. The location in your sig says Pacific, Wa. Is this the Pacific by Sumner, Wa?
The annual Hatch Patrol Christmas tree run
Turbone replied to Qman's topic in Meet n' Greet. Your USMB Welcome Center
Its 20min for me Be cool if you can make it Richie, and all the others that have never made this outing. Just hope theres more snow than there is now :-\ -
WCSS8 Where will it be?
Turbone replied to Scott in Bellingham's topic in Meet n' Greet. Your USMB Welcome Center
Hmmm, I really prefer to pitch my tent on a dry surface -
Donny's hurt - maybe in Seattle
Turbone replied to harpua's topic in Meet n' Greet. Your USMB Welcome Center
Well, he picked the right place to come to. The hospital is the areas best, and the peeps here are even better. Donny and his Bro will be taken care of, thats for sure. Btw, did he fall or jump off a roof? -
Welcome to the board, and howdy to a local owner The smoke could either be from bad rings or bad valve seals. Theres enough Soobs in the yards around here, it might be more feasible getting another engine for it. I saw a hyd lifter engine (smoother running) in a wagon at the Tacoma PAP last weekend. It doesnt matter if the car is 2wd or 4wd really, they all work (EA81). The special tool for the axles is just to make the job easier and faster. You can do it without the tool. Let me know if you would like some hands on pointers
Actually the WCSS events have always been a little later in the year like spring, thats when the mudd starts drying up. Maybe they could hold the event earlier the year? OR we can do something different and call it the Subaru MUD Festival. What? Nobody around there has a Water Truck? We have had to do this a few times at previous shows. What I miss is the RallyX events and mud pits -
I suggested the correct way to do the job. The chance that someone would have a pair of Channel Locks big enough to turn the bottom is the same as that person having spring compressor tools. You can rent the spring comp at most Parts Stores and it makes the job alot easier. And you dont mar up the bottom of the shocks doing it.
Cmoing home for a few days
Turbone replied to calebz's topic in Meet n' Greet. Your USMB Welcome Center
This "Boy" goes to Mad Dogs Diner I like to eat, but these dishes are so big I have to get a half order -
You need a coil spring compressor tool to adjust the shocks. They adjust from the bottom, with 3 different settings. I'm not sure if the strut is replaceable.
If you want to find out if its the gov, just remove the cover and pull the gear out. If the center is worn out, the unit is bad. Simple as that.
Hard starting issues with Weber?
Turbone replied to Mykeys Toy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Fuel filter? Does it have 2? -
MY 84 GLF 4WD SEDAN, 320.000 km on it.
Turbone replied to dgarzon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Where? -
Yes, please. Let us know where he wiil be staying. Someone here should be able to visit him. -
Whatcha lookin for Mykey? Give me a ring, might want to go too.
Call me when you get in. We'll set up a time and place to get together. -
I have 2 of each Well, 2 EA82T's and 2 XT6's anyways. But I would go with the XT6. Stock HP is 145hp. And lots of fun to drive
Detroit Lockers, and Subaru's
Turbone replied to MoscowSubaruDude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the trailing arm isnt dropping far enough when you jack the rear up, you may have to remove the lower bolt on the shock to get the axle off. -
You would need to go with straight axles to put a DL in. The easiest way is to weld the rear diff and just run with one axle removed when on the street. Lots of us do this, me included. -
Sounds like you spun a hub. Pull the dust caps off the front axles and then get out the car in gear while running. See if the axle(s) are turning in the hub(s). Oh, and it would be a good idea to block the wheels
I would try Craigslist.org before Ebay. Its free
Well,... i cut my cap into a spoiler
Turbone replied to 75subie's topic in Historic Subaru Forum: 50's thru 70's
The rest of that cap might fit on someone's Bratch No, I dont have one. But theres a few that do. -
Why get expensive flares when they will just get torn off when you offroad the car? Unless you dont have any trees or big rocks where you offroad?
Let it run for a while, it might burn off.
Hats off to USMB members!
Turbone replied to LUVMYBRAT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry you had to come so far for nothing :-\ It was so dark out, you couldnt see my "collection". Bill's a good guy, had a few deals with him and has always come thru
