Turbone
Administrator
    30
Everything posted by Turbone
  1. I'vr grenaded a couple of front diffs like this. Broken teeth off the ring gear and the grease will sling them up and they catch in the teeth that are still left. Easiest thing to do is replace the trans.
  2. Rockauto.com Some will say get oem seals, so try 1stsubaruparts.com
  3. Older Mitsubishi Eclipse turbo. Not sure exact year. A lot of fabbing to make them fit also.
  4. This is what mine looked like when I was doing the EJ swap. All better now.
  5. The biggest issue is with the 92 to early 95 trans. Rarely are the originals still in the car. If they are, its been rebuilt. The rear wheel bearings wear out after 100k. Other than that its a well built car. The engine is pretty bullit proof. I've owned 3 SVX.
  6. I dont think the guy at the shop knows anything about old school turbo'd Subaru's.
  7. Theres a tag on the back plate. Should be a 3.70.
  8. Welcome to the USMB Colonel. If you want a pristine Loyale, look on the West Coast.
  9. I put early Legacy seats in my 86 Brat, no pics of it. Put 90's Mitsubishi Eclipse seats in my 85 Brat. I had XT6 seats in my RX, but they were to stiff, so I found another pair of Mitsu Eclipse seats.
  10. It all centers on where you have the end of cable bracket. To have it work correctly it needs to be mounted on the back of the intake manifold. Mine is mounted to where the EGR used to be and works fine.
  11. If you want a shop to do it, go to Pacific Import Auto in Spanaway. They only work on Subaru's and are very knowledgeable with the old gen stuff. http://www.yelp.com/biz/steves-pacific-import-auto-tacoma
  12. If they salt the roads during winter in your area, dont drive it.
  13. The first thing you want to check is the timing belt, make sure if its broke or not. Removal of the covers will tell you if it is. If the belt is broken you might as well yank the engine because its going to need a lot of work. A snapped t-belt at 75mph is going to do some internal damage for sure.
  14. In the 6yrs since this thread was started, many people have done the swap. And what are impress seats?
  15. It moves around the PNW every year. It could be in Oregon or Washington next year. Wont know until around April/May(or later).
  16. Turbone
    EA81 Tool
    Hopefully it wont shear off when you try and break a head bolt lose :-p
  17. Finally got the trans in my SVX, its only taken 2yrs Now to install the timing belt kit and waterpump and drop the engine in.
  18. Huh, been so long forgot all about it. I probably forgot 10min after posting saying I would
