30
Everything posted by Turbone
Its obvious you have never spectated during "serious" offroading. I've had rocks chucked at me while standing on the trail from Subaru's sporting superswamper tires. This is also like going to a Rally X and working the course. You dont do something like this and not expect to have stuff flying around. Maybe you should have worn a helmet more often.
Sounds like someone is jelly The whole buggy is a helmet for goodness sake! He didnt know his wheel was off because of all of the dirt flying, he thought he was stuck on something (little did he know it was his wheel)
Um........wow. Is there such a thing as too much power?
No need to, the end of the projector fits right thru the stock opening.
Around $100......if the glass doesnt crack. Theres a risk when grinding and polishing.
Turbone replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Memorial day weekend some where in central WA. If you look at Subinewbys avatar, he has the black lifted coupe. -
http://motors.shop.ebay.com/i.html?_nkw=hid+projector+kit&_sacat=33710&Placement%2520on%2520Vehicle=Front&Part%2520Brand=New%2520Aftermarket&_dmpt=Motors_Car_Truck_Parts_Accessories&_odkw=xenon+hid+kit&_osacat=33710&bkBtn=&_trksid=p4506.m270.l1313 These look like the ones I have. http://www.ebay.com/itm/G5-HID-Bi-Xenon-Headlight-Projector-Lens-Kit-ballast-Fast-shipping-/200692631365?hash=item2eba368745&item=200692631365&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr#ht_2384wt_1159 I didnt buy them off ebay tho, I got them from another board member.
value of newly purchased rx turbo
Turbone replied to jamie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://losangeles.craigslist.org/lac/cto/2749230187.html This was a donated vehicle, I predict this will not end well. To the OP (if you come back)......Why would you buy this? -
has anyone done the hid conversion on gen 2?
Turbone replied to 85wagon's topic in Subaru Retrofitting
After you updated this I re-read the title and your first post. You done messed up. You asked about Gen 2 Subaru's and got responses about those, when you were actually talking about Gen 3's(?). You need to read my write up about doing HID's (with projectors)in a Gen 3. http://www.ultimatesubaru.org/forum/showthread.php?t=125187&highlight=Turbone -
Apparently he's had a EA82T before - http://www.ultimatesubaru.org/forum/showthread.php?t=126521 But its also apparent that he's a one hit wonder. Meaning he will start a thread and never come back to to answer a question. So, we will probably never know what happens when he picks this up and tries to make that 2000mi trip from LA to WI. -
Yup, and add in the timing belts, flushed radiator, a recent tune up, tires....and the list goes on. If you do decide to drive it back to WI, get a list of members that live along the way, you will most likely need it. -
He's in WA state.
Subaru's need grounds every where. Engine needs a grnd to body, battery needs grnd to body, ecu needs grnd to body, dash needs grnd to body......I could go on
Nope wont work, linkage is different.
Welcome to USMB. Another local
The answer to all these questions is EJ. Theres all kinds of options with gears and clutches. You wont get any upgrades with the old EA trans, been there already. And its not going to last very long either, I've been thru 2 RX trannys in 1yr. I'm just now completing my EJ trans swap and should be back on the road is about a week.
In OLympia now for work!
Turbone replied to monstaru's topic in Meet n' Greet. Your USMB Welcome Center
Your welcome to come up to my place, its only 30mi away. -
would this wagon be worth getting or not
Turbone replied to bheinen74's topic in Historic Subaru Forum: 50's thru 70's
To much rust, it needs to be crushed. -
Bypass squealing a/c compressor?
Turbone replied to SmashedGlass's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Actually, I just re-installed the a/c in my RX. Being a black car it needs it, plus power isnt a issue any more -
I would like to see vid of this when its up and running (racing)
1993 subaru ss
Turbone replied to katoi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Could very well be a grounding problem if the car is close to the sea. If you look at it, get underneath if possible and look for rust. Also check out the inner fenderwells. -
Remove the belt, then take a measurement without the a/c for a new belt. -
^^ Right after I got it. Proceeded to get it muddy and got stuck, big thanks to Qman for getting me out :-p -
Can you get a picture?
