30
Everything posted by Turbone
It took me over an hour to DL the last one, I'll be dipped if I'm going to try 20M Besides, I was there - done that Cant wait for this years runs
The best 4x4 money could buy is not going to do you any good on ice . It all comes down to knowing how to drive on it.
Did you get vid of me coming up out of that creek? Where I got some air under the front wheels
new guy/old subaru
Turbone replied to rainsplitter's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to our (strange) world! Lots of us in Pierce Co, will be having a get together at Evans Creek in a few weeks. Theres also lots of Soobs for sale on craigslist.com, some in your area -
Roll call for Jared's get together!
Turbone replied to Qman's topic in Meet n' Greet. Your USMB Welcome Center
Its a go here -
ea82 engine/tranny pictures?
Turbone replied to bushbasher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So what your saying is, you want pics of the engine and tranny outside of the car? -
Then why not just drop a EA82T in it?
I agree with John, this could still be a timing issue. You said it backfires thru the carb, this is a sure sign of bad timing. Might want to check those belts again.
Just 2 photos of the RX from today.
Turbone replied to tizzle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Geez, and I thought I lived in the sticks You live in the middle of Puget Sound! -
Over here the 83 DL had a EA81 from the factory. Was the EA82 in yours a retrofit?
Engine and Trans Replacment Help
Turbone replied to Bro's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you pull the engine and tranny as a unit, you wont have to much work under the car. Just to remove the tranny x-member and linkage. You might want to remove the engine/tranny in the car your putting the lift in first. Once they are out, go ahead with the removal of the other engine/tranny pull. -
Great pic! And the STI Brat is a looker. But isnt that a Mitsu in the bottom center?
Some of us have done AT to MT swaps and its no piece of cake. You need to install another pedal on the assembly box. Need to change the rear end to match ratios. Need to change tranny mounts and any other mounting needed. You also need to defeat the AT elec lock out switch. Now, if your a ambitious person and want that MT tranny real bad, go for it. Just my .02
But it wil get a little rusty I wish I could remember everything I knew and lernt :cool:
Sounds like the thermostat is sticking. Make sure you replace it with OEM, all others suck and dont last. 180deg is the recommended temp.
Yeah, that was before he had a Subaru addiction I dont think he's lost his sense of humor tho
Looking gooood Btw, what kind of roof rack is that?
ignition problem need help ASAP
Turbone replied to stngllhm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Fuseable links maybe? -
I'll try and get a pic of the "setup" on Hatchet this weekend. Its not your everyday washer
HELP - 1986 Fan Clutch...Update!!
Turbone replied to LuckyPistol's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If I recall, you supplied the parts? He would have assumed you had bought the correct parts. But on the other hand, when he installed the water pump he should have been able to tell that the pulleys did not line up and then should have said something. -
Wow, deja vue all over agian Wish we had snow we had to dig out of :-\
86 Turbo Wagon - Cowl 87 Turbo Wagon - Cowl 89 RX - Hood 89 XT6 - Cowl
Horn Fuse and Turn Signals
Turbone replied to leahchris's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, when you put in a 30amp fuse and saw smoke come from the steering column, I would say you located the problem. Theres obviously a short in there and you might need to replace the horn or at least find out why its shorted. There should be a connector plug for the horn, disconnect it and then try another fuse (the right amperage). You can always install a different horn button. No FSM needed here, just common sense.
